66AK2H06: Problem with QMSS
Part Number: 66AK2H06
Hello Team,
Could you help with our customer's question please.
They cant launch qmss on Linux.
Linux use keystone-uio.dtsi, where:
uio_qmss: qmss {
                                               compatible = "ti,uio-module-drv";
                                               mem  = <0x02a00000 0x00100000
                                                               0x23a00000 0x00200000>;
In k2hk-uio.dtsi file this section is not redefined
In documentation: Documentation/devicetree/bindings/soc/ti/keystone-navigator-qmss.txt
qmss: qmss@2a40000 {
                compatible = "ti,keystone-qmss";
                dma-coherent;
This section is pulled through keystone-k2hk-netcp.dtsi
In documentation on QMSS module in Keystone 2 the base adress 0x02a00000 is changed to 0x02a40000
The question:
Is described above the reason of the following message(when the try to open QMSS transport):
TransportQmss Version : 0x02000001
Version String: Linux IPC Transports Revision: 2.0.0.01:Jan 23 2018:19:13:09
Process 1 : Initialized RM_Client0
Process 1 : Opening RM client socket /var/run/rm/rm_client0
fw_memMap: Failed to find fd to map 0x02a00000.
Process 1 : Creating TransportQmss instance
TransportQmss_create : mpm_transport_open failed
name = "arm-qmss-generic", msg_size_bytes:4096, rm_service_h=0x830f68
ERROR Process 1 : Failed to create TransportQmss handle
Edit: Even after manual change of adresses the /dev/qmss still not appears.
The question 2:
When the /dev/qmss should appear? Which driver should be loaded?
“rmServer.out /usr/bin/device/k2h/global-resource-list.dtb /usr/bin/device/k2h/policy_dsp_arm.dtb” - was launched without errors.
Thank you in advance!
Ilya.
  • Hi, Ilya,
    The address difference is they point to different location of registers. Please refer to the device memory map in the datasheet, and section 5.3 Memory Map of Multicore Navigator User's Guide.
    Are you able to run any of the QMSS_LLD ARM examples, qmInfraDmaMC_k2h.out, qmInfraDmaSC_k2h.out, or qmQAllocTest_k2h.out? They are in tisdk-server-extra-rootfs-image-k2hk-evm.tar.xz filesystem. I used the images from procSDK 4.1 release instead of downloading the latest 4.2. I am able to run the multicore DMA example on ARM.
    root@k2hk-evm:/usr/include/ti/drv/rm/device/k2h# rmServer.out global-resource-list.dtb policy_dsp_arm.dtb
    Starting rmServer.out
    Daemon returned 0 as return value.
    root@k2hk-evm:/usr/include/ti/drv/rm/device/k2h# qmInfraDmaMC_k2h.out
    No command line given. Forking off 4 tasks
    coreNum: 1; pid=926
    coreNum: 0; pid=925
    coreNum: 2; pid=927
    coreNum: 3; pid=928
    Initialized RM_Client1
    Initialized RM_Client2
    Initialized RM_Client3
    core 0: got CMEM CMA phys 0x87cc00000; virt 0xb6d16000
    core 0: Mapping 1048576 bytes from /dev/qmss at 0x02a00000
    core 0: Mapping 1048576 bytes from /dev/qmss at 0x23a00000
    thread priority set to 99
    core 1: got CMEM CMA phys 0x87cc00000; virt 0xb6d16000
    core 1: Mapping 1048576 bytes from /dev/qmss at 0x02a00000
    core 1: Mapping 1048576 bytes from /dev/qmss at 0x23a00000
    core 2: got CMEM CMA phys 0x87cc00000; virt 0xb6d16000
    core 2: Mapping 1048576 bytes from /dev/qmss at 0x02a00000
