DLP300S: DMD >10 kHz binary control
Part Number: DLP300S
We are developing a compressed sensing imaging solution covering the UV to SWIR range and were wondering if some of the lower-cost DMD models allow binary control of the mirrors at rates above 10 kHz.
If so, could you please point us to the relevant models? This doesn’t seem to be a very common application, and the external print mode specifications are not detailed in the datasheets.
Additionally, I would like to know if you have transmission curves for Corning Eagle XG glass with the UV coating, since this curve does not appear in the Application Report – Wavelength Transmittance Considerations for DLP® DMD Window (ideally covering wavelengths up to 2500 nm).
Thank you very much for your help.
