[C5515EVM] Unexpected power on USB_CPU_3V3_USB line during RTC-only mode
Guru 24520 points
Hi TI Experts,
Please let me confirm the following question.
[Question]
When C5515 enters the RTC-only mode, there was 0.5V on CPU_3V3_USB line even though the JP19 is not shorted if the 1.3V domains for USB were provided by USB_LDO.  Also when c5515 enters the RTC-olny mode, there was approximately 1.0V on CPU_3V3_USB line even though the JP19 is not shorted in case that the 1.3V domains for USB were provided by external LDO(1.3V). Would you please teach me the reason why this phenomenon is happened?
It seems that there is leakage from the  1.3V USB domain to the 3.3V USB domain in internal pass.
If you have any questions, please let me know.
Best regards.
Kaka
  • Hi kaka-san,
    Will get back to you on this, I was looking at your other thread on leakage current with respect to SPI_TX pin.
     Vasanth
  • Hi Vasanth,
    Thank you for your kindly supports. I am waiting for your feedback now.
    Best regards.
    Kaka
  • Hi Kaka-san,
    Could you let us know what is the status of VBUS, is this ON or OFF ?
    Vasanth
  • Hi Vasanth,
    The VBUS status was OFF. There was not any connection for USB bus on C5515EVM.
    Just in case, I summarized the procedure for this evaluation as below.
    1. Put the RTC-only mode program to SD card and it inserts EVM.
    2. Change the jumper of JP15 from 1-2 to 2-3.
    3. Removed the jumper of JP15
    4. Measure the voltage on USB 3.3V domain.
    Best regards.
    Kaka
  • Hi Vasanth,
    Thank you always for taking your time for my requests.
    Can you reproduce this phenomenon?
    I need to update for this topic to my customer.
    Best regards.
    Kaka
  • Hi Kaka-san,
    This is what we have observed in the past,  from VBUS to 3.3V there is a weak path through weak resistors. Hence if 3.3V is down an VBUS is up, there is a residual voltage on 3.3V supply. But for the scenario you had mentioned (where VBUS is completely OFF ),  I need to discussed this further with USB expert and unfortunately he is out of office and would take some more time.
    Meanwhile If I need anymore details I will get back to you.
     Vasanth
  • Hi Vasanth,
    Thank you for your update.
    Just in case, I summarized my observation for this phenomenon. Please check out this.
    C5535_Result.pdf
    If you will get more information please let me know.
    Best regards.
    Kaka
  • Hi Kaka-san,
      Thanks for the details.
      Is it also possible to share your code, you could share code it to my TI email ID. This will help in replicating the issue.
     Vasanth
  • Hi Vasanth,
    Yes, I can share my code.  But I do not know your TI Email ID....
    I attached this code to this post.Wakeup_interrupt.zip
    Best regards.
    Kaka
  • Hi Vasanth,
    Would you please teach me your status for this topics?
    Could you reproduce this phenomenon?
    Best regards.
    Kaka
  • Hi Kaka-san,
    I am trying to reproduce the issue, but I do have few more questions.
    1. Is this issue reproduced in any other hardware platform like customer board etc ?
    2. In C5535 result.pdf you had mentioned in point #4
              -> Not supplied for USB_3.3V line
        I believe you meant JP19 is my understanding correct ?
    Could you Pl let me know on the above.
    Vasanth
  • Hi Vasanth,
    Thank you for your updates. I answered for your questions.
    1.Is this issue reproduced in any other hardware platform like customer board etc ?
    [Kaka]
    Yes. We have two C5515 EVMs and we could reproduce this issue with both boards.
    In addition to this , my customer board (It used the C5535) also confirmed this phenomenon.
    [Kaka]
    Yes. That's correct. JP15 is typo. I apologize for your confusion.
    If you have any more questions, please let me know.
    Best regards.
    Kaka
  • Hi Kaka-san,
    Thanks for confirming my questions.
    I tried to reproduce the issue on two different platform.
    1. C5515 EVM
    2. Power board platform (TI internal H/W platform this will not have peripherals connected and used for power testing/measurements).
    Here are my observation when verified with these two H/W platforms.
    • When tested on power board, I did not observe any residual voltage on USB 3.3 and 1.3V supply rails (when they were OFF). The voltage measured on these supply rails were close to zero volts.
    • On C5515 EVM I did see the residual voltage, although measured voltages were not similar when compared against your data.
    I do have few more questions based on the above tests.
     1. How different is customer board when compared to C5515 EVM (Specifically looking at USB )?
     2. Once the power was switched OFF to USB, how much time you allowed before measuring ?
    Vasanth
  • Hi Vasanth,
    Thank you for your confirming. Please let me confirm about your test result.
    To summary your result :
    [Issue.1]
    There is leakage voltage on USB 3.3V line during RTC-only mode.
    Summary the power domains as below.
