Max refresh rate?
What is the maximum refresh rate of the DLP 4000 .55 XGA DMD?
  • Hello Umer,
    The 0.55XGA Discovery 4000 kit is able to support double clock rate up to 320MHz. This translates to approximately 26K frames per second. The data sheet shows how to calculate the time to load 1 block. There are 16 blocks on the 0.55XGA DMD. By using phased block reset, you may stagger the reset of a few blocks at a time to maximize the speed of a full frame.
