Other Parts Discussed in Thread: TVP5146, THS7303, TVP7002, THS7353
I am not measuring 5v on the USB VBUS signal.
Here is my kernel configuration related to USB:
fgrep USB .config | grep -v '^#'
CONFIG_USB_HID=y
CONFIG_USB_SUPPORT=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB=y
CONFIG_USB_DEVICEFS=y
CONFIG_USB_DEVICE_CLASS=y
CONFIG_USB_MUSB_HDRC=y
CONFIG_USB_MUSB_SOC=y
CONFIG_USB_MUSB_HOST=y
CONFIG_USB_MUSB_HDRC_HCD=y
CONFIG_USB_TI_CPPI_DMA=y
CONFIG_USB_STORAGE=y
CONFIG_USB_TEST=y
CONFIG_USB_OTG_UTILS=y
CONFIG_NOP_USB_XCEIV=y
The schematic (http://designsomething.org/leopardboard/uploads/dm365_leopard_board_ver1.3.pdf) shows GPIO66 is connected to DRV_VBUS, so I changed the arch/arm/mach-davinci/board-dm365-evm.c file (we are in the process of making a board-dm365-leopard.c file) to have
static void dm365evm_usb_configure(void)
gpio_request(66, "usb-vbus");
gpio_direction_output(66, 0);
setup_usb(500, 8);
My hardware configuration is:
a) Leopardboard 365 v 1.3
b) LI-DVI1 v 1.3
c) USB mini-B to A converter that came with the DM6446 EVM
d) Logitech track ball that was tested working with a HawkBoard (and I measured 5v on VBUS on HawkBoard to verify I was measuring the right signal)
e) Leopardboard 365 powered with 3a 5v power supply
I am not seeing 5V on USB VBUS.
What configuration step am I missing?
Todd
P.S. here is the boot output (I have a USB serial dongle connected)
DM36x initialization passed!
TI UBL Version: 1.50
Booting Catalog Boot Loader
BootMode = NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
DONE
Jumping to entry point at 0x81080000.
U-Boot 1.3.4-svn21 (Feb 24 2010 - 10:04:27)
I2C: ready
DRAM: 128 MB
NAND: NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron NAND 256MiB 3,3
V 8-bit)
Bad block table not found for chip 0
nand_bbt: Error while writing bad block table -5
256 MiB
In: serial
Out: serial
Err: serial
Ethernet PHY: GENERIC @ 0x00
Hit any key to stop autoboot: 0
Loading from NAND 256MiB 3,3V 8-bit, offset 0x400000
Image Name: "RR Linux Kernel"
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4344320 Bytes = 4.1 MB
Load Address: 80008000
Entry Point: 80008000
Automatic boot of image at addr 0x82000000 ...
## Booting kernel from Legacy Image at 82000000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 2.6.32-rc2-ridgerun (tfischer@sax-lx) (gcc version 4.2.4) #10 PREE
MPT Thu Jul 29 10:57:14 MDT 2010
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: DaVinci DM365 EVM
Memory policy: ECC disabled, Data cache writeback
DaVinci dm365_rev1.2 variant 0x8
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 16256
Kernel command line: davinci_enc_mngr.ch0_output=DVI davinci_enc_mngr.ch0_mode=7
20P-60 davinci_display.cont2_bufsize=6291456 vpfe_capture.cont_bufoffset=6291456
vpfe_capture.cont_bufsize=8388608 console=ttyS0,115200n8 video=davincifb:vid0=o
ff:vid1=off:osd1=off mem=64M root=/dev/nfs nfsroot=10.111.0.3:/local/home/tfisch
er/work/winntech/fs/fs rw ip=dhcp mtdparts=nand_davinci.0:3968k(UBOOT),128k(UBOO
T_ENV),4352k(KERNEL),204800k(FS)
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 60444KB available (3904K code, 383K data, 144K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:245
Console: colour dummy device 80x30
Calibrating delay loop... 147.86 BogoMIPS (lpj=739328)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
DaVinci: 8 gpio irqs
NET: Registered protocol family 16
davinci_serial_init:97: failed to get UART2 clock
EVM: tvp5146 SD video input
bio: create slab <bio-0> at 0
DM365 IPIPE initialized in Single Shot mode
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
vpss vpss: dm365_vpss vpss probed