    [Power domain condition]
    LDOI, DCDDRTC: 3.3V
    DPS_LDO: OFF
    --> CVDD:OFF
    CVDDRTC: 1.3V
    ANA_LDO: OFF
    --> VDDA_PLL, VDDA_ANA: OFF
    USB_LDOO: OFF
    --> USB_VDDA1P3, USB_VDDA1P3: OFF
    DVDDIO. USB_VDDOSC, USB_VDDPLL, USB_VDDA3P3, VBUS: OFF
    [Issue.2]
    If supply the USB 1.3V during RTC-only mode, the leak voltage will increase compared to USB1.3V line is off.
    LDOI, DCDDRTC: 3.3V
    DPS_LDO: OFF
    --> CVDD:OFF
    ANA_LDO: OFF
    USB_LDOO: OFF
    Exrernal 1.3V On
    - -> USB_VDDA1P3, USB_VDDA1P3, CVDDRTC
    [Result]
    1. You did not observe those issues when you used the your power board platform.
    2. You can observe those issues when you used the C5515EVM. But there are some differences between your result and my result.
    Is my understanding correct? If possible, would you please share the waveform which you observed?
    Also I answer your question as below.
    [Kaka]
    My customer used the LDO (Parts number: S-1333, It is supports Discharge shunt function) for USB 3.3V line.
    datasheet.sii-ic.com/.../S1333_E.pdf
    So, this line will be off(0V, this line will connect to GND) during RTC-only mode by enable pin of LDO. And if the USB1.3V line will not remove while RTC-only mode, there is leakage on USB 3.3V line and it short to GND by LDO. This is difference between customer board and EVM. Also you can make the similar situation by shorting the USB 3.3V pin(of C5515) to GND.
    [Kaka]
    I apologize that I could not understand your question. Would you please explain about your question in detail?
    Best regards
    Kaka
  • Hi Kaka-san,
    Below is my response:
    [Result]
    Vasanth :  Yes that's correct on Issue 1.
    [Kaka]
    Vasanth :  I would try to create similar scenario and get back with results.
    [Kaka]
    Vasanth:  I was suggesting you to wait for some time, before you measure the voltage (residual voltage) on USB 3.3 and 1.3 supply rails, this is to ensure no discharge  being observed on these rails.
     Vasanth
  • Hi Kaka-san,
    With Issue 1, I am not seeing any leakage on both USB supplies on power board.
    I will re-verify on the Issue 2 you had  mentioned and get back to you .But with respect to this scenario there exists is a direct path between USB1.3v and USB3.3v through few transistors. Hence when USB 1.3V supply is up and USB 3.3V supply is off then these transistors will be ON and leak into 3.3V supply. I wll reconfirm on this.
     Vasanth
  • Hi Vasanth,
    Please let me confirm your comments just in case.
    [Kaka]
    Did you mean that if it will take some time from RTC-only mode, the leak/residual voltage will be discharge?
    In my observation, the residual (Leak) voltage will be not discharge even though it will take some time from RTC-only mode.
    Also I do not know why there is a difference for observation between your power board and EVM.
    Is there anything that comes to your mind in regards to that?
    For issue1, I could confirm that there is 0.3V on USB3.3V line when the USB3.3V did not supply during Active state.
    i.e.
    1. Remove the JP19
    2. Power on the EVM
    3. Measure the voltage on USB3.3V line.
    -> You will observe 0.3V on USB3.3V line.
    For issue2, I also reproduce this without entering RTC-only mode.
    1. Remove the JP19
    2. Change the short pin of JP15 from 1-2 to 2-3
    3. Power on the EVM
    4. Measure the voltage on USB3.3V line.
    -> You will observe 0.7V on USB3.3V line.
    Best regards.
    Kaka
  • Hi Kaka-san,
    Below is my response with respect to power board tests (marked in brown):
    i.e.
    1. Remove the JP19
    2. Power on the EVM
    Vasanth: I see around 0.25V when power both supplies are off, but eventually after a minute or so will reduces to almost 0V.
    1. Remove the JP19
    3. Power on the EVM
    Vasanth: My observation are similar with respect to this case  (on power board).
     Vasanth
  • Hi Vasanth,
    My customer situation is issue 2.
    So, if the USB3.3V line is short to GND by LDO discharge function, there are some leak current on this line. My customer believed the following comment on datasheet page 104.
    > 2. All of the device power domains can be shut down except RTC Core (CVDDRTC), RTC I/O (DVDDRTC), and LDO inputs (LDOI).
    Would you please explain the reason why there is 0.7V on USB 3.3V line?
    We need to explain this to my customer...
    Best regards.
    kaka
  • Hi Kaka-san,
    With respect to issue 2, where USB 1.3V is on ON and USB 3.3V is OFF, there exists a direct path between USB 1.3V  and USB 3.3V domain, through few transistor logic. Hence if USB 1.3V is up and USB 3.3V is down, then these transistors will turn ON and will leak into 3.3V supply. This is the reason for you to see ~0.7V on USB 3.3V supply even though this supply is OFF”
    Pl let me know if you have additional questions .
     Vasanth
  • Hi Vasanth,
    I will inform this to my customer. If I get more questions from my customer, please let me confirm them.
    Do you have a plan to add this information to datasheet as caution?
    Best regards.
    Kaka
