memory leak in EZSDK 05.05 (gst-omx)
HI,
I am using EZSDK 05.05 on DM8148.
The codec memory leakage in VideoM3 seems to have been solved, but I observed new issue:
Somehow omx codecs plug-in is causing memor leakage in linux application area. I use "free utility" to observe the memory leak. I found after running each of my tests for 4 times 60K bytes leakage is indicated in application memory. I tetsed this with omx_mpeg2dec, omx_mpeg4dec, omx_h264dec and omx_vc1dec and for each of  then afetr 4 runs, 60K bytes is lost.
My observation is as following:
omx_vc1dec:
root@dm814x-evm:/svp/bin#free
              total         used         free       shared      buffers
  Mem:       252408       241424        10984            0         4540
 Swap:            0            0            0
Total:       252408       241424        10984
root@dm814x-evm:/svp/bin# gst-launch filesrc location=/media/mmcblk1p1/Media_Tes
t/ASF-WMV9-WMA-1280x720.asf ! asfdemux ! multiqueue ! omx_vc1dec ! fakesink                (run this 4 times)
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Recieved EOS event, press <CTRL+C> to terminate pipeline.
Got EOS from element "pipeline0".
Execution ended after 27093282601 ns.
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
root@dm814x-evm:/svp/bin# free
  Mem:       252408       241484        10924            0         4540
 Swap:            0            0            0
Total:       252408       241484        10924
omx_mpeg2dec:
  Mem:       252408       210576        41832            0         2160
 Swap:            0            0            0
Total:       252408       210576        41832
t/01_VCD_NTSC_MediaClip-01.mpg ! mpegpsdemux ! multiqueue ! mpegvideoparse ! omx
_mpeg2dec ! fakesink
sequence end!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Execution ended after 2326990401 ns.
  Mem:       252408       210636        41772            0         2160
 Swap:            0            0            0
Total:       252408       210636        41772
omx_mpeg4dec:
  Mem:       252408       227736        24672            0         2176
 Swap:            0            0            0
Total:       252408       227736        24672
t/30-1672_MP4-MPEG4-AAC-720x480.MOV ! qtdemux ! multiqueue ! omx_mpeg4dec ! fake
sink
Width :720, Height: 480
Execution ended after 7070125100 ns.
  Mem:       252408       227796        24612            0         2176
 Swap:            0            0            0
Total:       252408       227796        24612
omx_h264dec
  Mem:       252408       233416        18992            0         4504
 Swap:            0            0            0
Total:       252408       233416        18992
t/29.9-20500-720X480-DucksTakeOffp-H.264.mkv ! matroskademux ! multiqueue ! h264
parse ! omx_h264dec ! fakesink
Execution ended after 3063128851 ns.
  Mem:       252408       233476        18932            0         4504
 Swap:            0            0            0
Total:       252408       233476        18932
I tested above with omx_... decodres and I do not see the loss of memory. So I believe somethign to do with gst-omx plug-in.
Salim
  • I found the memory leak is still there when media file is removed and gs-launch is run (error situation).
    Any pointer from Ti experts where the loss might be happening?
    Salim
    I will check it and I will let you know the results.
    What is the EZSDK version that you are using here 5.05.01 or 5.05.02?
    Margarita
  • Thanks Margarita,
    The version is 5.05.02.
    Kindest Regards,
    Salim
  • Any findings Margarita?
    Thanks and
    Kindest Regards,
    Salim
  • I even tried to free the cached memory via cat 3 > /proc/sys/vm/drop_caches, the result is the same.
    Salim
  • Hello Salim,
    I will check it for memory leak.
    An easy way to debug the memory leak of a GStreamer program that is running is by looking at the reference counters. In most of the cases the memory leaks on gstreamer happened because reference counters on one or more objects never go back to zero.
    One of the debug variables is GST_REFCOUNTING. With that, you can get a log of all the refcount changes that happened inside a gstreamer.
    Setting GST_REFCOUNTING
    Add the following to your pipeline's command line parameters:
    --gst-debug=GST_REFCOUNTING:5
    Another option is to set the GStreamer debugging shell variable, then run your pipeline:
    export GST_DEBUG=GST_REFCOUNTING:5
    Filtering debug output
    Here are  example on how to filter the debug output.
    You can see which objects disappear, meaning their reference count reaches zero:
    gst-launch --gst-debug=GST_REFCOUNTING:5 videotestsrc num-buffers=3 ! fakesink 2>&1 | grep "\->0" | cut -d' ' -f 19
    You could try to debug it.
    Margarita
  • Thanks Margarita,
    I will wait for any results from your side and at the same time perform some more tests on my side.
    BTW, will GST_REFCOUNTING be halpful to detect an leakage caused by gst-omx as well as omx components? I doubt that.
    What is good way to measure the memory usage / leakage by gst-omx and omx?
    Also, in above reported issue, the leak is observed after application/process exit, the leakage observed might not be from gstreamer / omx but from other shared services like syslink that might not be encapsulated by the process but used by process. (However this does not mean gst-omx and omx do nt have linux side memory leakage. We will need different method to check for gst-mx / omx side memory. Please share if you know of reliable and effective way).
