I see a problem with McBSP. I configure the timeslots for Tx and Rx directions. Once EDMA begins, after some random time like a few minutes, I see that MCBSP places Tx data on wrong timeslot. It shifts so suddenly. Not clear what is the reason.
On power-on the timeslots are proper both in Rx and Tx data pins. However after sometime, I see the data written on the Tx slot gets shifted in its timeslot position w.r.to the Frame Sync. Note I enabled the Frame Sync Detect bit in MCBSP registers.
* mcbspMasterDigLpbk.c
* This file contains the test / demo code to demonstrate the McBSP driver
* master functionality using Digital Loopback setup. The file configures
* the EVM in master mode.
* Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* INCLUDE FILES */
#include <xdc/std.h>
#include <xdc/runtime/System.h>
#include <xdc/runtime/Log.h>
#include <xdc/cfg/global.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Swi.h>
#include <ti/sysbios/knl/Semaphore.h>
#include <ti/sysbios/knl/task.h>
#include <string.h>
#include <ti/sysbios/knl/Queue.h>
/* Include EDMA3 Driver */
#include <ti/sdo/edma3/drv/edma3_drv.h>
/* CSL Chip Functional Layer */
#include <ti/csl/csl_chip.h>
/* CSL Cache Functional Layer */
#include <ti/csl/csl_cacheAux.h>
/* CSL CPINTC Include Files. */
#include<ti/csl/csl_cpIntc.h>
/* MCBSP Driver Include File. */
#include <ti/drv/mcbsp/mcbsp_drv.h>
#include <ti/drv/mcbsp/mcbsp_osal.h>
/* PlatformLib Include File */
#include <ti/platform/platform.h>
#include "platform_internal.h"
/* EXTERNAL FUNCTIONS */
extern EDMA3_DRV_Handle edma3init(unsigned int edma3Id, EDMA3_DRV_Result *);
extern void McbspDevice_init(void);
extern int32_t Osal_dataBufferInitMemory(uint32_t dataBufferSize);
/* FPGA Configuration Misc-1 Register offset */
#define MCBSP_FPGA_MISC_REG_OFFSET (0x0C)
/* MACRO DEFINTIONS */
#include "baker_mcbsp.h"
#if 0
#define NUM_BUFS 2 /* Max of 2 outstanding requests */
#define NUM_OF_CHANNELS 2 /* Number of slots to be used */
#define BUFSIZE (80*NUM_OF_CHANNELS) /* 1K of data transceive */
#define NUM_OF_CHANNELS_IN_FRAME 16 /* Number of slots to be used */
#endif
/* Defines the core number responsible for system initialization. */
#define CORE_SYS_INIT 0
/* GLOBAL VARIABLES */
/* Shared Memory Variable to ensure synchronizing MCBSP initialization
* with all the other cores. */
/* Created an array to pad the cache line with MCBSP_CACHE_LENGTH size */
#pragma DATA_ALIGN (isMCBSPInitialized, MCBSP_MAX_CACHE_ALIGN)
#pragma DATA_SECTION (isMCBSPInitialized, ".mcbspSharedMem");
volatile Uint32 isMCBSPInitialized[(MCBSP_CACHE_LENGTH / sizeof(Uint32))] = { 0 };
/* Handle to the EDMA driver instance */
#pragma DATA_ALIGN (hEdma, MCBSP_MAX_CACHE_ALIGN)
EDMA3_DRV_Handle hEdma[(MCBSP_CACHE_LENGTH / sizeof(EDMA3_DRV_Handle))] = { NULL };
/* Handle to MCBSP driver instance */
typedef void* Mcbsp_DevHandle;
Mcbsp_DevHandle hMcbspDev;
/* Handle to MCBSP driver channel instance */
typedef void* Mcbsp_ChanHandle;
Mcbsp_ChanHandle hMcbspTxChan;
Mcbsp_ChanHandle hMcbspRxChan;
/* Core Number Identifier */
UInt32 coreNum = 0xFFFF;
/* Array to hold the pointer to the allocated buffers */
void* bufRx[NUM_BUFS];
void* bufTx[NUM_BUFS];
#pragma DATA_ALIGN (mcbspBufRx0, MCBSP_MAX_CACHE_ALIGN)
uint8_t mcbspBufRx0[2*BUFSIZE]={0};
#pragma DATA_ALIGN (mcbspBufTx0, MCBSP_MAX_CACHE_ALIGN)
uint8_t mcbspBufTx0[2*BUFSIZE]={0};
#pragma DATA_ALIGN (mcbspBufRx1, MCBSP_MAX_CACHE_ALIGN)
uint8_t mcbspBufRx1[2*BUFSIZE]={0};
#pragma DATA_ALIGN (mcbspBufTx1, MCBSP_MAX_CACHE_ALIGN)
uint8_t mcbspBufTx1[2*BUFSIZE]={0};
Mcbsp_IOBuf txFrame[NUM_BUFS], rxFrame[NUM_BUFS];
/* Variables to indicate status of EDMA TX and RX requests */
volatile uint32_t edmaTxDone = 0;
volatile uint32_t edmaRxDone = 0;
volatile uint32_t edmaTxCountDone=0;
volatile uint32_t edmaRxCountDone=0;
* \brief Mcbsp Sample rate generator default parameters.
