DVRRDK_02.00.00.24 link_api_demo can't work!
Other Parts Discussed in Thread: TVP5158
Hi all
    I run the 3 case of link_api_demo, but none of them can work.  following is the log message.
    // case 1
 Chain Select
 Current System Settings,
 NSF Mode              : SNF + TNF
 1: Multi  CH Capture + NSF     + DEI     + Display           (16CH 4x TVP5158, NTSC, YUV422I )
 2: Multi  CH Src + Enc + Dec + Snk (VideoM3 chain)           (VideoM3 local loopBack)
 3: Multi  CH Cap + NF + Enc + Dec + SW (DEI/H,SC5) + Disp    (16CH Cap+Enc+Dec+Disp, Interlace Enc/Dec)
 4: Multi  CH Cap + NF + DEI/H + Enc + Dec + SW (SC5) + Disp  (16CH Cap+Enc+Dec+Disp, Progressive Enc/Dec)
 s: System Settings
 x: Exit
 Enter Choice: 1
 10375: CHAINS  : CPU Revision [ES1.1] !!!
 10375: CHAINS  : Detected [(null)] Board !!!
 10375: CHAINS  : Base Board Revision [DVR] !!!
 10375: CHAINS  : Daughter Card Revision [DVR] !!!
Display 0: Layout: CHAINS_LAYOUT_2X2_PLUS_4CH
 [m3vpss ]  18604: Assertion @ Line: 701 in links_m3vpss/system/system_dctrl.c: retVal == FVID2_SOK : failed !!!
   // case 2
 Chain Select
 s: System Settings
 x: Exit
 Enter Choice: 2
 2718: CHAINS  : CPU Revision [ES1.1] !!!
 2718: CHAINS  : Detected [(null)] Board !!!
 2718: CHAINS  : Base Board Revision [DVR] !!!
 2718: CHAINS  : Daughter Card Revision [DVR] !!!
 [host] CHAINS:Enable file write :(y -- yes/n -- no):n
 [host] CHAINS_IPCBITS:Chains_ipcBitsSendFxn:Entered...
 [host] CHAINS_IPCBITS:Chains_ipcBitsRecvFxn:Entered... [m3vpss ]  13582: NULL_SRC: Create in progress !!!
 [m3vpss ]  13588: NULL_SRC: Create Done !!!
 [host] CHAINS_IPCBITS:Chains_ipcBitsSendFxn:INFO: periodic print.. [m3video]  13589: IPC_IN_M3   : Create in progress !!!
 [m3vpss ]  13588: IPC_OUT_M3   : Create in progress !!!
 [m3video]  13589: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
 [m3vpss ]  13589: IPC_OUT_M3   : Create Done !!!
 [m3video]  13590: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
 [m3video]  13592: IPC_IN_M3   : Create Done !!!
 [m3video]  13592: ENCODE: Create in progress ... !!!
 [m3video]  13773: ENCODE: Creating CH0 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
 [m3video] ENCLINK_H264:HEAPID:0        USED:13808
 [m3video] ENCLINK_H264:HEAPID:3        USED:45056
 [m3video]  13775: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
 [host] IpcBitsInLink_tskMain:Entered
 [host]  4939: IPC_BITS_IN   : Create in progress !!!
 [host]  4939: IPC_BITS_IN   : ListMPOpen start !!!
 [host]  4939: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_28] ...
 4940: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_28] ...
 [host]  4942: IPC_BITS_IN   : ListMPOpen done !!!
 [host]  4943: IPC_BITS_IN   : System_linkGetInfo done !!!
 [host]  4944: IPC_BITS_IN   : Create Done !!!
 [host]  4944: IPC_BITS_OUT   : Create in progress !!!
###Bit buff of size from the SR # 1 : 39813120
 [host] IPC_BITSOUT:BitBuffer Alloc.PoolID:0,Size:0x25F8000
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x2e56f080 To Phy:0x925f8080
 [host]  4944: IPC_BITS_OUT   : Create Done !!!
