External patternsequence software?
hi,
i would creating pattern sequences streaming to send from HDMI port. I have generated 2016 monochromatic bmp images but i don't know how to generate the 1440 pattern rate video to send from HDMI, is there any software to do this?.
thanks in advance.
Fabrizio.
  • Hello Fabrizio,
    You need some kind of video frame generator that can select from the pattern stored in the frame-buffer. Typical uses case you can use FPGAs to generate or embedded processors and kernel programming that allow direct control of writing data into it's frame buffer.
    Sanjeev
