DLPLCR65EVM: Mounting Options for Optical Table
Part Number: DLPLCR65EVM
Good Morning,
I’m planning to integrate the DLPLCR65EVM into a precision optical setup on an optical table. Does TI offer a mechanical mount or fixture for this evaluation module that supports fine XYZ translation and angular alignment (e.g., tip/tilt), or are there any compatible third-party mounting solutions you recommend?
If not, is there another DLP product that you recommend which would work better with an optical table?
Alex Montes McNeil
  • Hello Alex,
    Thank you for reaching out through E2E!
    If you go to the product page on ti.com for the DLPLCR65EVM and go to the "Design Files" section, DLPC148.zip has both mounting concepts for both DMD types but you will need to look at the 'standard' type. The document 2511654-s600-MtgConcept.pdf will have this detail.
    I'd have to ask my team about an optical table, but it is fairly common for us to design systems to be utilized on optical tables. Please advise if you need further information.
    Aaron
