DLP6500/9000 GUI on Linux
I have compiled the GUI on Linux with Qt5.
Posting here the patch file with all the changes I had to make few changes in order to compile and link the gui.
This also fixes a bug that prevents GUI from saving the I2C slave address when updating the firmware image.
diff -u Sources.orig/batchfile.c Sources/batchfile.c
--- Sources.orig/batchfile.c	2016-03-02 03:32:11.000000000 -0500
+++ Sources/batchfile.c	2016-06-02 11:51:05.247708775 -0400
@@ -12,8 +12,8 @@
 #include <string.h>
 #include <stdlib.h>
-#include "common.h"
-#include "error.h"
+#include "Common.h"
+#include "Error.h"
 #include "batchfile.h"
 #include "API.h"
diff -u Sources.orig/batchfile.h Sources/batchfile.h
--- Sources.orig/batchfile.h	2016-03-02 03:32:11.000000000 -0500
+++ Sources/batchfile.h	2016-06-02 11:51:44.507223873 -0400
@@ -14,8 +14,8 @@
-#include "error.h"
+#include "Error.h"
 #include "API.h"
 #ifdef __cplusplus
diff -u Sources.orig/BMPParser.h Sources/BMPParser.h
--- Sources.orig/BMPParser.h	2016-03-02 03:32:11.000000000 -0500
+++ Sources/BMPParser.h	2016-06-02 11:36:02.830955902 -0400
@@ -8,7 +8,7 @@
 #include "Error.h"
 #include "Common.h"
-#include "Pattern.h"
+#include "pattern.h"
 #ifdef __cplusplus
 extern "C" {
diff -u Sources.orig/compress.c Sources/compress.c
--- Sources.orig/compress.c	2016-03-02 03:32:11.000000000 -0500
+++ Sources/compress.c	2016-06-02 11:51:22.537495226 -0400
@@ -8,8 +8,8 @@
  * This module provides RLE compression related APIs
-#include "error.h"
+#include "Error.h"
 #include "compress.h"
 static uint08 *AddCount(uint16 Count, uint08 *Out)
diff -u Sources.orig/compress.h Sources/compress.h
--- Sources.orig/compress.h	2016-03-02 03:32:11.000000000 -0500
+++ Sources/compress.h	2016-06-02 11:35:33.265324703 -0400
@@ -10,7 +10,7 @@
 #ifdef __cplusplus
 extern "C" {
diff -u Sources.orig/Error.c Sources/Error.c
--- Sources.orig/Error.c	2016-03-02 03:32:11.000000000 -0500
+++ Sources/Error.c	2016-06-02 11:51:35.977329227 -0400
@@ -13,8 +13,8 @@
 #include <string.h>
 #include <stdlib.h>
-#include "error.h"
+#include "Error.h"
 /******************************** MACROS **************************************/
diff -u Sources.orig/firmware.c Sources/firmware.c
--- Sources.orig/firmware.c	2016-03-02 03:32:11.000000000 -0500
+++ Sources/firmware.c	2016-06-02 11:48:55.394318969 -0400
@@ -10,11 +10,11 @@
-#include "Splash.h"
+#include "splash.h"
-#include "Firmware.h"
-#include "FlashImage.h"
+#include "firmware.h"
+#include "flashimage.h"
 #define FW_MAX_BLOCKS		512
diff -u Sources.orig/firmware.h Sources/firmware.h
--- Sources.orig/firmware.h	2016-03-02 03:32:11.000000000 -0500
+++ Sources/firmware.h	2016-06-02 11:49:00.768251934 -0400
@@ -10,10 +10,10 @@
  * This module provides the flash binary reading and manipulation functions
-#include "BatchFile.h"
+#include "batchfile.h"
 #ifdef __cplusplus
diff -u Sources.orig/firmwarepage.cpp Sources/firmwarepage.cpp
--- Sources.orig/firmwarepage.cpp	2016-03-02 03:33:35.000000000 -0500
+++ Sources/firmwarepage.cpp	2016-06-02 15:01:09.190526714 -0400
@@ -278,7 +278,8 @@
-    if (ui->updateFlashWaitCycle_checkBox->isChecked())
+//    if (ui->updateFlashWaitCycle_checkBox->isChecked())
+    if (ui->i2cSlaveAdd_checkBox->isChecked())
         if(fw->setConfigBits(FW_CFG_I2C_ADDRESS, ui->i2cSlaveAdd->text().toUInt()) < 0)
             showError(GET_ERR_STR());
diff -u Sources.orig/FirmwareW.h Sources/FirmwareW.h
--- Sources.orig/FirmwareW.h	2016-02-15 00:23:01.000000000 -0500
+++ Sources/FirmwareW.h	2016-06-02 11:47:50.799124727 -0400
@@ -7,7 +7,7 @@
 #define FIRMWAREW_H
 #include "PtnImage.h"
