DLP6500: Direct Solder?
Other Parts Discussed in Thread: DLP6500FYE
We are considering to solder the dlp6500fye directly to a PCB without using a socket(2511569 type), as recommended.
Could this pose a problem? In the TI website we found a PCB foot print only for the socket and not for the dlp6500fye, which is why we are hesitant.
On the other hand – Is the socket mandatory?
I will be out of office for most of the remaining August, so please be sure to copy Zvi Biener, our electrionic engineer.
He is here copied, but for some readon I could only add him as bcc. His email is zvi.biener@elbitsystems.com.
Thank you for your help, and best regards,
Yuval
  • Hi Yuval,
    Soldering the DLP6500FYE to a board would most likely violate the maximum non-operational temperature and or temperature delta limits as specified in the datasheet, hence which is why the socket is always used.
