Need a daughter board to connect Discovery 4100 via EXP
We are using the DLP Discovery 4100 board and would like to stream data from PC, probably from HDMI/DVI, to the board via EXP ports. Could you suggest any daughter boards that have the compatible EXP ports? Or EXP mating components that we could build a simple circuit with?
I have searched a lot on the Internet but found nothing useful. The most related one is the xapp460 from Xilinx (link listed below), but it is no longer being fabricated.
http://www.xilinx.com/support/documentation/application_notes/xapp460.pdf
Thanks a lot!
Lu