Mcbsp_srgConfig mcbspSrgCfg =
FALSE, // FALSE, /* No gsync to be used as input is not CLKS */
Mcbsp_ClkSPol_RISING_EDGE, /* Dont care as input clock is not clks */
Mcbsp_SrgClk_CLKCPU, //Mcbsp_SrgClk_CLKS, //Mcbsp_SrgClk_CLKCPU, /* McBSP internal clock to be used */
166666667, /* Mcbsp internal clock frequency(PLL-SYSCLK6) */
0 /* frame sync pulse width (val+1) is used */
* \brief Mcbsp device creation default parameters.
const Mcbsp_Params Mcbsp_PARAMS =
Mcbsp_DevMode_McBSP, /* Use the device as MCBSP */
Mcbsp_OpMode_DMAINTERRUPT, /* Use DMA mode of operation */
TRUE, /* cache coherency taken care of by driver */
Mcbsp_EmuMode_FREE, //Mcbsp_EmuMode_SOFT_STOP, /* Soft mode is to be enabled */
Mcbsp_Loopback_DISABLE, /* Loop back mode disabled */
&mcbspSrgCfg, /* sample rate generator configuration */
NULL, /* TX pending buffer queue from application */
NULL, /* TX floating buffer queue in DMA */
NULL, /* RX pending buffer queue from application */
NULL /* RX floating buffer queue in DMA */
#pragma DATA_ALIGN(loopJob, MCBSP_MAX_CACHE_ALIGN)
static Int32 loopJob[16] = {
0, 0, 0, 0, 0, 0, 0, 0,
/**< settings to configure the TX or RX hardware sections */
Mcbsp_DataConfig mcbspChanConfig =
Mcbsp_Phase_SINGLE,
Mcbsp_WordLength_32,
Mcbsp_WordLength_32, /* Dont care for single phase*/
NUM_OF_CHANNELS_IN_FRAME,
0, // Only using single phase, hence num channels is 0
Mcbsp_FrmSync_DETECT,
Mcbsp_DataDelay_0_BIT, //Mcbsp_DataDelay_1_BIT,
Mcbsp_Compand_OFF_MSB_FIRST,
Mcbsp_BitReversal_DISABLE,
Mcbsp_IntMode_ON_SYNCERR,
Mcbsp_RxJust_RZF, //Mcbsp_RxJust_RSE, //Mcbsp_RxJust_RZF, /* Dont care for TX */
Mcbsp_DxEna_ON, //Mcbsp_DxEna_ON
/**< clock setup for the TX section */
Mcbsp_ClkSetup mcbspClkConfigTx =
Mcbsp_FsClkMode_EXTERNAL, //Mcbsp_FsClkMode_INTERNAL,//Mcbsp_FsClkMode_EXTERNAL,
8000, /* 96KHz */
Mcbsp_TxRxClkMode_EXTERNAL, //Mcbsp_TxRxClkMode_INTERNAL,//Mcbsp_TxRxClkMode_EXTERNAL,
Mcbsp_FsPol_ACTIVE_HIGH,
Mcbsp_ClkPol_RISING_EDGE
/**< clock setup for the RX section */
Mcbsp_ClkSetup mcbspClkConfigRx =
Mcbsp_FsClkMode_EXTERNAL, //Mcbsp_FsClkMode_INTERNAL, //Mcbsp_FsClkMode_EXTERNAL,
8000, /* 96KHz */
Mcbsp_TxRxClkMode_EXTERNAL, //Mcbsp_TxRxClkMode_INTERNAL, //Mcbsp_TxRxClkMode_EXTERNAL, //Mcbsp_TxRxClkMode_EXTERNAL,
Mcbsp_ClkPol_FALLING_EDGE
/**< Multi channel setup */
Mcbsp_McrSetup mcbspMultiChanCtrl =
