Other Parts Discussed in Thread: SYSBIOS, TDA2
undefined first referenced symbol in file --------- ---------------- EDMA3_DRV_close /opt/ti/VISION_SDK_02_06_00_00/ti_components/drivers/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/sample/lib/tda2xx-evm/66/debug/edma3_lld_drv_sample.ae66<sample_init.oe66> EDMA3_DRV_create /opt/ti/VISION_SDK_02_06_00_00/ti_components/drivers/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/sample/lib/tda2xx-evm/66/debug/edma3_lld_drv_sample.ae66<sample_init.oe66> EDMA3_DRV_delete /opt/ti/VISION_SDK_02_06_00_00/ti_components/drivers/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/sample/lib/tda2xx-evm/66/debug/edma3_lld_drv_sample.ae66<sample_init.oe66> EDMA3_DRV_initXbarEventMap /opt/ti/VISION_SDK_02_06_00_00/ti_components/drivers/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/sample/lib/tda2xx-evm/66/debug/edma3_lld_drv_sample.ae66<sample_tda2xx_int_reg.oe66> EDMA3_DRV_open /opt/ti/VISION_SDK_02_06_00_00/ti_components/drivers/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/sample/lib/tda2xx-evm/66/debug/edma3_lld_drv_sample.ae66<sample_init.oe66> lisrEdma3CCErrHandler0 /opt/ti/VISION_SDK_02_06_00_00/ti_components/drivers/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/sample/lib/tda2xx-evm/66/debug/edma3_lld_drv_sample.ae66<sample_tda2xx_int_reg.oe66> lisrEdma3ComplHandler0 /opt/ti/VISION_SDK_02_06_00_00/ti_components/drivers/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/sample/lib/tda2xx-evm/66/debug/edma3_lld_drv_sample.ae66<sample_tda2xx_int_reg.oe66> lisrEdma3TC0ErrHandler0 /opt/ti/VISION_SDK_02_06_00_00/ti_components/drivers/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/sample/lib/tda2xx-evm/66/debug/edma3_lld_drv_sample.ae66<sample_tda2xx_int_reg.oe66> lisrEdma3TC1ErrHandler0 /opt/ti/VISION_SDK_02_06_00_00/ti_components/drivers/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/sample/lib/tda2xx-evm/66/debug/edma3_lld_drv_sample.ae66<sample_tda2xx_int_reg.oe66> lisrEdma3TC2ErrHandler0 /opt/ti/VISION_SDK_02_06_00_00/ti_components/drivers/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/sample/lib/tda2xx-evm/66/debug/edma3_lld_drv_sample.ae66<sample_tda2xx_int_reg.oe66> lisrEdma3TC3ErrHandler0 /opt/ti/VISION_SDK_02_06_00_00/ti_components/drivers/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/sample/lib/tda2xx-evm/66/debug/edma3_lld_drv_sample.ae66<sample_tda2xx_int_reg.oe66> lisrEdma3TC4ErrHandler0 /opt/ti/VISION_SDK_02_06_00_00/ti_components/drivers/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/sample/lib/tda2xx-evm/66/debug/edma3_lld_drv_sample.ae66<sample_tda2xx_int_reg.oe66> lisrEdma3TC5ErrHandler0 /opt/ti/VISION_SDK_02_06_00_00/ti_components/drivers/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/sample/lib/tda2xx-evm/66/debug/edma3_lld_drv_sample.ae66<sample_tda2xx_int_reg.oe66> lisrEdma3TC6ErrHandler0 /opt/ti/VISION_SDK_02_06_00_00/ti_components/drivers/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/sample/lib/tda2xx-evm/66/debug/edma3_lld_drv_sample.ae66<sample_tda2xx_int_reg.oe66> lisrEdma3TC7ErrHandler0 /opt/ti/VISION_SDK_02_06_00_00/ti_components/drivers/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/sample/lib/tda2xx-evm/66/debug/edma3_lld_drv_sample.ae66<sample_tda2xx_int_reg.oe66> error: unresolved symbols remain error: errors encountered during linking; "app_dsp" not built >> Compilation failure make[3]: *** [src/svs220jr18/video/app_dsp/app_dsp] Error 1 make[3]: Leaving directory `/svsbase/build_jr18_dsp' make[2]: *** [src/svs220jr18/video/app_dsp/CMakeFiles/app_dsp.dir/all] Error 2 make[2]: Leaving directory `/svsbase/build_jr18_dsp' make[1]: *** [src/svs220jr18/video/app_dsp/CMakeFiles/app_dsp.dir/rule] Error 2 make[1]: Leaving directory `/svsbase/build_jr18_dsp' make: *** [app_dsp] Error 2
I am trying to run the example code available in edma3_lld_02_12_00_20 .