 [m3video] ENCLINK_H264:HEAPID:0        USED:11912
 [m3video]  13777: ENCODE: Creating CH2 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
 [m3video]  13780: ENCODE: Creating CH3 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
 [m3video]  13782: ENCODE: Creating CH4 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
 [m3video]  13784: ENCODE: Creating CH5 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
 [m3video]  13786: ENCODE: Creating CH6 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
 [m3video]  13788: ENCODE: Creating CH7 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
 [m3video]  13790: ENCODE: Creating CH8 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
 [m3video]  13792: ENCODE: Creating CH9 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
 [m3video]  13794: ENCODE: Creating CH10 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
 [m3video]  13797: ENCODE: Creating CH11 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
 [m3video]  13799: ENCODE: Creating CH12 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
 [m3video]  13801: ENCODE: Creating CH13 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
 [m3video]  13803: ENCODE: Creating CH14 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
 [m3video]  13805: ENCODE: Creating CH15 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
 [m3video]  13807: ENCODE: All CH Create ... DONE !!!
 [m3video] ENCLINK:HEAPID:0     USED:192608
 [m3video] ENCLINK:HEAPID:2     USED:39813120
 [m3video] ENCLINK:HEAPID:3     USED:720896
 [m3video]  13809: ENCODE: Create ... DONE !!!
 [m3video]  13809: IPC_BITS_OUT   : Create in progress !!!
 [m3video]  13811: IPC_BITS_OUT   : Create Done !!!
 [m3video]  13816: IPC_BITS_IN   : Create in progress !!!
 [m3video]  13816: SYSTEM: Opening ListMP [HOST_IPC_OUT_28] ...
 [m3video]  13817: SYSTEM: Opening ListMP [HOST_IPC_IN_28] ...
 [m3video]  13818: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
 [m3video]  13819: IPC_BITS_IN   : Create Done !!!
 [m3video]  13820: DECODE: Create in progress ... !!!
 [m3video] DECLINK_H264:HEAPID:0        USED:2368
 [m3video] DECLINK_H264:HEAPID:3        USED:4501504
 [m3video]  13845: DECODE: Creating CH0 of 720 x 480 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
 [m3video]  13869: DECODE: Creating CH1 of 720 x 480 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
 [m3video]  13893: DECODE: Creating CH2 of 720 x 480 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
 [m3video]  13916: DECODE: Creating CH3 of 720 x 480 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
 [m3video]  13940: DECODE: Creating CH4 of 720 x 480 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
 [m3vpss ]  14207: IPC_IN_M3   : Create in progress !!!
 [m3vpss ]  14208: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
 [m3video]  13964: DECODE: Creating CH5 of 720 x 480 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
 [m3vpss ]  14208: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
 [m3vpss ]  14208: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
 [m3vpss ]  14210: IPC_IN_M3   : Create Done !!!
 [m3vpss ]  14210: NULL   : Create Done !!!
 [m3video]  13988: DECODE: Creating CH6 of 720 x 480 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
 Chains Run-time Menu
 0: Stop Chain
 s: Switch Display Layout  (Sequential change of layout)
 c: Switch Display Channel (Sequential: Increments by 1)
 p: Print Capture Statistics
 b: Modify Encoder Bit Rate
 f: Modify Encoder Frame Rate
 r: Modify Intra Frame Interval(GOP)
 t: Toggle force IDR frame
 g: Print Encoder Dynamic Parameters
 i: Print IVA-HD Statistics
 m: Print SwMs Statistics
 a: Audio Capture / Playback
 Enter Choice:
 0: Stop Chain
 Enter Choice:  [m3vpss ]  14211: NULL_SRC: Start Done !!!
 [m3video]  14012: DECODE: Creating CH7 of 720 x 480 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
 [m3video]  14035: DECODE: Creating CH8 of 720 x 480 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
 [host] CHAINS_IPCBITS: Callback function:Chains_ipcBitsInCbFxn
 [host] CHAINS_IPCBITS:Leaving function:Chains_ipcBitsCopyBitBufInfo
 [host] BitBufInfo:virt:0x2bf77080,bufSize:414720,chnId:0,codecType:0,filledBufSize:1319,mvDataFilledSize:0,timeStamp:0,isKeyFrame:1,phy:90000080,width:720height:480
 [host] CHAINS_IPCBITS:Chains_ipcBitsRecvFxn:INFO: periodic print.. [m3video] DECLINK_H264:HEAPID:0     USED:2368
 [m3video]  14059: DECODE: Creating CH9 of 720 x 480 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
 [m3video]  14083: DECODE: Creating CH10 of 720 x 480 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
 [m3video]  14107: DECODE: Creating CH11 of 720 x 480 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
 [m3video]  14131: DECODE: Creating CH12 of 720 x 480 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
 [m3video]  14154: DECODE: Creating CH13 of 720 x 480 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
 [m3video]  14178: DECODE: Creating CH14 of 720 x 480 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
 [m3video]  14202: DECODE: Creating CH15 of 720 x 480 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
 [m3video]  14203: DECODE: All CH Create ... DONE !!!