Mcbsp_McmMode_ALL_CHAN_ENABLED_UNMASKED, //Mcbsp_McmMode_ALL_CHAN_DISABLED_UNMASKED, //Mcbsp_McmMode_ALL_CHAN_ENABLED_UNMASKED,
Mcbsp_PartitionMode_CHAN_0_15,
Mcbsp_PartitionMode_CHAN_16_31,
Mcbsp_PartitionMode_2
Mcbsp_ChanParams mcbspChanparamTx =
Mcbsp_WordLength_32, /* wordlength configured */
&loopJob[0], /* loop job buffer internal */
8, /* user loopjob length */
NULL, /* global error callback */
NULL, /* edma Handle */
1, /* EDMA event queue */
8, /* hwi number */
Mcbsp_BufferFormat_MULTISLOT_NON_INTERLEAVED,
TRUE, /* FIFO mode enabled */
&mcbspChanConfig, /* channel configuration */
&mcbspClkConfigTx, /* clock configuration */
&mcbspMultiChanCtrl, /* multi channel control */
0x0000000a,
0x00,
0x00,
0x00
Mcbsp_ChanParams mcbspChanparamRx =
2, /* EDMA event queue */
8, /* hwi number */
&mcbspClkConfigRx, /* clock configuration */
0x0000000a,
0x00,
0x00,
0x00
/* FUNCTION DEFINITIONS */
* This is the application's callback function. The driver will
* call this function whenever an EDMA I/O operation is over.
unsigned char toggleledvaluegpio14, toggleledvaluegpio15;
int mcbspAppCallbackCnt = 0;
volatile uint32_t edmaMcbspTxCount=0;
volatile uint32_t edmaMcbspRxCount=0;
volatile uint32_t edmaMcbspTxRxCnt=0;
volatile uint32_t edmaMcbspTxRxPeriod=0, edmaMcbspErrCount= 0, edmaMcbspTxCountfree=0, edmaMcbspRxCountfree=0;
int32_t mcbspmoderecived = 0;
void mcbspAppCallbackTx(void* arg, Mcbsp_IOBuf *ioBuf)
int32_t mode;
int32_t *pmode = (int32_t *)arg;
mcbspAppCallbackCnt++;
mode = *pmode;
if (mode == MCBSP_MODE_OUTPUT)
edmaMcbspTxCount++;
Semaphore_post(semMcbspTx);
edmaMcbspTxCountfree++;
else
edmaMcbspErrCount++;
mcbspmoderecived= mode;
return;
void mcbspAppCallbackRx(void* arg, Mcbsp_IOBuf *ioBuf)
int32_t mode;
mode = *pmode;
if (mode == MCBSP_MODE_INPUT)
edmaMcbspRxCount++;
Semaphore_post(semMcbspRx);
edmaMcbspRxCountfree++;
#if 0
edmaMcbspTxRxPeriod++;
clk5msfun_swipost040();
swipost040();
#if 1
if ((edmaMcbspTxRxPeriod & 0x1) == 0)
swipost080();
if ((edmaMcbspTxRxPeriod & 0x3) == 0)
swipost160();
if ((edmaMcbspTxRxPeriod == 6) || (edmaMcbspTxRxPeriod == 12))
swipost240();
#endif
if (edmaMcbspTxRxPeriod == 12)
edmaMcbspTxRxPeriod=0;
#endif
else
return;
void testMcBSPLoop(void);
* \brief This function demostrates the use of Mcbsp using digital loopback
* communication setup.