This is edma package that I downloaded from below link :
software-dl.ti.com/.../index.html
PFB linker command file (which comes with examples default one)
SECTIONS
.my_sect_iram > L2SRAM
.my_sect_ddr > L2SRAM
I tried to remove maximum liking error but I am unable to solve the linking errors mentioned in attachment .PFA.
I am using CCSv5.4 in windows (64 bit) .
edma3 version :edma3_lld_02_12_00_20
CORE : C6657
EXAMPLE: edma3_drv_bios6_c6657_st_sample
CCS:v5.4
OS:Windows
Error:PFA
DSP:C66X
**** Build of configuration Debug for project edma3_drv_bios6_c6657_st_sample ****
/home/studinstru/Docker/ti/ccsv6/utils/bin/gmake -k all
Building target: edma3_drv_bios6_c6657_st_sample.out
Invoking: C6000 Linker
"/home/studinstru/Docker/ti/ccsv6/tools/compiler/c6000_7.4.13/bin/cl6x" --cmd_file="/home/studinstru/Docker/ti/edma3_lld_02_12_00_20/examples/edma3_driver/simC6657/rtsc_config/Debug/configPkg/compiler.opt" -mv6600 -g --diag_warning=225 --abi=eabi -z -m"edma3_drv_bios6_c6657_st_sample.map" --warn_sections -i"/home/studinstru/Docker/ti/ccsv6/tools/compiler/c6000_7.4.13/lib" -i"/home/studinstru/Docker/ti/ccsv6/tools/compiler/c6000_7.4.13/include" -i"/home/studinstru/Docker/ti/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/lib/66/debug" -i"/home/studinstru/Docker/ti/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/sample/lib/c6657-sim/66/debug" -i"/home/studinstru/Docker/ti/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/rm/lib/c6657-sim/66/debug" -i"/home/studinstru/Docker/ti/ccsv6/tools/compiler/c6000_7.4.13/lib" -i"/home/studinstru/Docker/ti/ccsv6/tools/compiler/c6000_7.4.13/include" -i"/home/studinstru/Docker/ti/bios_6_33_02_31/packages/ti/sysbios/syncs/lib/debug" --reread_libs --xml_link_info="edma3_drv_bios6_c6657_st_sample_linkInfo.xml" --rom_model -l"/home/studinstru/Docker/ti/edma3_lld_02_12_00_20/examples/edma3_driver/simC6657/rtsc_config/Debug/configPkg/linker.cmd" -o "edma3_drv_bios6_c6657_st_sample.out" "./common.obj" "./dma_chain_test.obj" "./dma_link_test.obj" "./dma_misc_test.obj" "./dma_ping_pong_test.obj" "./dma_poll_test.obj" "./dma_test.obj" "./main.obj" "./qdma_link_test.obj" "./qdma_test.obj" "../linker.cmd" -ledma3_lld_drv_sample.ae66 -ledma3_lld_rm.ae66 -ledma3_lld_drv.ae66 -l"libc.a" -lti.sysbios.syncs.ae66e
<Linking>
error: symbols in the reserved far sections cannot be accessed as near; symbol
"numEdma3Instances" in the far section
mple/lib/c6657-sim/66/debug/edma3_lld_drv_sample.ae66<sample_c6657_cfg.oe66>
(.const)" is accessed as near in the section "./main.obj(.text)"
symbol in file
ti_sysbios_knl_Semaphore_create /home/studinstru/Docker/ti/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/sample/lib/c6657-sim/66/debug/edma3_lld_drv_sample.ae66<sample_cs.oe66>
ti_sysbios_knl_Semaphore_delete /home/studinstru/Docker/ti/edma3_lld_02_12_00_20/packages/ti/sdo/edma3/drv/sample/lib/c6657-sim/66/debug/edma3_lld_drv_sample.ae66<sample_cs.oe66>
error: errors encountered during linking; "edma3_drv_bios6_c6657_st_sample.out"
not built
>> Compilation failure
gmake: *** [edma3_drv_bios6_c6657_st_sample.out] Error 1
gmake: Target `all' not remade because of errors.
**** Build Finished ****
