I am using DM8168 EVM + VC card and want to capture video from both HDMI IN ports.
I have successfully integrated the SII9135 video decoder and tested it for single channel (HDMI IN1, /dev/video0). I am facing issue with the configuration for HDMI IN2.
When I run the application ( with /dev/video4 and input index 0, however tried with others as well), I always get following errors. I have attached modified ti81xx_fb.c file here.
Can somebody please review and let me know if I am missing anything or configured incorrectly?
root@dm816x-evm:/home# ./saLoopBack
Driver Name: ti81xxvin
Driver bus info: TI81xx Platform
Driver<3>VPSS_DCTRL: venc 1 already stop
Instance Id: 0
oing capture
<7>ti81xxvin ti81xxvin: couldn't lookup sub device for the input index
Set input failed
* Framebuffer device registration for TI TI816x platforms
* Copyright (C) 2009 Texas Instruments Inc.
* Author: Yihe Hu <yihehu@ti.com>
* Some code and ideas taken from TI OMAP2 Platforms
* by Tomi Valkeinen.
* This program is free software; you can redistribute it and/or modify it
* under the terms of the GNU General Public License as published by the
* Free Software Foundation; either version 2 of the License, or (at your
* option) any later version.
* This program is distributed in the hope that it will be useful, but
* WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
* General Public License for more details.
* You should have received a copy of the GNU General Public License along
* with this program; if not, write to the Free Software Foundation, Inc.,
* 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
#include <linux/module.h>
#include <linux/kernel.h>
#include <linux/mm.h>
#include <linux/init.h>
#include <linux/platform_device.h>
#include <linux/bootmem.h>
#include <linux/io.h>
#include <linux/vps_capture.h>
#include <linux/ti81xxfb.h>
#include <linux/ti81xx.h>
#include <mach/hardware.h>
#include <mach/board-ti814x.h>
#include <mach/board-ti816x.h>
#include <asm/mach/map.h>
#if (defined(CONFIG_FB_TI81XX) || defined(CONFIG_FB_TI81XX_MODULE) || \
defined(CONFIG_ARCH_TI81XX))
#define HDVPSS_CAPTURE_INST0_BASE 0x48105500
#define HDVPSS_CAPTURE_INST0_SIZE 1024u
#define HDVPSS_CAPTURE_INST2_BASE 0x48105A00
#define HDVPSS_CAPTURE_INST2_SIZE 1024u
u8 ti81xx_card_name[] = "TI81xx_catalogue";
struct ti81xxvin_interface tvp7002_pdata = {
.clk_polarity = 0,
.hs_polarity = 0,
.vs_polarity = 1,
.fid_polarity = 0,
.sog_polarity = 0,
struct ti81xxvin_interface sii9135_pdata = {
.clk_polarity = 0,
.hs_polarity = 0,
.vs_polarity = 1,
.fid_polarity = 0,
.sog_polarity = 0,
static struct ti81xxvin_subdev_info hdvpss_capture_sdev_info[] = {
.name = SII9135_INST0,
.board_info = {
/* Modify the i2c address in driver file also */
I2C_BOARD_INFO(SII9135_INST0, 0x30),
.platform_data = &sii9135_pdata,
.vip_port_cfg = {
.ctrlChanSel = VPS_VIP_CTRL_CHAN_SEL_15_8,
.ancChSel8b = VPS_VIP_ANC_CH_SEL_DONT_CARE,