* \param None
* \return None
int mcbspInitDone = 0;
int rxStartCnt = 0;
int txStartCnt = 0;
//void mcbspTxLoop(UArg arg0, UArg arg1);
//void mcbspRxLoop(UArg arg0, UArg arg1);
uint32_t mcbspTxDone = 0, mcbspRxDone = 0;
int edmaSuccessCnt=0, edmaErrorCnt=0;
int edmaDebug=0;
int mcbspRxBufEdmaIndex = 1;
int mcbspTxBufEdmaIndex = 0;
int maxSubmitcnt = 2;
int sendMcbspRxTxCnt = 0;
#pragma DATA_ALIGN (loopbuf, MCBSP_MAX_CACHE_ALIGN)
uint8_t loopbuf[NUM_OF_CHANNELS] [CHAN_BUFSIZE]= {0};
int debugMcbspIssue = 0;
#pragma DATA_ALIGN (loopbuf_rx, MCBSP_MAX_CACHE_ALIGN)
int16_t loopbuf_rx[NUM_OF_CHANNELS] [NUM_OF_FRAMES]= {0};
#pragma DATA_ALIGN (loopbuf_tx, MCBSP_MAX_CACHE_ALIGN)
int16_t loopbuf_tx[NUM_OF_CHANNELS] [NUM_OF_FRAMES]= {0};
void mcbspChanBuf(int bufchan, int edmachan, int Index, int chansizeinbytes, int writesel)
int32_t *ptr_32;
int16_t *ptr_16;
int len, i;
int temp = (int) SLOT_WORD_WIDTH_IN_BYTES;
len = chansizeinbytes >> 2;
if (writesel)
ptr_16 = (int16_t *) &loopbuf_rx[bufchan][0]; // loopbuf_tx
ptr_32 = (int32_t *)(((uint8_t *)bufTx[Index])+ (edmachan*chansizeinbytes));
for (i = 0; i < len; i++)
*ptr_32++ = (int32_t) *ptr_16++;
else
ptr_32 = (int32_t *)(((uint8_t *)bufRx[Index])+ (edmachan*chansizeinbytes));
*ptr_16++ = (int16_t) *ptr_32++;
void bakerMcbspTask(UArg arg0, UArg arg1)
/**< Mcbsp device params */
Mcbsp_Params mcbspParams;
/**< Mcbsp sample rate configuration parameters */
Mcbsp_srgConfig mcbspSrgParams;
/**< Queue to hold the pending packets received from the application */
Queue_Struct txQueuePendingList, rxQueuePendingList;
/**< Queue to manage floating packets in DMA */
Queue_Struct txQueueFloatingList, rxQueueFloatingList;
uint32_t count = 0, tempCount = 0;
int32_t status = 0, retval = 0, i;
int32_t txChanMode = MCBSP_MODE_OUTPUT;
int32_t rxChanMode = MCBSP_MODE_INPUT;
uint8_t *ptr;
int result=FALSE;
while(mcbspInitDone == 0)
Task_sleep(1);
mcbspInitDone++;
/* Initialize the OSAL */
if (Osal_dataBufferInitMemory(BUFSIZE) < 0)
Log_info1 ("Debug(Core %d): Error: Unable to initialize the OSAL. \n", coreNum);
return;
/* update EDMA3 handle to channel parameters */
mcbspChanparamTx.edmaHandle = hEdma[0];
mcbspChanparamRx.edmaHandle = hEdma[0];
/* create the pending and floating queue for the TX channel */
Queue_construct(&txQueuePendingList, NULL);
Queue_construct(&txQueueFloatingList, NULL);
/* create the pending and floating queue for the RX channel */
Queue_construct(&rxQueuePendingList, NULL);
Queue_construct(&rxQueueFloatingList, NULL);
/* configure the SRG properties */
/* use Mcbsp intenal clock */
//mcbspSrgParams.srgInputClkMode = Mcbsp_SrgClk_CLKCPU;
/* 1 bit width framesync */
//mcbspSrgParams.srgFrmPulseWidth = 0;
/* internal clock frequncy */
//mcbspSrgParams.srgrInputFreq = 166666667; /* 166.67 MHz - SYSCLK6 */
mcbspParams = Mcbsp_PARAMS;
