How to config HDMI core running as DVI mode?
I  make my  board  used CA8168  chip. I make internal HDMI port output as DVI port, but it cann't display anything on monitor from DVI port.
I can find only a little register  refered to DVI  in sprugx7-reference.pdf  document ,  how to modify TI81xx_hdmi.ko driver  to support DVI port?
It can not use HDMI to DVI convertor , because my board make HDMI port as DVI port  in hardware.
    We are planning to support switching from DVI to HDMI and vice versa in our future release in a proper way. For now,
    You can brute force DVI mode by clearing bit 0 of HDMI_CORE_HDMI_CTRL_OFFSET as follows...
    void SetDVIMode()
        unsigned int temp;
        temp = RD_MEM_32(HDMI_CORE_0_REGS + HDMI_CORE_HDMI_CTRL_OFFSET);
        temp =temp & 0xfffE;//Clear HDMI mode control bit to force DVI mode
        WR_MEM_32(HDMI_CORE_0_REGS + HDMI_CORE_HDMI_CTRL_OFFSET, temp);
    Alternatively you can use the terminal window and mem_util to read/write memory address 0x46c009bc and clear bit 0.
    Hardik Shah