 [m3video] DECLINK:HEAPID:0     USED:38008
 [m3video] DECLINK:HEAPID:3     USED:72024064
 [m3video]  14206: DECODE: Create ... DONE !!!
 [m3video]  14206: IPC_OUT_M3   : Create in progress !!!
 [m3video]  14207: IPC_OUT_M3   : Create Done !!!
 [m3video]  Channel:0 inputframerate:30 targetfps:30
 [m3video]  Channel:1 inputframerate:30 targetfps:30
 [m3video]  Channel:2 inputframerate:30 targetfps:30
 [m3video]  Channel:3 inputframerate:30 targetfps:30
 [m3video]  Channel:4 inputframerate:30 targetfps:30
 [m3video]  Channel:5 inputframerate:30 targetfps:30
 [m3video]  Channel:6 inputframerate:30 targetfps:30
 [m3video]  Channel:7 inputframerate:30 targetfps:30
 [m3video]  Channel:8 inputframerate:30 targetfps:30
 [m3video]  Channel:9 inputframerate:30 targetfps:30
 [m3video]  Channel:10 inputframerate:30 targetfps:30
 [m3video]  Channel:11 inputframerate:30 targetfps:30
 [m3video]  Channel:12 inputframerate:30 targetfps:30
 [m3video]  Channel:13 inputframerate:30 targetfps:30
 [m3video]  Channel:14 inputframerate:30 targetfps:30
 [m3video]  Channel:15 inputframerate:30 targetfps:30
 [host] BitBufInfo:virt:0x2cc1f080,bufSize:414720,chnId:0,codecType:0,filledBufSize:162,mvDataFilledSize:0,timeStamp:0,isKeyFrame:0,phy:90ca8080,width:720height:480
   // case 4
   root@dvr:/opt/dvr_rdk/ti816x# ./run_link_api.sh
 0: SYSTEM: System Common Init in progress !!!
 1: SYSTEM: IPC init in progress !!!
 13: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 14: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
 15: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
 17: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
 17: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
 18: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
 18: SYSTEM: Notify register to [DSP] line 0, event 15 ...
 19: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
 19: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
 19: SYSTEM: IPC init DONE !!!
 21: SYSTEM: Creating ListMP [HOST_IPC_OUT_28] in region 0 ...
 23: SYSTEM: Creating ListMP [HOST_IPC_IN_28] in region 0 ...
 24: SYSTEM: ListElem Shared Addr = 0x2b022280
 25: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
 27: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
 28: SYSTEM: ListElem Shared Addr = 0x2b03ee00
 29: SYSTEM: Creating ListMP [HOST_IPC_OUT_23] in region 0 ...
 31: SYSTEM: Creating ListMP [HOST_IPC_IN_23] in region 0 ...
 33: SYSTEM: ListElem Shared Addr = 0x2b05b980
 34: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
 36: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
 37: SYSTEM: ListElem Shared Addr = 0x2b07b380
 38: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
 40: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
 41: SYSTEM: ListElem Shared Addr = 0x2b09ad80
 60: SYSTEM: System Common Init Done !!!
 Chain Select
 s: System Settings
 x: Exit
 Enter Choice: 4
 2832: CHAINS  : CPU Revision [ES1.1] !!!
 2832: CHAINS  : Detected [(null)] Board !!!
 2832: CHAINS  : Base Board Revision [DVR] !!!
 2832: CHAINS  : Daughter Card Revision [DVR] !!!
 [host] CHAINS_IPCFRAMES:Chains_ipcFramesSendRecvFxn:Entered...
  • 哎,在中国论坛你也发了。。Ti支持很坑爹的。不过要开发还是要用mcfw_demo,我们现在就是用的这个,开发还是很方便的。
  • Dear Eric,
    The DVRRDK_02.00.00.24 version is released by UD Works. This version only supports the DVRGUI application. For MCFW demos please refer to DVRRDK_02.80.00.11 or DVRRDK_03.00.00.00
    Arun
    还能使用中文? 厉害,第一次发现:) 没法,广撒网,遇到问题自己一下解决不了了,还是要需求帮助。
  • Arun Menon said:
    Dear Eric,
    Arun
    Hi Arun
        I've signed  NDA with TI, how can i get the newest version of the DVRRDK?
