DLPNIRNANOEVM: Different light source
Part Number: DLPNIRNANOEVM
Is there a way (hardware or software wise) to turn off the two tungsten lights and use your own light source for material analysis?
Thank you,
Predrag
  • Hello Predrag,
    Thank you for reaching out to us through E2E!
    I am reaching out to an expert on this issue and they will respond shortly! Thank you for your patience!
    Aaron
  • Hello Pendrag,
    Please refer to the NIRNANOEVM User's Guide - https://www.ti.com/lit/ug/dlpu030g/dlpu030g.pdf.
    See the table and picture on page 18.  J501 (marked "Lamp" on the picture) can be disconnected which will disable the lamps.  This output can drive a little bit more power than the on board lamps, or better it can be used via some enable on your own lamp driver.
    Fizix
