Hello, I am using Lightcrafter 4500 and I can't get working Pattern sequence with Video Port as pattern source.
In particular, the DLP is connected vai HDMI to win7 PC and I currently have extended screen; in video mode all works fine and when I drag a window to the second screen, Lightcrafter displays it well. Now I want to turn to pattern sequence mode, and I successfully had it working with flash as source (e.g. the example in the user manual which projects pattern #8 works fine).
Now I'd like to stream the patterns via HDMI but, as soon as I switch to Video Port as Pattern Source, the DLP turns black and doesn't show anything. I have found little documentation about this particular topic on the manual, so I am asking here. In particular, I can't understand how pattern should be streamed to the DLP: simply by dragging the window on the DLP screen (and there might be some downsampling to 8bit?), sending to DLP a video of the patterns, sending the 24bit images to the DLP (but how?)?
Thank you in advance for your attention
Giovanni Riva
