We use RDK4, DM8168.
I want to test the latency, I find a report about Performance Measurement Summary.
How to test the Ti, just like T4, T5?
Thanks very much for all your help.
Hi, Badri.
I invoke Vsys_printDetailedStatistics. The log is as following:
root@dm816x:/opt/dvr_rdk/ti816x/bin# ./hdcard20_app.out 0: SYSTEM: System Common Init in progress !!! 0: SYSTEM: IPC init in progress !!! 11: SYSTEM: CPU [DSP] syslink proc ID is [0] !!! 12: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!! 12: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!! 12: SYSTEM: CPU [HOST] syslink proc ID is [3] !!! 12: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_3] ... 14: SYSTEM: Creating MsgQ [HOST_MSGQ] ... 15: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ... 17: SYSTEM: Opening MsgQ [DSP_MSGQ] ... 17: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ... 18: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ... 18: SYSTEM: Notify register to [DSP] line 0, event 15 ... 19: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ... 20: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ... 20: SYSTEM: IPC init DONE !!! 21: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ... 23: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ... 24: SYSTEM: ListElem Shared Addr = 0x40663880 25: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ... 27: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ... 28: SYSTEM: ListElem Shared Addr = 0x40698a80 29: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ... 31: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ... 33: SYSTEM: ListElem Shared Addr = 0x406cdc80 33: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ... 35: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ... 37: SYSTEM: ListElem Shared Addr = 0x40710f80 38: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ... 40: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ... 41: SYSTEM: ListElem Shared Addr = 0x40754280 57: SYSTEM: System Common Init Done !!! Selected file write path [/opt] Opened file [/opt/VID_CH00.h264] for writing CH0 Opened file [/opt/VID_CH01.h264] for writing CH1 Opened file [/opt/VID_CH02.h264] for writing CH2 [m3vpss ] 82487: CAPTURE: Create in progress !!! [m3vpss ] 82516: CAPTURE: VIP0 PortA capture mode is [16-bit, Non-mux Discrete Sync - ACTVID_VSYNC] !!! [m3vpss ] 82807: CAPTURE: 0: 0xb0ba9480, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 82807: CAPTURE: 1: 0xb0f9dc80, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 82807: CAPTURE: 2: 0xb1392480, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 82807: CAPTURE: 3: 0xb1786c80, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 82807: CAPTURE: 4: 0xb1b7b480, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 82807: CAPTURE: 5: 0xb1f6fc80, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] UTILS: DMA: Allocated CH (TCC) = 58 (58) [m3vpss ] UTILS: DMA: 0 of 4: Allocated PaRAM = 58 (0x49004740) [m3vpss ] UTILS: DMA: 1 of 4: Allocated PaRAM = 64 (0x49004800) [m3vpss ] UTILS: DMA: 2 of 4: Allocated PaRAM = 65 (0x49004820) [m3vpss ] UTILS: DMA: 3 of 4: Allocated PaRAM = 66 (0x49004840) [m3vpss ] CAPTURE::HEAPID:0 USED:328 [m3vpss ] CAPTURE::HEAPID:4 USED:66355200 [m3vpss ] 82808: CAPTURE: Create Done !!! [m3vpss ] 82814: DUP : Create Done !!! [m3vpss ] 82814: DEI : Create in progress !!! [m3vpss ] 82917: DEI : Loading Down-scaling Co-effs [m3vpss ] 82917: DEI : Co-effs Loading ... DONE !!! [m3vpss ] DEI:HEAPID:0 USED:64 [m3vpss ] DEI:HEAPID:1 USED:4832 [m3vpss ] DEI:HEAPID:4 USED:21772800 [m3vpss ] 82917: DEI : Create Done !!! [m3vpss ] 82918: DEI : Create in progress !!! [m3vpss ] 83020: DEI : Loading Down-scaling Co-effs [m3vpss ] 83021: DEI : Co-effs Loading ... DONE !!! [m3vpss ] DEI:HEAPID:0 USED:64 [m3vpss ] DEI:HEAPID:1 USED:1312 [m3vpss ] DEI:HEAPID:4 USED:21772800 [m3vpss ] 83021: DEI : Create Done !!! [m3vpss ] 83021: DEI : Create in progress !!! [m3video] 83127: IPC_IN_M3 : Create in progress !!! [m3vpss ] 83124: DEI : Loading Down-scaling Co-effs [m3video] 83127: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ... [m3vpss ] 83124: DEI : Co-effs Loading ... DONE !!! [m3video] 83128: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ... [m3video] 83130: IPC_IN_M3 : Create Done !!! [m3video] 83130: ENCODE: Create in progress ... !!! [m3vpss ] DEI:HEAPID:0 USED:64 [m3vpss ] DEI:HEAPID:1 USED:4704 [m3vpss ] DEI:HEAPID:4 USED:21772800 [m3vpss ] 83125: DEI : Create Done !!! [m3vpss ] 83126: MERGE : Create Done !!! [m3vpss ] 83126: IPC_OUT_M3 : Create in progress !!! [m3vpss ] 83127: IPC_OUT_M3 : Create Done !!! [m3video] 83219: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps ... [m3video] ENCLINK_H264:HEAPID:0 USED:13808 [m3video] ENCLINK_H264:HEAPID:3 USED:7176192 [m3video] 83253: ENCODE: Creating CH1 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps ... [m3video] ENCLINK_H264:HEAPID:0 USED:11912 [m3video] ENCLINK_H264:HEAPID:3 USED:7176192 [m3video] 83288: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps ... [host] IpcBitsInLink_tskMain:Entered [host] 899: IPC_BITS_IN : Create in progress !!! [host] 899: IPC_BITS_IN : ListMPOpen start !!! [host] 899: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_24] ... 900: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_24] ... [host] 902: IPC_BITS_IN : ListMPOpen done !!! [host] 902: IPC_BITS_IN : System_linkGetInfo done !!! [host] 903: IPC_BITS_IN : Create Done !!! registerOMs success! [host] IpcBitsInLink_tskMain:Entered [m3vpss ] 83331: CAPTURE: Start in progress !!! [m3video] ENCLINK_H264:HEAPID:0 USED:11912 [m3video] ENCLINK_H264:HEAPID:3 USED:7176192 [m3video] 83322: ENCODE: All CH Create ... DONE !!! [m3video] ENCLINK:HEAPID:0 USED:37752 [m3video] ENCLINK:HEAPID:2 USED:18662400 [m3video] ENCLINK:HEAPID:3 USED:21528576 [m3video] 83323: ENCODE: Create ... DONE !!! [m3video] 83324: IPC_BITS_OUT : Create in progress !!! [m3video] 83325: IPC_BITS_OUT : Create Done !!! [m3vpss ] 83431: CAPTURE: Enabled Time Stamping !!! Disable Channel: 0 Disable Channel: 1 Disable Channel: 2 [m3vpss ] 83439: CAPTURE: Start Done !!! [m3vpss ] [m3vpss ] *** Capture Driver Advanced Statistics *** [m3vpss ] [m3vpss ] VIP Parser Reset Count : 0 [m3vpss ] [m3vpss ] | Total Even Odd Total Even Odd Min / Max Min / Max Dropped Fid Repeat Frame Error Y/C [m3vpss ] CH | Fields Fields Fields FPS FPS FPS Width Height Fields Count (Desc Error Y/C) [m3vpss ] ------------------------------------------------------------------------------------------------------------ [m3vpss ] [m3vpss ] VIP Capture Port 0 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0 [m3vpss ] [m3vpss ] *** Capture List Manager Advanced Statistics *** [m3vpss ] [m3vpss ] List Post Count : 1 [m3vpss ] List Stall Count : 0 [m3vpss ] List Post Time (ms) : Max = 0, Min = 0, Avg = 0, Total = 0 [m3vpss ] INTC Timeout Count : (0, 0) (Min timeout value = 993, 1000) [m3vpss ] Descriptor miss found count : 0 [m3vpss ] [m3vpss ] [m3vpss ] VIP and VPDMA registers, [m3vpss ] VIP0 : FIQ_STATUS : 0x4810551c = 0x00000000 [m3vpss ] VIP1 : FIQ_STATUS : 0x48105a1c = 0x00000000 [m3vpss ] VPDMA: LIST_BUSY : 0x4810d00c = 0x00000000 [m3vpss ] [m3vpss ] [m3vpss ] 83442: CAPTURE: Fields = 0 (fps = 0, CPU Load = 0) [m3vpss ] 83442: CAPTURE: Num Resets = 0 (Avg 0 ms per reset) [m3vpss ] 83442: SYSTEM : FREE SPACE : System Heap = 67856 B, Mbx = 10239 msgs) [m3vpss ] 83442: SYSTEM : FREE SPACE : SR0 Heap = 8713728 B (8 MB) [m3vpss ] 83442: SYSTEM : FREE SPACE : Frame Buffer = 121146752 B (115 MB) [m3vpss ] 83442: SYSTEM : FREE SPACE : Bitstream Buffer = 192101248 B (183 MB) [m3vpss ] TILER_STATS: CNT :8BIT [m3vpss ] TILER_STATS: CNT RESOLUTION: 16384 x 8192 [m3vpss ] TILER_STATS: BUCKET RESOLUTION: 16384 x 8188 [m3vpss ] TILER_STATS: NUM FREE BUCKETS: 1 [m3vpss ] TILER_STATS: NUM USED BUCKETS: 0 [m3vpss ] TILER_STATS: TOTAL FREE AREA: 134152192 (99 %) [m3vpss ] TILER_STATS: TOTAL USED AREA: 0 (0 %) [m3vpss ] TILER_STATS: CNT :16BIT [m3vpss ] TILER_STATS: CNT RESOLUTION: 32768 x 3072 [m3vpss ] TILER_STATS: BUCKET RESOLUTION: 32768 x 3072 [m3vpss ] TILER_STATS: NUM FREE BUCKETS: 1 [m3vpss ] TILER_STATS: NUM USED BUCKETS: 0 [m3vpss ] TILER_STATS: TOTAL FREE AREA: 100663296 (100 %) [m3vpss ] TILER_STATS: TOTAL USED AREA: 0 (0 %) [m3vpss ] 83443: SYSTEM : FREE SPACE : Tiler 8-bit = 134152192 B (127 MB) - TILER ON [m3vpss ] 83444: SYSTEM : FREE SPACE : Tiler 16-bit = 100663296 B (96 MB) - TILER ON [m3vpss ] [m3vpss ] *** [DEI0 ] DEI Statistics *** [m3vpss ] [m3vpss ] Elasped Time : 0 secs [m3vpss ] Total Fields Processed : 0 [m3vpss ] Total Fields FPS : 0 FPS [m3vpss ] [m3vpss ] [m3vpss ] CH | In Recv In Reject In Process Out[0] Out[1] Out[2] Out[3] Out[4] Skip Out[0] Skip Out[1] Skip Out[2] Skip Out[3] Skip Out[4] User Out[0] User Out[1] User Out[2] User Out[3] User Out[4] Latency [m3vpss ] Num | FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS Skip FPS Skip FPS Skip FPS Skip FPS Skip FPS Min / Max [m3vpss ] ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- [m3vpss ] 0 | 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 255 / 0 [m3vpss ] [m3vpss ] [m3vpss ] *** [DEI1 ] DEI Statistics *** [m3vpss ] [m3vpss ] Elasped Time : 0 secs [m3vpss ] Total Fields Processed : 0 [m3vpss ] Total Fields FPS : 0 FPS [m3vpss ] [m3vpss ] [m3vpss ] CH | In Recv In Reject In Process Out[0] Out[1] Out[2] Out[3] Out[4] Skip Out[0] Skip Out[1] Skip Out[2] Skip Out[3] Skip Out[4] User Out[0] User Out[1] User Out[2] User Out[3] User Out[4] Latency [m3vpss ] Num | FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS Skip FPS Skip FPS Skip FPS Skip FPS Skip FPS Min / Max [m3vpss ] ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- [m3vpss ] 0 | 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 255 / 0 [m3vpss ] [m3vpss ] [m3vpss ] *** [DEI2 ] DEI Statistics *** [m3vpss ] [m3vpss ] Elasped Time : 0 secs [m3vpss ] Total Fields Processed : 0 [m3vpss ] Total Fields FPS : 0 FPS [m3vpss ] [m3vpss ] [m3vpss ] CH | In Recv In Reject In Process Out[0] Out[1] Out[2] Out[3] Out[4] Skip Out[0] Skip Out[1] Skip Out[2] Skip Out[3] Skip Out[4] User Out[0] User Out[1] User Out[2] User Out[3] User Out[4] Latency [m3vpss ] Num | FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS Skip FPS Skip FPS Skip FPS Skip FPS Skip FPS Min / Max [m3vpss ] ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- [m3vpss ] 0 | 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 255 / 0 [m3vpss ] [m3video] 89449: HDVICP-ID:0 [m3video] All percentage figures are based off totalElapsedTime [m3video] totalAcquire2wait :0 % [m3video] totalWait2Isr :65 % [m3video] totalIsr2Done :0 % [m3video] totalWait2Done :65 % [m3video] totalDone2Release :0 % [m3video] totalAcquire2Release :67 % [m3video] totalAcq2acqDelay :32 % [m3video] totalElapsedTime in msec : 5935 [m3video] numAccessCnt: 356 [m3video] IVA-FPS : 71 [m3video] Average time spent per frame in microsec: 10836 [m3video] 89450: HDVICP-ID:1 [m3video] All percentage figures are based off totalElapsedTime [m3video] totalAcquire2wait :0 % [m3video] totalWait2Isr :0 % [m3video] totalIsr2Done :0 % [m3video] totalWait2Done :0 % [m3video] totalDone2Release :0 % [m3video] totalAcquire2Release :0 % [m3video] totalAcq2acqDelay :0 % [m3video] totalElapsedTime in msec : 0 [m3video] numAccessCnt: 0 [m3video] IVA-FPS : 0 [m3video] Average time spent per frame in microsec: 0 [m3video] 89450: HDVICP-ID:2 [m3video] All percentage figures are based off totalElapsedTime [m3video] totalAcquire2wait :0 % [m3video] totalWait2Isr :0 % [m3video] totalIsr2Done :0 % [m3video] totalWait2Done :0 % [m3video] totalDone2Release :0 % [m3video] totalAcquire2Release :0 % [m3video] totalAcq2acqDelay :0 % [m3video] totalElapsedTime in msec : 0 [m3video] numAccessCnt: 0 [m3video] IVA-FPS : 0 [m3video] Average time spent per frame in microsec: 0 [m3video] [m3video] *** ENCODE Statistics *** [m3video] [m3video] Elasped Time : 5 secs [m3video] [m3video] [m3video] CH | In Recv In Skip In User Out Latency [m3video] Num | FPS FPS Skip FPS FPS Min / Max [m3video] -------------------------------------------- [m3video] 0 | 70 0 0 70 255 / 82532 [m3video] 1 | 70 0 70 0 255 / 0 [m3video] 2 | 70 0 70 0 255 / 0 [m3video] [m3video] Multi Channel Encode Average Submit Batch Size [m3video] Max Submit Batch Size : 24 [m3video] IVAHD_0 Average Batch Size : 1 [m3video] IVAHD_0 Max achieved Batch Size : 1 [m3video] IVAHD_1 Average Batch Size : 0 [m3video] IVAHD_1 Max achieved Batch Size : 0 [m3video] IVAHD_2 Average Batch Size : 0 [m3video] IVAHD_2 Max achieved Batch Size : 0 [m3video] [m3video] Multi Channel Encode Batch break Stats [m3video] Total Number of Batches created: 353 [m3video] All numbers are based off total number of Batches created [m3video] Batch breaks due to batch sizeexceeding limit: 100 % [m3video] Batch breaks due to ReqObj Que being empty: 0 % [m3video] Batch breaks due to changed resolution class: 0 % [m3video] Batch breaks due to interlace and progressivecontent mix: 0 % [m3video] Batch breaks due to channel repeat: 0 % [m3video] Batch breaks due to different codec: 0 % [m3video] Total Number of Batches created: 0 [m3video] All numbers are based off total number of Batches created [m3video] Batch breaks due