.pixClkEdgePol = VPS_VIP_PIX_CLK_EDGE_POL_FALLING,
.invertFidPol = 0,
.embConfig = {
.errCorrEnable = 1,
.srcNumPos = VPS_VIP_SRC_NUM_POS_DONT_CARE,
.isMaxChan3Bits = 0,
.disConfig = {
.fidSkewPostCnt = 0,
.fidSkewPreCnt = 0,
.lineCaptureStyle =
VPS_VIP_LINE_CAPTURE_STYLE_DONT_CARE,
.fidDetectMode =
VPS_VIP_FID_DETECT_MODE_DONT_CARE,
.actvidPol = VPS_VIP_POLARITY_DONT_CARE,
.vsyncPol = VPS_VIP_POLARITY_DONT_CARE,
.hsyncPol = VPS_VIP_POLARITY_DONT_CARE,
.video_capture_mode =
VPS_CAPT_VIDEO_CAPTURE_MODE_SINGLE_CH_NON_MUX_EMBEDDED_SYNC,
.video_if_mode = VPS_CAPT_VIDEO_IF_MODE_16BIT,
.input_data_format = FVID2_DF_YUV422P,
.name = SII9135_INST1,
.board_info = {
I2C_BOARD_INFO(SII9135_INST1, 0x31),
.vip_port_cfg = {
.pixClkEdgePol = VPS_VIP_PIX_CLK_EDGE_POL_RISING,
.invertFidPol = 0,
.embConfig = {
.errCorrEnable = 1,
.disConfig = {
.fidSkewPreCnt = 0,
.lineCaptureStyle =
.fidDetectMode =
#if defined(CONFIG_VIDEO_TVP7002_MODULE) || defined(CONFIG_VIDEO_TVP7002)
.name = TVP7002_INST0,
.board_info = {
/* TODO Find the correct address
of the TVP7002 connected */
I2C_BOARD_INFO("tvp7002", 0x5d),
.platform_data = &tvp7002_pdata,
.vip_port_cfg = {
.invertFidPol = 0,
.embConfig = {
.errCorrEnable = 1,
.disConfig = {
.fidSkewPreCnt = 0,
.lineCaptureStyle =
.fidDetectMode =
.name = TVP7002_INST1,
.board_info = {
I2C_BOARD_INFO("tvp7002", 0x5c),
.vip_port_cfg = {
.invertFidPol = 0,
.embConfig = {
.errCorrEnable = 1,
.disConfig = {
.fidSkewPreCnt = 0,
.lineCaptureStyle =
.fidDetectMode =
#endif
/* tvp7002: inst0_inp0 */
static const struct v4l2_dv_preset hdvpss_inst0_inp0_presets[] = {
.preset = V4L2_DV_480P59_94,
.preset = V4L2_DV_720P60,
.preset = V4L2_DV_1080I60,
.preset = V4L2_DV_1080P60,
.preset = V4L2_DV_1080P30,
/* tvp7002: inst1_inp0 */
static const struct v4l2_dv_preset hdvpss_inst1_inp0_presets[] = {
/* sii9135: inst0_inp1 */
static const struct v4l2_dv_preset hdvpss_inst0_inp1_presets[] = {
/* sii9135: inst1_inp1 */
static const struct v4l2_dv_preset hdvpss_inst1_inp1_presets[] = {
static const struct ti81xxvin_input hdvpss_inst0_inputs[] = {
.input = {
.index = 0,
.name = "hdmi",
.type = V4L2_INPUT_TYPE_CAMERA,
.std = V4L2_STD_UNKNOWN,
.capabilities = V4L2_OUT_CAP_PRESETS,
.subdev_name = SII9135_INST0,
.dv_presets = hdvpss_inst0_inp0_presets,
.num_dv_presets = ARRAY_SIZE(hdvpss_inst0_inp0_presets),
.input = {
.index = 1,
.name = "hdmi",
.subdev_name = SII9135_INST1,
.dv_presets = hdvpss_inst1_inp1_presets,
.num_dv_presets = ARRAY_SIZE(hdvpss_inst1_inp1_presets),
static const struct ti81xxvin_input hdvpss_inst1_inputs[] = {
.input = {
.index = 0,
.name = "hdmi",
.num_dv_presets = ARRAY_SIZE(hdvpss_inst1_inp0_presets),
/* 16 bit decoders are present on the Port A of VIP0 and VIP1 instances. Which
represents the VIP0 and VIP2 instances in software. While Port B of VIP0 and
VIP1 are represented by VIP1 and VIP3 instances. On these two instances no
decoders are present.
