Coupling in IR light into dmd
I am trying to illuminate the DMD chip with NIR light from a fiber source in my own lab, and then collect the reflection via optics from my lab.  I am thinking that the best way to do this would be to simply disconnect the DMD board (with the chip) from all the optics (including the core-optics module) and connect it to only the controller board to receive signals from the comp.  I was then planning on shining a collimated beam of light (from my own source) on the DMD and using the reflection.  I know that the controller board has many inputs.  Would it still work ok if I don't connect it to anything except the DMD (and its power supply) ?  Also, would you have any suggestions for better ways to do this?  I am a bit hesitant to take the DMD off the core optics module and am not sure if that is the smartest (or possible) way ...