    core 2: Mapping 1048576 bytes from /dev/qmss at 0x23a00000
    core 3: got CMEM CMA phys 0x87cc00000; virt 0xb6d16000
    core 3: Mapping 1048576 bytes from /dev/qmss at 0x02a00000
    core 3: Mapping 1048576 bytes from /dev/qmss at 0x23a00000
    Successfully opened RX QPEND queue 665
    Successfully opened UIO dev /dev/uio3
    core 0: my rx queue: 665
    -----------------------Initializing---------------------------
    Successfully opened RX QPEND queue 663
    Successfully opened UIO dev /dev/uio1
    core 1: my rx queue: 663
    Core 0 : Memory region 0 inserted
    Successfully opened RX QPEND queue 664
    Successfully opened UIO dev /dev/uio2
    core 2: my rx queue: 664
    Successfully opened RX QPEND queue 662
    Successfully opened UIO dev /dev/uio0
    core 3: my rx queue: 662
    Core 0 : Memory region 1 inserted
    Core 0 : Tx Completion Queue Number : 9025 opened
    Core 0 : Number of Tx descriptors requested : 32. Number of descriptors allocated : 32
    Core 0 : Number of Rx descriptors requested : 32. Number of descriptors allocated : 32
    Core 0 : Number of Sync free descriptors requested : 32. Number of descriptors allocated : 32
    Core 0 : Sync Queue Number : 9026 opened
    Core 0 : Sync Cfg Queue Number : 898 opened
    Core 0 : Sync Free Queue Number : 897 opened
    Core 0 : Receive Free Queue Number : 8928 opened
    Core 0 : Transmit Free Queue Number : 736 opened
    Core 0 : System initialization completed: 736
    Core 0 : Publishing RM nameserver names for shared queues
    Core 0: Getting receive queues for other cores
    Core 1 : Rx Free Queue Number : 8928 opened
    Core 2 : Rx Free Queue Number : 8928 opened
    Core 3 : Rx Free Queue Number : 8928 opened
    Core 1 : Tx Free Queue Number : 736 opened
    Core 2 : Tx Free Queue Number : 736 opened
    Core 3 : Tx Free Queue Number : 736 opened
    Core 1 : Tx Completion Queue Number : 9025 opened
    Core 2 : Tx Completion Queue Number : 9025 opened
    Core 3 : Tx Completion Queue Number : 9025 opened
    Core 1 : Sync Queue Number : 9026 opened
    Core 2 : Sync Queue Number : 9026 opened
    Core 3 : Sync Queue Number : 9026 opened
    Core 1 : Sync Free Queue Number : 897 opened
    Core 2 : Sync Free Queue Number : 897 opened
    Core 3 : Sync Free Queue Number : 897 opened
    Core 1 : Sync Cfg Queue Number : 898 opened
    Core 2 : Sync Cfg Queue Number : 898 opened
    Core 3 : Sync Cfg Queue Number : 898 opened
    core 1: waiting for packets on 663
    core 2: waiting for packets on 664
    core 3: waiting for packets on 662
    core 0: Got core 1's RX QID: 663
    core 0: Got core 2's RX QID: 664
    core 0: Got core 3's RX QID: 662
    --------------------Queue status CORE 0----------------------
    After Initialization
    Tx Free Queue 736 Entry Count : 32
    Rx Free Queue 8928 Entry Count : 32
    Tx completion Queue 9025 Entry Count : 0
    Sync Queue 9026 Entry Count : 0
    Sync free Queue 897 Entry Count : 29
    Sync Cfg Queue 898 Entry Count : 3
    Core 0 : Opened Tx channel : 16
    Core 0 : Opened Rx channel : 16
    Core 0 : Transmit Queue Number : 816
    Core 0 : Receive Queue Number : 665
    Core 0 : Opened Rx flow : 16
    Core 0 : Transmitting 8 packets..........
