1-1SA4A01
I received the ordered DLP LightCrafter Display 2000 Evaluation Module with an order number of 1684521.
It wont work after I opened it, LED D2 was flashing with green, and LED D3 didn't function, the pins and board got heated. I don't know what happened and if this EVM is replaceable, thanks.
  • ianyangto,
    Thanks for your interest in our DLP products.
    Did you by chance use the incorrect power supply with your system? It expects a 5V-3A supply. Using the incorrect supply can damage the board. We do have a warranty policy, so I believe you can replace the board if it is not working. I recommend you contact customer support in this case.
    Philippe Dollo
  • Dear Philippe,
    Thank you very much for your valued reply.
    I didn't notice the power supply that I maybe make a wrong one, it's maybe the reason that the board doesn't function, I think it need replace, thanks.