    Rgds,
    Salim
    After few tests I can say that, the gstreamer plugin and OMX are not the cause for the problem.
    I will let you know when I have something.
    Margarita
  • Thanks Margarita,
    I too had same inference. This is because, the memory depletion is present even after the process invoking gstreamer and omx is killed.
    High suspicion is on Syslink.
    Surprisingly, VPSS omx components too use Syslink but do not demonstrate this issue.
    So, I think that VICP2 side syslink specifically might be causing the issue.
    Kindest Regards,
    Salim
  • Hi Margarita,
    We are facing same issue in our DM8168 with EZsdk setup.
    After multiple restart of gstreamer pipeline, we are getting error
     CRITICAL **: g_omx_port_allocate_buffers: assertion `port->buffers[i]' failed.
    Do you have any update on this memory leak issue?
    Abeesh.
  • HI Abeesh,
    I do not know about your test environment, but few hints may help you:
    The error CRITICAL **: g_omx_port_allocate_buffers: assertion `port->buffers[i]' failed.
    will happen only if previous playback has not be closed in clean way (decoder resources mainly shared video buffer) have been released.
    There could be many reason for previous playback not getting close normally:
    - Is you are using gst-launch command line, in the middle of the playback you press ^C and sometimes the pipeline stops without releasing the video buffers
    - There may be timestamped problem in the media file, where EOS might not be received as expected.
    Hence, check in your pipeline when you stop is are all resources begin released before being re-allocated in the next playback.
    Rgds,
    Salim
    It would be better to post this issue in the DM8168 forum.
    http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717.aspx
    Margarita
  • Hi Salim,
    We are using C application instead of using gst-launch.Before starting pipeline again, am doing this much state changes in pipeline and unref the pipeline.
           gst_element_set_state (hsc1_fact_live.Bin, GST_STATE_PAUSED);
            gst_element_set_state (hsc1_fact_live.Bin, GST_STATE_READY);
            gst_element_set_state (hsc1_fact_live.Bin, GST_STATE_NULL);
            gst_object_unref (hsc1_fact_live.Bin);
    Is there anything extra needs to be done ?
    Abeesh
  • HI Abeesh,
    After each of gst_element_set_... try to use gst_element_get with NULL as parameter instead of timeout.
    Kindest Regards,
    Salim
  • Hi salim,
    Am using that, The code snippet I have sent u was old one,New one is like this,
    int gst_state_check(GstElement *element,int trans_state)
        int timeout=0,state;
        while(1)
            state = gst_element_get_state(element,NULL,NULL,-1);
            if(trans_state !=GST_STATE_PAUSED)
                if(state ==  GST_STATE_CHANGE_SUCCESS){
                    return 1;
            else {
                if((state ==  GST_STATE_CHANGE_SUCCESS ) || state == GST_STATE_CHANGE_NO_PREROLL){
                    return 1;
            usleep(500);
            timeout++;
            if(timeout > 10)
                g_print("ERROR!!!!!!!!!!! state change failed: state %d for state_transition=%d\n",state, trans_state);
                return -1;
            gst_element_send_event(hsc1_fact_rtp_stream.Bin, gst_event_new_eos ());
            gst_element_set_state(hsc1_fact_rtp_stream.Bin, GST_STATE_PAUSED);
            gst_state_check(hsc1_fact_rtp_stream.Bin ,GST_STATE_PAUSED);
            gst_element_set_state(hsc1_fact_rtp_stream.Bin, GST_STATE_READY);
            gst_state_check(hsc1_fact_rtp_stream.Bin, GST_STATE_READY);
            gst_element_set_state(hsc1_fact_rtp_stream.Bin, GST_STATE_NULL);
            gst_state_check(hsc1_fact_rtp_stream.Bin, GST_STATE_NULL);
            gst_object_unref (hsc1_fact_rtp_stream.Bin);
    Have you tried with the Ridgerun plugins? they are based on the latest gstreamer 0.10.36, the version on the EZSDK is older so you get the latest fixes available in the gstreamer libraries. Now, we have an improved version of the plugins included in the EZSDK (option 1) in the below post, we have fixed several bug fixes, It is included in the Ridgerun Eval SDK
    http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/t/327198.aspx
    Ridgerun Eval SDKs:
    http://www.ridgerun.com/www/index.php/download-center.html
    However, those already have problems to move between states and if you keep destroying instances of the plugins that are implemented on the VPSS you will see a problem, in the above thread.
    Now, we are creating a new set of plugins (option 3) in the thread you can see how you could use them from the eval as well.
    @ : Did you solve your problem? We can try to reproduce it at Ridgerun.
    @ : As Salim mentioned the allocate buffers assertion happens when something was not closed properly, you can verify running sys_top that the amount of memory used while running the pipeline is not freed, we solved several of those errors in our version of the plugins too. Could you share the pipeline that you are using? I will try to reproduce it with our plugins.
    -David
