DLPDLCR2000EVM: spare parts
Part Number: DLPDLCR2000EVM
I was checking to see if I can remove the front lens from the EVM and the edge of the lens just before the pico chipped off. Is there any way to buy a spare part from this?
Since I never managed to remove the front lens, is there a way to remove it? As I see its pretty integrated.
  • Hi Gergely,
    The Optical engine used in DLPDLCR2000 EVM is designed as one compact unit and not for replacing parts.
    Could you please share with us your application and requirement? We will try explore the best way to support you.
    regards,
    Vivek
  • Hi Vivek,
    I wanted to remove the front lens as I assume that enlarges the picture and I need the picture to be roughly 2mmx2mm eventually .
    Naturally I will use some lenses to converge the picture, but I figured the smaller one starts from the better.
    If its not possible to remove that lens, that not a very big issue, however as I damanged the other lens that is located just after the pico unit, I was hoping that I can purchase a replacement. I have since bought another EVM, but it would be a shame if the whole EVM became useless, because I chipped a small piece of that lens.
    That being said, I completely understand if you do not sell spare parts!
    Gergely
  • Hi Gergely,
    These optical engines are sourced from a third party and we do carry spare parts.
    The board and flex cable from EVM you may be able to as replacement for future.
    regards,
    Vivek
