Part Number: DLPLCR4500EVM
Other Parts Discussed in Thread: TIDA-00293,
I have disassembled the light engine to access and replace the blue LED with an UV LED as directed in the TIDA-00293 reference design. However, I discovered to my dismay that the LightCrafter had undergone a revision and the circuit board design (Philips Violet LED board.pcb) provided as part of the modification files appears to be incompatible.
Where can I obtain the design files for the current version of the blue LED board so that I can modify it to support the smaller UV LED package?
The blue LED board is marked:
610-0017-01
P1 B Cu MCPCB V1.1
Thank you,
Alex
