Questions about pattern display of LightCrafter4500EVM
As a result of projection by loading a pattern of ON and OFF every 1-pixel.
Blue and black are crushed and become all blue.(Please see the attached file)
11.pdf
Is this the influence of the mirror of the diamond array?
Seishin
  • Seishin,
    I am presuming you are using 912x1140 resolution images, also you are in pattern display mode, 1-bit pattern display?. Let us know if it is not the case.
    To answer your question, Diamond array arrangement could cause this, to get straight lines, draw lines diagonally on the DMD, you should see straight lines.
    Sanjeev