to batch sizeexceeding limit: 0 % [m3video] Batch breaks due to ReqObj Que being empty: 0 % [m3video] Batch breaks due to changed resolution class: 0 % [m3video] Batch breaks due to interlace and progressivecontent mix: 0 % [m3video] Batch breaks due to channel repeat: 0 % [m3video] Batch breaks due to different codec: 0 % [m3video] Total Number of Batches created: 0 [m3video] All numbers are based off total number of Batches created [m3video] Batch breaks due to batch sizeexceeding limit: 0 % [m3video] Batch breaks due to ReqObj Que being empty: 0 % [m3video] Batch breaks due to changed resolution class: 0 % [m3video] Batch breaks due to interlace and progressivecontent mix: 0 % [m3video] Batch breaks due to channel repeat: 0 % [m3video] Batch breaks due to different codec: 0 % [m3video] 89454:DECLINK::links_m3video/iva_dec/decLink_tsk.c:[33]::INTERNAL ERROR:-8 [m3video] Link create should be first cmd.Received Cmd:8196 [m3vpss ] [m3vpss ] 92455: LOAD: CPU: 8.7% HWI: 1.1%, SWI:0.9% [m3vpss ] [m3vpss ] 92455: LOAD: TSK: IPC_OUT_M30 : 1.2% [m3vpss ] 92455: LOAD: TSK: CAPTURE : 0.4% [m3vpss ] 92455: LOAD: TSK: DEI0 : 1.0% [m3vpss ] 92455: LOAD: TSK: DEI1 : 1.1% [m3vpss ] 92455: LOAD: TSK: DEI2 : 0.9% [m3vpss ] 92455: LOAD: TSK: DUP0 : 0.3% [m3vpss ] 92456: LOAD: TSK: MERGE0 : 0.4% [m3vpss ] 92456: LOAD: TSK: MISC : 1.4% [m3vpss ] [m3video] [m3video] 92956: LOAD: CPU: 6.0% HWI: 1.0%, SWI:0.6% [m3video] [m3video] 92956: LOAD: TSK: IPC_IN_M30 : 0.7% [m3video] 92956: LOAD: TSK: IPC_BITS_OUT0 : 0.6% [m3video] 92957: LOAD: TSK: ENC0 : 1.5% [m3video] 92957: LOAD: TSK: ENC_PROCESS_TSK_0 : 1.4% [m3video] 92957: LOAD: TSK: MISC : 0.2% [m3video] [c6xdsp ] [c6xdsp ] 92373: LOAD: CPU: 0.2% HWI: 0.0%, SWI:0.0% [c6xdsp ] [c6xdsp ] 92373: LOAD: TSK: MISC : 0.2% [c6xdsp ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3video]
[m3video]
[m3video]
[m3video]
[m3video]
[m3video]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3video]
[m3video]
[m3video]
[c6xdsp ]
[c6xdsp ]
[c6xdsp ]
The usecase is capture-dei-enc.
I just find the latency of encode is 82532, is the latency from capture to encode?
What's the ldifferent of Elasped Time and latency ?
The dei latency time is Zero. And I can not find the latency of capture.
You are capturing logs when neither capture has captured any frames nor DEI has processed any frames. I don't understand from where encoder is receiving frames. Don't refer latency printed in encLink. It is not correct.+\You can measure total latency from capture to receiving the frames on A8 by getting difference between Avsync_getWallTime - pBitBuffer->timestamp.
Refer /dvr_rdk/demos/mcfw_api_demos/mcfw_demo/demo_vcap_venc_vdec_vdis_bits_rdwr.c
VcapVencVdecVdis_updateStatistics
latency = Avsync_getWallTime() - (((UInt64)pBuf->upperTimeStamp << 32) | (UInt64)pBuf->lowerTimeStamp);
if(latency > pChInfo->maxLatency)
pChInfo->maxLatency = latency;
if(latency < pChInfo->minLatency)
pChInfo->minLatency = latency;
Hi, Badri.
You mean if I change latency frome (pBuf->encodeTimestamp - pBuf->timestamp) to (Avsync_getWallTime() - (((UInt64)pBuf->upperTimeStamp << 32) | (UInt64)pBuf->lowerTimeStamp) ) in VcapVenc_bitsWriteMain.
The time is the latency frome capture to encode?
The time is the latency from capture to when you receive the frame on A8 after encoding.