static struct ti81xxvin_config ti81xx_hsvpss_capture_cfg = {
.subdev_info = hdvpss_capture_sdev_info,
.subdev_count = ARRAY_SIZE(hdvpss_capture_sdev_info),
.card_name = ti81xx_card_name,
.inst_config[0] = {
.inputs = hdvpss_inst0_inputs,
.input_count = ARRAY_SIZE(hdvpss_inst0_inputs),
.inst_config[1] = {
.input_count = 0,
.inst_config[2] = {
.inputs = hdvpss_inst1_inputs,
.input_count = ARRAY_SIZE(hdvpss_inst1_inputs),
.inst_config[3] = {
.input_count = 0,
static u64 ti81xx_fb_dma_mask = ~(u32)0;
static struct ti81xxfb_platform_data ti81xxfb_config;
static struct resource ti81xx_hdvpss_resource[] = {
[0] = {
.start = HDVPSS_CAPTURE_INST0_BASE,
.end = (HDVPSS_CAPTURE_INST0_BASE +
HDVPSS_CAPTURE_INST0_SIZE - 1),
.flags = IORESOURCE_MEM,
[1] = {
.start = HDVPSS_CAPTURE_INST2_BASE,
.end = (HDVPSS_CAPTURE_INST2_BASE +
HDVPSS_CAPTURE_INST2_SIZE - 1),
static struct platform_device ti81xx_fb_device = {
.name = "ti81xxfb",
.id = -1,
.dev = {
.dma_mask = &ti81xx_fb_dma_mask,
.coherent_dma_mask = ~(u32)0,
.platform_data = &ti81xxfb_config,
.num_resources = 0,
static struct platform_device hdvpss_capture_dev = {
.name = "ti81xxvin",
.id = -1,
.dev = {
.num_resources = 2,
.resource = ti81xx_hdvpss_resource,
void ti81xxfb_set_platform_data(struct ti81xxfb_platform_data *data)
ti81xxfb_config = *data;
static inline int ti81xx_init_fb(void)
int retval = 0;
retval = platform_device_register(&ti81xx_fb_device);
hdvpss_capture_dev.dev.platform_data = &ti81xx_hsvpss_capture_cfg;
if (cpu_is_ti814x()) {
hdvpss_capture_sdev_info[0].ti81xxvin_select_decoder =
vps_ti814x_select_video_decoder;
hdvpss_capture_sdev_info[0].ti81xxvin_set_mode =
vps_ti814x_set_tvp7002_filter;
hdvpss_capture_sdev_info[0].decoder_id = 0;
hdvpss_capture_sdev_info[1].ti81xxvin_select_decoder =
NULL;
hdvpss_capture_sdev_info[1].ti81xxvin_set_mode =
NULL;
hdvpss_capture_sdev_info[1].decoder_id = 0;
} else {
/* sii9135 */
NULL;
VPS_SEL_SII9135_DECODER_INST0;
NULL;
VPS_SEL_SII9135_DECODER_INST1;
/* tvp7002 */
hdvpss_capture_sdev_info[2].ti81xxvin_select_decoder =
hdvpss_capture_sdev_info[2].ti81xxvin_set_mode =
vps_ti816x_set_tvp7002_filter;
hdvpss_capture_sdev_info[2].decoder_id =
VPS_SEL_TVP7002_DECODER_INST0;
hdvpss_capture_sdev_info[3].ti81xxvin_select_decoder =
hdvpss_capture_sdev_info[3].ti81xxvin_set_mode =
NULL;
hdvpss_capture_sdev_info[3].decoder_id =
VPS_SEL_TVP7002_DECODER_INST1;
#endif
retval += platform_device_register(&hdvpss_capture_dev);
return retval;
arch_initcall(ti81xx_init_fb);
#endif
Krunal
