DLPC3478: Different img file with bin file
Part Number: DLPC3478
I have firmware(img file) from ti, but recently I use a new programmer which only support bin file or hex file to program, how can I program it with new programmer? Or is there a tool to convert to bin or hex format file?
  • Hi liqing,
    Most flash programmer software support .img files as they are functionally similar to binary (.bin) files. Can you mention the name of the software you're using to program flash?
    I'll also check whether the DLPC3478 supports reading a .bin file from flash. If the binary data and endianness remain the same, I expect it should not be a problem, nevertheless let me confirm it.
    Azad
