Other Parts Discussed in Thread: TLC59108, TVP7002
Hello, Dear experts!
I try to run capture_encode_a8host_debug.xv5T but all is without luck!
My actions is:
Firstly, I have ezsdk_dm814x-evm_5_05_02_00_setuplinux,
then I've created new bootable sd-card with linux and booted up from it.
After it I stop matrix gui and pvr as:
/etc/init.d/matrix-gui-e stop
/etc/init.d/pvr-init stop
and run app
./capture_encode_a8host_debug.xv5T -o my.h264 -m 1080p -f 60 -b 1000000 -d 1 -n 500
output file: my.h264
bit_rate: 1000000
frame_rate: 60
num_frames: 500
mode: 1080p
display_id: 1
Capture-Encode example
OMX_Init completed
UIAClient is ready to send a UIA configuration command
UIAClient received UIA_CONFIGURE_ACK
UIAClient is done sending requests
openeing file
capture compoenent is created
control TVP compoenent is created
Buffer Size computed: 3110400
set input port params (width = 1920, height = 1080)enable capture output port
got eventEnable/Disable Event
dei compoenent is created
set output port params (width = 1920, height = 1080)set output port params (width = 1920, height = 1080)set number of channelsset input resolutionset output resolutionenable dei input port
enable dei output port 0
enable dei output port 1
encoder compoenent is created
found handle 0x1244f8 for component OMX.TI.VPSSM3.VFDC
got display handle
found handle 0x128500 for component OMX.TI.VPSSM3.CTRL.DC
Buffer Size computed: 1728000
set input port params (width = 1920, height = 1080)setting input and output memory type to defaultenable input port
connect call for capture-Dei
connect call for dei- encoder
connect call for dei-display
got eventState changed to: OMX_StateIdle
Capture outport buffers allocated
Capture is in IDLE state
Dei input port use buffer done
DEI outport buffers allocated
DEI is in IDLE state
encoder input port use buffer done
encoder outport buffers allocated
Encoder state IDLE
ctrl-dc state IDLE
display buffers allocated
waiting for IDLEgot eventState changed to: OMX_StateIdle
display state IDLE
got eventState changed to: OMX_StateExecuting
display control state execute
display state execute
encoder state execute
dei state execute
capture state execute
But my LCD have just white screen!
Here is result of lsmod:
bufferclass_ti 4950 0
omaplfb 10794 0
pvrsrvkm 155618 2 bufferclass_ti,omaplfb
tlc59108 1545 0
ti81xxhdmi 17685 0
ti81xxfb 21979 2
vpss 74936 3 omaplfb,ti81xxhdmi,ti81xxfb
syslink 1133911 0
ipv6 214095 14
Of course, I check out my video source, camera is working!
I plug camera video out to composite in on board as depicted on pic:
Then I resolved to try one's luck with 4vl2 but I got error again!
My actions is:
1.
cd /usr/share/ti/ti-media-controller-utils/
./load-hd-firmware.sh stop
./load-hd-v4l2-firmware.sh start
2.
root@dm814x-evm:~# lsmod
Module Size Used by
tlc59108 1545 0
ti81xxhdmi 17685 0
ti81xxvin 20591 0
tvp7002 6429 1
ti81xxvo 21210 0
ti81xxfb 21979 0
vpss 74936 4 ti81xxhdmi,ti81xxvin,ti81xxvo,ti81xxfb
syslink 1133911 0
ipv6 214095 14
3.
root@dm814x-evm:~# ./saLoopBack
Driver Name: ti81xxvin
Driver bus info: TI81xx Platform
Driver is capable of doing capture
sh: can't create /sys/devices/platform/vpss/display0/enabled: nonexistent directory
saLoopBack:
Mode set is 0
Setting DV Preset failed
Many thanks for considering my request.
With best regards, Max!