    Core 0 : Receive Queue Number : 663
    core 1: got interrupt - process 8
    core 1: got 8 packets
    Core 1 : Waiting for sync signal
    Core 0 : Receive Queue Number : 664
    core 2: got interrupt - process 8
    core 2: got 8 packets
    Core 2 : Waiting for sync signal
    Core 0 : Receive Queue Number : 662
    core 3: got interrupt - process 8
    core 3: got 8 packets
    Core 3 : Waiting for sync signal
    core 0: waiting for packets on 665
    core 0: got interrupt - process 8
    core 0: got 8 packets
    Core 1 : Got sync signal
    Core 3 : Got sync signal
    Core 2 : Got sync signal
    Core 0 : Waiting for sync signal
    Core 0 : Got sync signal
    After packet processing
    Tx Free Queue 736 Entry Count : 0
    Tx completion Queue 9025 Entry Count : 32
    Sync Queue 9026 Entry Count : 4
    Sync free Queue 897 Entry Count : 24
    Sync Cfg Queue 898 Entry Count : 4
    Core 0 : Waiting for other cores to ack sync signal
    Core 0 : acks found
    Core 1 : Receive free queue closed successfully. Ref count : 3
    Core 3 : Receive free queue closed successfully. Ref count : 2
    Core 2 : Receive free queue closed successfully. Ref count : 1
    Core 0 : Receive free queue closed successfully. Ref count : 0
    Core 1 : Transmit completion queue closed successfully. Ref count : 3
    Core 3 : Transmit completion queue closed successfully. Ref count : 2
    Core 2 : Transmit completion queue closed successfully. Ref count : 1
    Core 0 : Transmit completion queue closed successfully. Ref count : 0
    Core 1 : Transmit free queue closed successfully. Ref count : 3
    Core 3 : Transmit free queue closed successfully. Ref count : 2
    Core 2 : Transmit free queue closed successfully. Ref count : 1
    Core 0 : Transmit free queue closed successfully. Ref count : 0
    Core 1 : Sync queue closed successfully. Ref count : 3
    Core 3 : Sync queue closed successfully. Ref count : 2
    Core 2 : Sync queue closed successfully. Ref count : 1
    Core 0 : Sync queue closed successfully. Ref count : 0
    Core 1 : Sync free queue closed successfully. Ref count : 3
    Core 3 : Sync free queue closed successfully. Ref count : 2
    Core 2 : Sync free queue closed successfully. Ref count : 1
    Core 0 : Sync free queue closed successfully. Ref count : 0
    Core 0 : CPPI CPDMA closed successfully
    Core 0 : CPPI exit successful
    Core 0: Cleaning regions
    Core 1 : CPPI CPDMA closed successfully
    Core 1 : CPPI exit successful
    Core 1: exit QMSS
    Core 3 : CPPI CPDMA closed successfully
    Core 3 : CPPI exit successful
    Core 3: exit QMSS
    Core 2 : CPPI CPDMA closed successfully
    Core 2 : CPPI exit successful
    Core 2: exit QMSS
    ******** QMSS Multicore (1) Example Done (PASS) *******
    ******** QMSS Multicore (3) Example Done (PASS) *******
    ******** QMSS Multicore (2) Example Done (PASS) *******
    Core 0: exit QMSS
    Core 0 : Deleting RM nameserver names for shared queues
    ******** QMSS Multicore (0) Example Done (PASS) *******
    Waiting for children to exit
    All children passed
    You may want to check what were done differently from the example.
    Rex
  • Hello Rex,
    Thank you a lot for the reply!
    With your help the customer solved the issue with registers.
    But there real problem: They can't start interacting between Linux and DSP cores.
    Description:
    The customer managed to run mpm-transort through shared memory, but this method is not the best, because OS should constantly poll the mailbox. It seems like there should be a qmss mechanism with interrupts for normal operation.
    The customer took DSP_EP and ARM_EP examples and tried to adapt it for their own project.
    Under Linux it seems like it's working, "/ dev / qmss" has appeared, but we are spinning in a loop:
    do {
               status = MessageQ_open(rem_msg_q_name, &msg_q_id_arr[i]);
               sleep(1);
           } while ((status == MessageQ_E_NOTFOUND) ||
                    (status == MessageQ_E_TIMEOUT));
    Where rem_msg_q_name  = "RM_Client_DSP_1”, status = MessageQ_E_NOTFOUND.
    After loading program to DSP0, then it also goes in loop:
    * ======== VirtQueue_startup ========
    Void VirtQueue_startup(UInt16 procId, Bool isHost)
       /* Wait for first kick from host, which happens to coincide with the
        * priming of host's receive buffers, indicating host is ready to send.
        * Since interrupt is cleared, we throw away this first kick, which is
        * OK since we don't process this in the ISR anyway.
       Log_print0(Diags_USER1, "VirtQueue_startup: Polling for host int...");
       while (!VirtQueue_InterruptProxy_intClear(procId, NULL));
    It is waiting something from HOST. What is DSP waiting for?
