Hello TI team,
Now I am using the LI-VM01CM camera module for lightcrafter. The resolution is not good enough. Right now, I tested the LI-2M05CM module on lightcrafter but it doe not work and when I run the lightcrafterprogram, it prompts "Command Failed". I want to know, do you have any other camera module recommended? Or if there are any method like by accessing the firmware so that I can write a driver for other camera?
regards
bojing