//mcbspParams.mode = Mcbsp_DevMode_McBSP;
//mcbspParams.opMode = Mcbsp_OpMode_DMAINTERRUPT;
//mcbspParams.enablecache = TRUE;
//mcbspParams.emulationMode = Mcbsp_EmuMode_FREE;
//mcbspParams.dlbMode = Mcbsp_Loopback_ENABLE;//Mcbsp_Loopback_DISABLE;
mcbspParams.srgSetup = &mcbspSrgParams;
mcbspParams.txQPendingList = &txQueuePendingList;
mcbspParams.txQFloatingList = &txQueueFloatingList;
mcbspParams.rxQPendingList = &rxQueuePendingList;
mcbspParams.rxQFloatingList = &rxQueueFloatingList;
/* Bind the driver instance with device instance */
status = mcbspBindDev(&hMcbspDev, coreNum, &mcbspParams);
if (status != MCBSP_STATUS_COMPLETED)
Log_info1 ("Debug(Core %d): MCBSP LLD Bind Device Failed\n", coreNum);
return;
/* Create a RX channel for receiving */
status = mcbspCreateChan(&hMcbspRxChan, hMcbspDev, MCBSP_MODE_INPUT, &mcbspChanparamRx, mcbspAppCallbackRx, &rxChanMode);
if (MCBSP_STATUS_COMPLETED != status)
Log_info1 ("Debug(Core %d): Error: Create Channel (RX) failed\n", coreNum);
return;
/* Create a TX channel for the transmission */
status = mcbspCreateChan(&hMcbspTxChan, hMcbspDev, MCBSP_MODE_OUTPUT, &mcbspChanparamTx, mcbspAppCallbackTx, &txChanMode);
Log_info1 ("Debug(Core %d): Error: Create Channel (TX) failed\n", coreNum);
return;
/* create the buffers required for the TX and RX operations */
for (count = 0; count < (NUM_BUFS); count++)
bufTx[count] = (uint8_t *)Osal_mcbspDataBufferMalloc(BUFSIZE);
bufRx[count] = (uint8_t *)Osal_mcbspDataBufferMalloc(BUFSIZE);
if (bufTx[count] == NULL)
Log_info2 ("Debug(Core %d): Error: Tx Buffer (%d) Memory Allocation Failed\n", coreNum, count);
return;
if (bufRx[count] == NULL)
Log_info2 ("Debug(Core %d): Error: Rx Buffer (%d) Memory Allocation Failed\n", coreNum, count);
return;
/* Fill the buffers with known data and transmit the same and
check if the same pattern is received */
memset((uint8_t *)bufTx[count], 0, BUFSIZE);
for (i=0; i < maxSubmitcnt; i++)
mcbspRxBufEdmaIndex = (mcbspRxBufEdmaIndex +1)%NUM_BUFS;
memset((uint8_t *)bufRx[mcbspRxBufEdmaIndex], 0, BUFSIZE);
/* RX frame processing */
rxFrame[mcbspRxBufEdmaIndex].cmd = Mcbsp_IOBuf_Cmd_READ;
rxFrame[mcbspRxBufEdmaIndex].addr = (void*)bufRx[mcbspRxBufEdmaIndex];
rxFrame[mcbspRxBufEdmaIndex].size = BUFSIZE;
rxFrame[mcbspRxBufEdmaIndex].arg = (uint32_t) hMcbspRxChan;
rxFrame[mcbspRxBufEdmaIndex].status = MCBSP_STATUS_COMPLETED;
rxFrame[mcbspRxBufEdmaIndex].misc = 1; /* reserved - used in callback to indicate asynch packet */
status = mcbspSubmitChan(hMcbspRxChan, (void *)&rxFrame[mcbspRxBufEdmaIndex]);
rxStartCnt++;
if (status != MCBSP_STATUS_PENDING)
Log_info2 ("Debug(Core %d): Error: RX buffer submission in iteration-%d FAILED\n", coreNum, i);
retval = 1;
else
//Log_info2 ("Debug(Core %d): RX buffer in iteration-%d is submitted to MCBSP driver\n", coreNum, newcount);
} // End of simultaenous submits.
