Other Parts Discussed in Thread: DLP4500NIR
Dear all,
We are done with upgrading our DLP version 1.0 to version 2.0 by following the suggested procedure. Then, we tried to do measurement to compare the spectra of sample using both DLP NIRscan. DLP 1 refer to the DLP that we upgraded from version 1.0 to 2.0 whereas DLP 2 refer to the DLP that comes with version 2.0 from TI.
We used palm oil as the sample and observed that the pattern of spectra is likely to be same but the recorded wavelengths are different.
We also found out that for DLP 1, the absorbance value is higher compared to DLP 2 (as attached below). I would like to seek your kind advice regarding the calibration for our DLP NIR scan as we are struggeling in getting similar result for DLP1 (reproducibility problem).
I already share this problem in TI e2e community >> https://e2e.ti.com/support/dlp__mems_micro-electro-mechanical_systems/f/983/t/458723
Really appreciate your kind response and advice.
