Hi Team,
As you know, DLP2010FQJ had been done EOL. So please let me know the differences(in more detail) between DLP2010FQJ and DLP2010AFQJ such as pin map, package, and functions.
Hi Team,
Hello Jeffrey,
Welcome back to the E2E forums and we hope to assist you with your questions.
Please give our team some time to look into this issue further and please note the delay due to the Memorial Day holiday in the U.S.
Thank you for your patience.
Alex Chan
Hi Jeffrey,
The updated part numbers correspond to updated differences between our display and light control chipsets. Otherwise any additional information such as supported pin mapping can be found in the data sheet and should be compared with your design if you previously used the DLP2010AFQJ. You should however be able to use the updated part number: DLP2010FQJ the same for a display application. However if your application is a light control one and uses a DLPC37x controller you will need the DLP2010LC: DLP2010LCFQJ.
Maximus
Hi Maximus,
Thanks for your response. But I want to know if the pin map, package, functions of DLP2010AFQJ are same as DLP2010FQJ. Please share it with me if you have the comparison table between DLP2010AFQJ and DLP2010FQJ.
Hi Jeffrey,
These two parts have the same pinmapping and should be interchangeable with the exception the new DMD part number will require a firmware upgrade to the latest version. Older versions which supported the DLP2010FQJ do not support the DLP2010AFQJ part.
Maximus