  * Class for loading, storing and manipulating the firmware file. This is a
diff -u Sources.orig/flashimage.c Sources/flashimage.c
--- Sources.orig/flashimage.c	2016-03-02 03:32:12.000000000 -0500
+++ Sources/flashimage.c	2016-06-02 11:51:40.546272796 -0400
@@ -10,8 +10,8 @@
 #include <stdio.h>
 #include <stdlib.h>
-#include "error.h"
+#include "Error.h"
 #define BOOT_SECTOR_SIZE_MIN    0x8000
diff -u Sources.orig/flashimage.h Sources/flashimage.h
--- Sources.orig/flashimage.h	2016-03-02 03:32:12.000000000 -0500
+++ Sources/flashimage.h	2016-06-02 11:35:04.205687192 -0400
@@ -5,7 +5,7 @@
 #ifdef __cplusplus
diff -u Sources.orig/flashloader.c Sources/flashloader.c
--- Sources.orig/flashloader.c	2016-03-02 03:32:12.000000000 -0500
+++ Sources/flashloader.c	2016-06-02 11:51:27.935428555 -0400
@@ -11,7 +11,7 @@
 #include "API.h"
-#include "error.h"
+#include "Error.h"
 #include "flashloader.h"
diff -u Sources.orig/flashloader.h Sources/flashloader.h
--- Sources.orig/flashloader.h	2016-03-02 03:32:12.000000000 -0500
+++ Sources/flashloader.h	2016-06-02 11:35:26.559408352 -0400
@@ -10,7 +10,7 @@
  * This module provides the flash programing APIs
 #ifdef __cplusplus
diff -u Sources.orig/GUI.pro Sources/GUI.pro
--- Sources.orig/GUI.pro	2016-03-02 03:32:11.000000000 -0500
+++ Sources/GUI.pro	2016-06-02 11:44:27.978654704 -0400
@@ -74,6 +74,6 @@
 INCLUDEPATH += ../GUI/hidapi-master/hidapi
 DEPENDPATH += ../GUI/hidapi-master/hidapi
-OTHER_FILES +=  icons\GUI_icon.rc \
-                icons\GUI_icon.ico \
+OTHER_FILES +=  icons/GUI_icon.rc \
+                icons/GUI_icon.ico \
     Icons/GUI_icon.rc
diff -u Sources.orig/mainwindow.h Sources/mainwindow.h
--- Sources.orig/mainwindow.h	2016-03-02 03:32:12.000000000 -0500
+++ Sources/mainwindow.h	2016-06-02 11:47:42.121232975 -0400
@@ -10,7 +10,7 @@
 #include <QSettings>
 #include <QFile>
 #include "waveformwindow.h"
 #include "FlashDevice.h"
 #include "FirmwareW.h"
diff -u Sources.orig/pattern.c Sources/pattern.c
--- Sources.orig/pattern.c	2016-03-02 03:32:12.000000000 -0500
+++ Sources/pattern.c	2016-06-02 11:51:47.943181435 -0400
@@ -13,8 +13,8 @@
 #include <string.h>
-#include "error.h"
+#include "Error.h"
diff -u Sources.orig/pattern.h Sources/pattern.h
--- Sources.orig/pattern.h	2016-03-02 03:32:12.000000000 -0500
+++ Sources/pattern.h	2016-06-02 11:51:51.435138305 -0400
@@ -14,8 +14,8 @@
-#include "error.h"
+#include "Error.h"
 #ifdef __cplusplus
 extern "C" {
diff -u Sources.orig/PtnImage.h Sources/PtnImage.h
--- Sources.orig/PtnImage.h	2016-02-15 00:23:10.000000000 -0500
+++ Sources/PtnImage.h	2016-06-02 11:50:02.101488708 -0400
@@ -7,10 +7,11 @@
 #ifndef PTN_IMAGE_H
 #define PTN_IMAGE_H
-#include "QImage.h"
-#include "QPixmap.h"
+#include "qimage.h"
+#include "qpixmap.h"
+#include "Error.h"
  * Class for loading, storing and manipulating the pattern image.
diff -u Sources.orig/splash.c Sources/splash.c
--- Sources.orig/splash.c	2016-03-02 03:32:12.000000000 -0500
+++ Sources/splash.c	2016-06-02 11:51:18.729542259 -0400
@@ -9,7 +9,7 @@
 #include "splash.h"
-#include "error.h"
+#include "Error.h"
 #define BYTES_PER_PIXEL     3
diff -u Sources.orig/splash.h Sources/splash.h
--- Sources.orig/splash.h	2016-03-02 03:32:12.000000000 -0500
+++ Sources/splash.h	2016-06-02 11:36:06.139914626 -0400
@@ -10,8 +10,8 @@
  * This module provides the splash image related functions
 #ifdef __cplusplus
 extern "C" {
diff -u Sources.orig/usb.h Sources/usb.h
--- Sources.orig/usb.h	2016-03-02 03:32:12.000000000 -0500
+++ Sources/usb.h	2016-06-02 11:35:07.955640415 -0400
@@ -9,7 +9,7 @@
 #ifndef USB_H
 #define USB_H
 #ifdef __cplusplus
 extern "C" {