vpss vpss: dm365_vpss vpss probe success
dm365_afew_hw_init
ch0 default output "DVI", mode "720P-60"
VPBE Encoder Initialized
cfg80211: Using static regulatory domain info
cfg80211: Regulatory domain: US
(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
(2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
(5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
cfg80211: Calling CRDA for country: US
Leopard DVI encoder initialized
Switching to clocksource timer0_1
musb_hdrc: version 6.0, cppi-dma, host, debug=0
musb_hdrc: USB Host mode controller at fec64000 using DMA, IRQ 12
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
msgmni has been set to 118
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered (default)
davincifb davincifb.0: dm_osd0_fb: 1280x720x16@0,0 with framebuffer size 1800KB
davinci_interrupt 374: VBUS error workaround (delay coming)
davincifb davincifb.0: dm_osd1_fb: 1280x720x4@0,0 with framebuffer size 1800KB
DM365 IPIPEIF probed
imp serializer initialized
davinci_previewer initialized
davinci_resizer initialized
Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
console [ttyS0] enabled
brd: module loaded
at24 1-0050: 32768 byte 24c256 EEPROM (writable)
Read MAC addr from EEPROM: eb:02:03:25:f1:52
spi_davinci spi_davinci.0: DaVinci SPI driver in EDMA mode
Using RX channel = 17 , TX channel = 16 and event queue = 3
at25 spi0.0: 8 KByte at25640 eeprom, pagesize 32
spi_davinci spi_davinci.0: Controller at 0xfec66000
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbtest
i2c /dev entries driver
Linux video capture interface: v2.00
ths7303 1-002c: chip found @ 0x58 (DaVinci I2C adapter)
vpfe_init
vpfe-capture: vpss clock vpss_master enabled
vpfe-capture vpfe-capture: v4l2 device registered
vpfe-capture vpfe-capture: video device registered
EVM: switch to tvp5146 SD video input
vpfe-capture vpfe-capture: v4l2 sub device tvp5146 register fails
EVM: switch to tvp7002 HD video input
vpfe-capture vpfe-capture: v4l2 sub device tvp7002 register fails
ths7353 1-002e: chip found @ 0x5c (DaVinci I2C adapter)
ths7353 1-002e: No platform data!!
ths7353 1-002e: ths7353 write failed
ths7353: probe of 1-002e failed with error -121
vpfe-capture vpfe-capture: v4l2 sub device ths7353 register fails
No sub devices registered
vpfe-capture: vpfe capture clocks disabled
vpfe_register_ccdc_device: DM365 ISIF
DM365 ISIF is registered with vpfe.
af major#: 252, minor# 0
AF Driver initialized
aew major#: 251, minor# 0
AEW Driver initialized
Trying to register davinci display video device.
layer=c25f1400,layer->video_dev=c25f1570
layer=c25f1a00,layer->video_dev=c25f1b70
davinci_init:DaVinci V4L2 Display Driver V1.0 loaded
watchdog watchdog: heartbeat 60 sec
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.21.
No device for DAI tlv320aic3x
No device for DAI davinci-i2s
asoc: tlv320aic3x <-> davinci-i2s mapping ok
ALSA device list:
#0: DaVinci EVM (tlv320aic3x)
TCP cubic registered
NET: Registered protocol family 17
lib80211: common routines for IEEE802.11 drivers
Clocks: disable unused mmcsd0
Clocks: disable unused mmcsd1
Clocks: disable unused spi1
Clocks: disable unused spi2
Clocks: disable unused spi3
Clocks: disable unused spi4
Clocks: disable unused pwm0
Clocks: disable unused pwm1
Clocks: disable unused pwm2
Clocks: disable unused pwm3
Clocks: disable unused timer1
Clocks: disable unused timer3
Clocks: disable unused emac
Clocks: disable unused voice_codec
Clocks: disable unused rto
Clocks: disable unused mjcp
davinci_emac_probe: using random MAC addr: 02:a5:87:47:d1:f7
emac-mii: probed
eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=1:01, id=221613)
Sending DHCP requests .
