I'm trying to use the Video Pattern Mode to input 1K Hz of pictures in 1 second (every picture is different), and the bit depth is 1, I'm wondering how or what to do to reach the goal. Thanks for answering.
All The Best
All The Best
Hi Michael,
Achieving a frame rate of 1000 Hz with 1000 1-bit pictures is indeed possible on the LightCrafter9000 EVM in Video Pattern Mode.
For an example of how to set up a Video Pattern Mode pattern sequence, review section 3.6.4 of the User's Guide: http://www.ti.com/lit/dlpu028
For your application, you'll probably want to add 24 1-bit patterns to a frame with the appropriate timing to achieve your desired frame rate. This process can be repeated with new images to display your desired amount of patterns.
Let me know if you have any difficulties setting up a pattern after looking through the User's Guide.
Trevor
