I am using a Lightcrafter 6500. I need to produce a stationary pattern of laser light that is stable in time. So far, I have found that if I project a stationary pattern on the DMD, and illuminate it with a laser, while the pattern is on, every 105 us, the dmd turns off and immediately back on. Is there a way to control this rate (ideally significantly decreasing the rate), without changing the number of active blocks or the bit depth?
Thank you.