mcbspTxBufEdmaIndex = (mcbspTxBufEdmaIndex +1) % NUM_BUFS;
/* TX frame processing */
txFrame[mcbspTxBufEdmaIndex].cmd = Mcbsp_IOBuf_Cmd_WRITE;
txFrame[mcbspTxBufEdmaIndex].addr = (void*)bufTx[mcbspTxBufEdmaIndex];
txFrame[mcbspTxBufEdmaIndex].size = BUFSIZE;
txFrame[mcbspTxBufEdmaIndex].arg = (uint32_t)hMcbspTxChan;
txFrame[mcbspTxBufEdmaIndex].status = MCBSP_STATUS_COMPLETED;
txFrame[mcbspTxBufEdmaIndex].misc = 1; /* reserved - used in callback to indicate asynch packet */
status = mcbspSubmitChan(hMcbspTxChan, (void *)&txFrame[mcbspTxBufEdmaIndex]);
txStartCnt++;
Log_info2 ("Debug(Core %d): Error: TX frames submission in iteration-%d FAILED\n", coreNum, i);
retval = 1;
else
//Log_info2 ("Debug(Core %d): TX frames in iteration-%d are submitted to MCBSP driver\n", coreNum, newcount);
mcbspInitDone=2;
//Task_sleep(2);
while(1)
/* Wait for TX and RX processing to complete */
result = Semaphore_pend(semMcbspRx, BIOS_WAIT_FOREVER); //5000);
if (result == TRUE) //(edmaMcbspRxCount)
edmaMcbspRxCount--;
mcbspRxBufEdmaIndex = (mcbspRxBufEdmaIndex +1) % NUM_BUFS;
/* Invalidate the Cache Contents */
Mcbsp_osalBeginMemAccess ((void *)bufRx[mcbspRxBufEdmaIndex], BUFSIZE);
mcbspChanBuf(0, 0, mcbspRxBufEdmaIndex, CHAN_BUFSIZE, 0);
mcbspChanBuf(1, 1, mcbspRxBufEdmaIndex, CHAN_BUFSIZE, 0);
//memset((uint8_t *)bufRx[mcbspRxBufEdmaIndex], 0, BUFSIZE);
Mcbsp_osalEndMemAccess ((void *)bufRx[mcbspRxBufEdmaIndex], BUFSIZE);
rxStartCnt++;
Log_info2 ("Debug(Core %d): Error: RX buffer submission in iteration-%d FAILED\n", coreNum, rxStartCnt);
retval = 1;
else
#if 1
toggleledvaluegpio14 = ~toggleledvaluegpio14;
if (toggleledvaluegpio14 & 1)
gpioSetOutput(GPIO_14);
else
gpioClearOutput(GPIO_14);
#endif
} // End of if()
else
while(1);
} // End of Rx While
result = Semaphore_pend(semMcbspTx,BIOS_WAIT_FOREVER); // 5000);
if (/* (edmaMcbspTxCount) && */(result == TRUE))
edmaMcbspTxCount--;
mcbspTxBufEdmaIndex = (mcbspTxBufEdmaIndex +1)% NUM_BUFS;
Mcbsp_osalBeginMemAccess ((void *)bufTx[mcbspTxBufEdmaIndex], BUFSIZE);
mcbspChanBuf(1, 0, mcbspTxBufEdmaIndex, CHAN_BUFSIZE, 1);
mcbspChanBuf(0, 1, mcbspTxBufEdmaIndex, CHAN_BUFSIZE, 1);
if (debugMcbspIssue)
memset((uint8_t *)bufTx[mcbspTxBufEdmaIndex], 0, BUFSIZE);
Mcbsp_osalEndMemAccess ((void *)bufTx[mcbspTxBufEdmaIndex], BUFSIZE);
txStartCnt++;
Log_info2 ("Debug(Core %d): Error: TX frames submission in iteration-%d FAILED\n", coreNum, txStartCnt);
retval = 1;
else
#if 1
toggleledvaluegpio15 = ~toggleledvaluegpio15;
if (toggleledvaluegpio15 & 1)
gpioSetOutput(GPIO_15);
else
gpioClearOutput(GPIO_15);
#endif
#if 1
swipost040();
#if 1
swipost080();
swipost160();
swipost240();
#endif
#endif
} //if (edmaMcbspTxCount)
else
while(1);
} // End of Tx While
} // while(1)
} // End of program
* \brief Void main(Void)
* Main function of the sample application. This function calls the
* function to configure the mcbsp instance.
