The checksum mismatch problem for Lightcrafter 4500 USB programming
Hello everyone, I have made the PCB of lightcrafter 4500 Projector by myself according the information of TI. When I Programming the "*.bin" file into two flash chips. I found a problem of "checksum mismacth". The communication of USB interface is good, as well as the programming process of JTAG Boundary Scan by UM232. Has somebody encountered the same problem before? Please help me.
    To confirm, you have programmed the .bin file successfully with the JTAG programmer and you are receiving the checksum mismatch when programming the same .bin file with the GUI, correct? If not, could you further elaborate on your setup and procedure?
    Could you also provide the versions of the binary and GUI you are using?
    Clinton