    The Linux part:
    Ipc_transportConfig(&TransportRpmsg_Factory);
    status = Ipc_start();
    rm_msg_hub(MAX_REMOTE_DSPS); -> looped
    The DSP part in stack order:
    /* Setup TransportRpmsg for host communication */
       IpcMgr_ipcStartup(); ->
                    status = TransportRpmsgSetup_attach(procId, 0); ->
                                    handle = TransportRpmsg_create(procId, &params, &eb);
                                    RPMessage_init(remoteProcId); ->
                                                        /* Plug Vring Interrupts, and wait for host ready to recv kick: */
                                                       VirtQueue_startup(remoteProcId, isHost);
    Also the process stops on “Process 1 : Attempting to open DSP 1 queue: TEST_MsgQ_Proc_1”. Logs in attachment - Log1 with error, Log2 after reboot with check inside ARM
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.01.26 14:07:24 =~=~=~=~=~=~=~=~=~=~=~=
    root@k2hk-user:/media/ram# rmServer.out /usr/bin/device/k2h/global-resource-list.dtb /usr/bin/device/k2h/policy_dsp_arm.dtb
    root@k2hk-user:/media/ram# ./multiProcessTest_k2h.out
    ******** TransportQmss Linux Multi-Process Test *********
    Version String: Linux IPC Transports Revision: 2.0.0.01:Jan 24 2018:19:40:03
    Process 1 : Initialized RM_Client1
    Process 0 : Initialized RM_Client0
    Process 0 : Creating TransportQmss instance
    Process 2 : Initialized RM_Client2
    Process 2 : Creating TransportQmss instance
    Process 3 : Initialized RM_Client3
    Process 3 : Creating TransportQmss instance
    Process 1 : Local MessageQ: Process_1_MsgQ, QId: 0x80
    Process 1 : Attempting to open remote queue: Process_2_MsgQ
    Process 3 : Local MessageQ: Process_3_MsgQ, QId: 0x81
    Process 3 : Attempting to open remote queue: Process_0_MsgQ
    Process 2 : Local MessageQ: Process_2_MsgQ, QId: 0x82
    Process 2 : Attempting to open remote queue: Process_3_MsgQ
    Process 0 : Local MessageQ: Process_0_MsgQ, QId: 0x83
    Process 0 : Attempting to open remote queue: Process_1_MsgQ
    Process 2 : Opened Remote queue: Process_3_MsgQ, QId: 0x81
    Process 0 : Opened Remote queue: Process_1_MsgQ, QId: 0x80
    Process 0 : Allocating round trip test MessageQ msg
    Round Trip -    1
    Process 0 : Sending msg to Process 1
    Process 1 : Opened Remote queue: Process_2_MsgQ, QId: 0x82
    Process 1 : Received msg with good data from Process 0
    Process 1 : Sending msg to Process 2
    Process 2 : Received msg with good data from Process 1
    Process 2 : Sending msg to Process 3
    Process 3 : Opened Remote queue: Process_0_MsgQ, QId: 0x83
    Process 3 : Received msg with good data from Process 2
    Process 3 : Sending msg to Process 0
    Process 0 : Received msg with good data from Process 3
    Round Trip -    2
    Round Trip -    3
    Round Trip -    4
    Round Trip -    5
    Round Trip -    6
    Round Trip -    7
    Round Trip -    8
    Round Trip -    9
    Round Trip -   10
    Round Trip -   11
    Round Trip -   12
    Round Trip -   13
    Round Trip -   14
    Round Trip -   15
    Round Trip -   16
    Round Trip -   17
    Round Trip -   18
    Round Trip -   19
    Round Trip -   20
    Round Trip -   21
    Round Trip -   22
    Round Trip -   23
    Round Trip -   24
    Round Trip -   25
    Round Trip -   26
    Process 0 : Flushing transport's dst cache of dst MessageQ queue ID 0x80
    Process 1 : Flushing transport's dst cache of dst MessageQ queue ID 0x82
    Process 2 : Flushing transport's dst cache of dst MessageQ queue ID 0x81
    Process 3 : Flushing transport's dst cache of dst MessageQ queue ID 0x83
    Round Trip -   27
    Round Trip -   28
    Round Trip -   29
    Round Trip -   30
    Round Trip -   31
    Round Trip -   32
    Round Trip -   33
    Round Trip -   34
    Round Trip -   35
    Round Trip -   36
    Round Trip -   37
    Round Trip -   38
    Round Trip -   39
    Round Trip -   40