* \param None
* \return None
Void myStartupFxn(Void)
//BIOS_start();
Void mcbspmain0(Void);
Void main(void)
mcbspmain0();
Void mcbspmain(Void)
Task_Params taskParams;
EDMA3_DRV_Result edmaResult = 0;
uint8_t uchValue;
/* Get the core number. */
coreNum = CSL_chipReadReg (CSL_CHIP_DNUM);
#ifdef SIMULATOR_SUPPORT
#warn MCBSP Digital Loopback example is not supported on SIMULATOR !!!
Log_info0 ("MCBSP Digital Loopback example is not supported on SIMULATOR. Exiting!\n");
return;
#else
Log_info1 ("Debug(Core %d): Running MCBSP Digital Loopback example on the DEVICE\n", coreNum);
#endif
/* Initialize the system only if the core was configured to do so. */
if (coreNum == CORE_SYS_INIT)
Log_info1 ("Debug(Core %d): System Initialization for MCBSP\n", coreNum);
#if 0
/* Drive McBSP_AMC_EN# high. Output SLCLKs, TxCLKs, RxCLKs, FSTs, FSRs as Hi-Z.
* These clocks and syncs are tri-stated and McBSP is accessed over 80-pin header */
if (0 != (platform_fpgaWriteConfigReg(MCBSP_FPGA_MISC_REG_OFFSET, 11)))
Log_info1 ("Debug(Core %d): FPGA McBSP_AMC_EN# register WRITE failed \n", coreNum);
return;
/* DEBUG: Verify if FPGA register is configured correctly */
if (0 != (platform_fpgaReadConfigReg(MCBSP_FPGA_MISC_REG_OFFSET, &uchValue)))
Log_info1 ("Debug(Core %d): FPGA McBSP_AMC_EN# register READ failed \n", coreNum);
return;
if (11 != uchValue)
Log_info1 ("Debug(Core %d): FPGA McBSP_AMC_EN# register setting failed \n", coreNum);
return;
else
Log_info2 ("Debug(Core %d): FPGA McBSP_AMC_EN# register is set to %d \n", coreNum, uchValue);
#endif
/* MCBSP Driver Initialization: This should always be called before
* invoking the MCBSP Driver. */
mcbspInit();
/* Device Specific MCBSP Initializations */
McbspDevice_init();
/* MCBSP Driver is operational at this time. */
Log_info1 ("Debug(Core %d): MCBSP Driver Initialization Done\n", coreNum);
/* Write to the SHARED memory location at this point in time. The other cores cannot execute
* till the MCBSP Driver is up and running. */
isMCBSPInitialized[0] = 1;
/* The MCBSP IP block has been initialized. We need to writeback the cache here because it will
* ensure that the rest of the cores which are waiting for MCBSP to be initialized would now be
* woken up. */
CACHE_wbL1d ((void *) &isMCBSPInitialized[0], MCBSP_MAX_CACHE_ALIGN, CACHE_FENCE_WAIT);
else
/* All other cores need to wait for the MCBSP to be initialized before they proceed with the test. */
Log_info1 ("Debug(Core %d): Waiting for MCBSP to be initialized.\n", coreNum);
/* All other cores loop around forever till the MCBSP is up and running.
* We need to invalidate the cache so that we always read this from the memory. */
while (isMCBSPInitialized[0] == 0)
CACHE_invL1d ((void *) &isMCBSPInitialized[0], MCBSP_MAX_CACHE_ALIGN, CACHE_FENCE_WAIT);
Log_info1 ("Debug(Core %d): MCBSP can now be used.\n", coreNum);
/* Initialize EDMA3 library */
hEdma[0] = edma3init(0, &edmaResult);
if (edmaResult != EDMA3_DRV_SOK)
/* Report EDMA Error */
Log_info1("Debug(Core %d): EDMA Driver Initialization FAILED\n", coreNum);
else
Log_info1("Debug(Core %d): EDMA Driver Initialization Done\n", coreNum);
gpioSetDirection(GPIO_14, GPIO_OUT );
gpioSetDirection(GPIO_15, GPIO_OUT );
mcbspInitDone = 1;
#if 0
/* Create the Digital Loopback Application Task */
Task_Params_init(&taskParams);
taskParams.priority = 5;
Task_create(bakerMcbspInit2, &taskParams, NULL);
#endif
/* Start BIOS */
//BIOS_start();
return;
void evbplatformInit(void)
uint8_t uchValue;
return;
return;
if (11 != uchValue)
return;
else
/* END OF FILE */