PHY: 1:01 - Link is Up - 100/Full
., OK
IP-Config: Got DHCP answer from 10.111.0.1, my address is 10.111.0.197
IP-Config: Complete:
device=eth0, addr=10.111.0.197, mask=255.255.255.0, gw=10.111.0.1,
host=10.111.0.197, domain=fischerfamily.org, nis-domain=fischerfamily.org,
bootserver=10.111.0.1, rootserver=10.111.0.3, rootpath=
Looking up port of RPC 100003/2 on 10.111.0.3
Looking up port of RPC 100005/1 on 10.111.0.3
VFS: Mounted root (nfs filesystem) on device 0:14.
Freeing init memory: 144K
init started: BusyBox v1.14.2 (2010-07-14 14:05:20 MDT)
starting pid 978, tty '': '/etc/rcS'
Starting System
done.
Customized by RidgeRun Embedded Linux Solutions
For further information see:
http://www.ridgerun.com
Build host: sax-lx
Built by: tfischer
Build date: Thu, 29 Jul 2010 11:28:48 -0600
Build tag: leopard
Configuring network interfaces
CMEMK module: built on Jul 29 2010 at 06:12:26
Loading CMEM fro Reference Linux version 2.6.32
m 0x84e00000 to 0x88000000
File /local/home/tfischer/work/winntech/proprietary/dvsdk_3_10_00/dvsdk_3_10_0
0_12/linuxutils_2_25_01_06/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
allocated heap buffer 0xc7000000 of size 0x65b000
cmemk initialized
EDMAK module: built on Jul 29 2010 at 06:12:34
0_12/linuxutils_2_25_01_06/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
IRQK module: built on Jul 29 2010 at 06:12:38
0_12/linuxutils_2_25_01_06/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
irqk initialized
dm365mmap 1740 0 - Live 0xbf01a000
irqk 6066 0 - Live 0xbf013000
edmak 11929 0 - Live 0xbf00b000
cmemk 20210 0 - Live 0xbf000000
You can see the track ball USB device was not found
/ # cd /sys/bus/usb/
/sys/bus/usb # find .
./uevent
./devices
./devices/usb1
./devices/1-0:1.0
./drivers
./drivers/usbfs
./drivers/usbfs/module
./drivers/usbfs/uevent
./drivers/usbfs/unbind
./drivers/usbfs/bind
./drivers/usbfs/new_id
./drivers/hub
./drivers/hub/module
./drivers/hub/uevent
./drivers/hub/unbind
./drivers/hub/bind
./drivers/hub/new_id
./drivers/hub/1-0:1.0
./drivers/usb
./drivers/usb/uevent
./drivers/usb/unbind
./drivers/usb/bind
./drivers/usb/usb1
./drivers/usb-storage
./drivers/usb-storage/module
./drivers/usb-storage/uevent
./drivers/usb-storage/unbind
./drivers/usb-storage/bind
./drivers/usb-storage/new_id
./drivers/usbtest
./drivers/usbtest/module
./drivers/usbtest/uevent
./drivers/usbtest/unbind
./drivers/usbtest/bind
./drivers/usbtest/new_id
./drivers/usbhid
./drivers/usbhid/module
./drivers/usbhid/uevent
./drivers/usbhid/unbind
./drivers/usbhid/bind
./drivers/usbhid/new_id
./drivers_probe
./drivers_autoprobe
/sys/bus/usb #