    Round Trip -   41
    Round Trip -   42
    Round Trip -   43
    Round Trip -   44
    Round Trip -   45
    Round Trip -   46
    Round Trip -   47
    Round Trip -   48
    Round Trip -   49
    Round Trip -   50
    Round Trip -   51
    Process 0 : Flushing transport's entire dst cache
    Process 1 : Flushing transport's entire dst cache
    Process 2 : Flushing transport's entire dst cache
    Process 3 : Flushing transport's entire dst cache
    Round Trip -   52
    Round Trip -   53
    Round Trip -   54
    Round Trip -   55
    Round Trip -   56
    Round Trip -   57
    Round Trip -   58
    Round Trip -   59
    Round Trip -   60
    Round Trip -   61
    Round Trip -   62
    Round Trip -   63
    Round Trip -   64
    Round Trip -   65
    Round Trip -   66
    Round Trip -   67
    Round Trip -   68
    Round Trip -   69
    Round Trip -   70
    Round Trip -   71
    Round Trip -   72
    Round Trip -   73
    Round Trip -   74
    Round Trip -   75
    Round Trip -   76
    Round Trip -   77
    Round Trip -   78
    Round Trip -   79
    Round Trip -   80
    Round Trip -   81
    Round Trip -   82
    Round Trip -   83
    Round Trip -   84
    Round Trip -   85
    Round Trip -   86
    Round Trip -   87
    Round Trip -   88
    Round Trip -   89
    Round Trip -   90
    Round Trip -   91
    Round Trip -   92
    Round Trip -   93
    Round Trip -   94
    Round Trip -   95
    Round Trip -   96
    Round Trip -   97
    Round Trip -   98
    Round Trip -   99
    Round Trip -  100
    Process 3 : Freeing round trip test MessageQ msg
    Test PASSED
    Cleaning up
    Test Complete!
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.01.26 13:58:57 =~=~=~=~=~=~=~=~=~=~=~=
    root@k2hk-user:/media/ram# mpmcl reset dsp0
    reset succeeded
    root@k2hk-user:/media/ram# mpmcl reset dsp0 1
    reset succeeded
    root@k2hk-user:/media/ram# mpmcl load dsp0 transportQmssDspEpK2HC66TestProject.out
    load succeeded
    root@k2hk-user:/media/ram# mpmcl load dsp1 transportQmssDspEpK2HC66TestProject.out
    load succeeded
    root@k2hk-user:/media/ram# mpmcl run dsp0
    run succeeded
    run succeeded
    root@k2hk-user:/media/ram# ./armEpTest_k2h.out
    * ARMv7 Linux TransportQmss Heterogeneous Test (ARM EP) *
    Process 0 : Starting RM Message Hub
    Process 0 : Created RM hub queue: RM_Message_Hub, Qid: 0x80
    Process 0 : Opening RM_Client_DSP_1
    Process 1 : Local MessageQ: TEST_MsgQ_Proc_0, QId: 0x81
    ^Z
    [1]+  Stopped(SIGTSTP)        ./armEpTest_k2h.out
    Process 1 : Local MessageQ: Process_1_MsgQ, QId: 0x82
    ERROR Process 0 : Failed to create TransportQmss handle
    Process 2 : Local MessageQ: Process_2_MsgQ, QId: 0x83
    Process 3 : Local MessageQ: Process_3_MsgQ, QId: 0x84
    Process 1 : Opened Remote queue: Process_2_MsgQ, QId: 0x83
    Process 2 : Opened Remote queue: Process_3_MsgQ, QId: 0x84
    ^Z
    [2]+  Stopped(SIGTSTP)        ./multiProcessTest_k2h.out
    Edit 1: They collect their own Linux image with the connection of the necessary modules:
    ARAGO_IMAGE_EXTRA_INSTALL ?= ""
    IMAGE_INSTALL += " \
                    packagegroup-core-boot \
                    ${ARAGO_IMAGE_EXTRA_INSTALL} \
    IMAGE_INSTALL += "\
        packagegroup-arago-base \
        packagegroup-arago-console \
        packagegroup-arago-base-tisdk \
        packagegroup-arago-test \
        ${VIRTUAL-RUNTIME_initramfs} \
    IMAGE_INSTALL += "openssh openssh-sftp openssh-sftp-server gdbserver multiprocmgr ipc-transport-qmss uio-module-drv qmss-lld qmss-pdsp-fw rm-lld"
    In attachment there are logs wth various options (logs.zip).5707.logs.zip
    Edit 2: I should add, as i understand, almost similar problem described in:
    https://e2e.ti.com/support/dsp/c6000_multi-core_dsps/f/639/p/541046/1983711
    https://e2e.ti.com/support/dsp/c6000_multi-core_dsps/f/639/t/544167
    But i have not found there any complete answer from TI's team. Or may be we are missing something...
  • Hi, Ilya,
    From the logs, the benchmark and multi-process werefine, but armEP test failed due to IPC_start failed. In the links you provided, customer resolved it by himself and found that " it turns out the place where the shared region is defined is really important. If placed in the middle of the configuration file (like the original dsp_ep.cfg from the example), the IPC start blocks. If the shared region is defined at the end of the configuration file, it works! "
    Could your customer compare its configuration with the one posted in the thread to see if that is the problem?
    Rex
  • Hello Rex,
    Thank you for the reply!
    The additional question from the customer:
    1)Due to source code of prj «transportQmssDspEpK2HC66TestProject» in «dsp_ep.c» file, the IPC initialization is:
       /* Setup IPC for DSP to DSP communication */
    Then Ipc_start() turns to the endless cyrcle.
    But in documentation mentioned that Keystone 2 in Linux-DSP mode should only use the IpcMgr_ipcStartup(). But when doing so, the ti_sdo_ipc_SharedRegion_attach() and SharedRegion_getHeap() wasnt called and the initialization of ti_sdo_ipc_GateMP_Instance_init() returns NULL.
    The question:
    Should the SharedRegion_module->regions[0].heap be initializated in ARM-Linux?
    If it is, then: Why wasnt it initializated by  «armEpTest_k2h.out»  from «ipc-transport-qmss-test»?
    Also the customer adds:
    1)If Ipc_start() left in DSP module then it doesnt turn to the cycle. And then, if we try to make Ipc_attach(2) to another DSP, after calling status = Ipc_procSyncStart(remoteProcId, Ipc_module->ipcSharedAddr) it returns status = -11 (Ipc_E_NOTREADY).
    Log from DSP2:
    2 Resource entries at 0x810000
    Core 1 : ******************************************************
    Core 1 : SYS/BIOS DSP TransportQmss Heterogeneous Test (DSP EP)
    Core 1 : Device name:               TMS320TCI6636
    Core 1 : Processor names:           HOST,CORE0,CORE1
    Core 1 : IPC Core ID:               2
    Core 1 : Number of DSPs             2
    Core 1 : Number of test iterations: 100
    Core 1 : Starting IPC core 2 with name ("CORE1")
    TransportRpmsg_Instance_init: remoteProc: 0
    registering rpmsg-proto:rpmsg-proto service on 61 with HOST
    [t=0x00052e1c] xdc.runtime.Main: NameMap_sendMessage: HOST 53, port=61
    2) In the example project (transportQmssDspEpK2HC66TestProject) there are function:
                   /* The region heap will do the alignment */
               regionHeap = SharedRegion_getHeap(obj->regionId);
    It returns NULL without Ipc_start() (If we left only IpcMgr_ipcStartup()).
    If we turns on the Ipc_start(), when the DSP2 is trying attach to DSP1 the process crashes with reinitialization(because through the RM server we can work only with HOST).
    But at this moment we dont need operations between DSP cores.
    Stack of calls when NULL is returned:
    initTsk >>>
    GateMP_create >>>
    ti_sdo_ipc_GateMP_create >>>
    ti_sdo_ipc_GateMP_Instance_init__E >>>
    ti_sdo_ipc_GateMP_Instance_init >>>
    SharedRegion_getHeap(0) return NULL!!!
    Stack when the error in Ipc_start() CORE0 occurs:
    Ipc_start >>>
    status = Ipc_attach(baseId = 2); >>>
    status = ti_sdo_ipc_MessageQ_SetupTransportProxy_attach(2, 0); return -1; !!!
    /* This MessageQ Transport over RPMSG only talks to the "HOST" for now: */ !!!
    Could you help us please to reslove our customer's problem. This is very important project.
    The customer wants to made data reception on PCIe and distribution to DSP, and then processing the data and data tranfer with SPI in two directions.
  • Hi, Ilya,
    I'll close this thread for QMSS. Could you submit a new thread for this IPC question? I'll have a DSP engineer to help in the new thread.
    Rex
  • Hello Rex,
    I have made new thread for the last post:
    e2e.ti.com/.../662636
    Ilya.
