Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
DM816x EVM generates Kernel Panic when board is booted from NAND
Hi All ,
a/ I am able to load u-boot.noxip.bin [UBOOT] , uImage [KERNEL] & rd-jffs2.bin [JFFS file system] on NAND [Board is DM816x EVM]
b/ When i try to boot the EVM in NAND mode i am getting KERNEL PANIC message of
     //Only last part of kernel panic , please let me know if the entire log is required
ALSA device list:
  #0: TI81XX EVM
TCP cubic registered
NET: Registered protocol family 17
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
smartreflex smartreflex: Driver initialized
omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
ata1: SATA link down (SStatus 0 SControl 300)
ata2: SATA link down (SStatus 0 SControl 300)
Division by zero in kernel.
Backtrace:
[<c004abb8>] (dump_backtrace+0x0/0x110) from [<c039d8f4>] (dump_stack+0x18/0x1c)
 r7:c2eabe00 r6:c2f45000 r5:00000000 r4:00000000
[<c039d8dc>] (dump_stack+0x0/0x1c) from [<c004b3ac>] (__div0+0x18/0x20)
[<c004b394>] (__div0+0x0/0x20) from [<c01b35a4>] (Ldiv0+0x8/0x10)
[<c016db08>] (jffs2_do_fill_super+0x0/0x238) from [<c016e9e8>] (jffs2_fill_super+0xbc/0xd4)
 r7:00000001 r6:00000000 r5:c2eabe00 r4:c2f45000
[<c016e92c>] (jffs2_fill_super+0x0/0xd4) from [<c023b5f0>] (mount_mtd_aux+0x54/0xe8)
 r7:00000000 r6:00008000 r5:c2e5ce00 r4:c2eabe00
[<c023b59c>] (mount_mtd_aux+0x0/0xe8) from [<c023b6e0>] (mount_mtd_nr+0x5c/0x64)
 r7:00008000 r6:c0501928 r5:00000000 r4:c2f3fbc0
[<c023b684>] (mount_mtd_nr+0x0/0x64) from [<c023b828>] (mount_mtd+0x140/0x170)
 r7:c0501928 r6:00008000 r5:01f00003 r4:c2f3fbc0
[<c023b6e8>] (mount_mtd+0x0/0x170) from [<c016e6c0>] (jffs2_mount+0x1c/0x28)
[<c016e6a4>] (jffs2_mount+0x0/0x28) from [<c00ca658>] (vfs_kern_mount+0xac/0x1d8)
[<c00ca5ac>] (vfs_kern_mount+0x0/0x1d8) from [<c00ca7e0>] (do_kern_mount+0x3c/0xe0)
[<c00ca7a4>] (do_kern_mount+0x0/0xe0) from [<c00e0290>] (do_mount+0x68c/0x6ec)
 r9:00000000 r8:c2f3fbc0 r7:00000020 r6:00000000 r5:00000000
r4:00008000
[<c00dfc04>] (do_mount+0x0/0x6ec) from [<c00e037c>] (sys_mount+0x8c/0xcc)
[<c00e02f0>] (sys_mount+0x0/0xcc) from [<c0008f50>] (do_mount_root+0x28/0xc0)
 r7:c2c14000 r6:c0072de8 r5:c002ec44 r4:c2c14000
[<c0008f28>] (do_mount_root+0x0/0xc0) from [<c00091d4>] (mount_block_root+0x100/0x220)
 r4:c2c14000
[<c00090d4>] (mount_block_root+0x0/0x220) from [<c00093a0>] (mount_root+0xac/0xcc)
[<c00092f4>] (mount_root+0x0/0xcc) from [<c0009530>] (prepare_namespace+0x170/0x1d4)
 r4:c0522f64
[<c00093c0>] (prepare_namespace+0x0/0x1d4) from [<c00087c4>] (kernel_init+0x114/0x154)
 r5:c00086b0 r4:c0522f00
[<c00086b0>] (kernel_init+0x0/0x154) from [<c0072de8>] (do_exit+0x0/0x5e4)
 r5:c00086b0 r4:00000000
Backtrace:
[<c016bfcc>] (jffs2_do_mount_fs+0x0/0x648) from [<c016dc64>] (jffs2_do_fill_super+0x15c/0x238)
r4:00008000
 r4:c2c14000
 r4:c0522f64
Backtrace:
 r7:c2c24000 r6:00000080 r5:00000000 r4:00000080
r4:00008000
 r4:c2c14000
 r4:c0522f64
VFS: Mounted root (jffs2 filesystem) on device 31:3.
devtmpfs: error mounting -2
Freeing init memory: 208K
Kernel panic - not syncing: No init found.  Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
Backtrace:
 r7:00000013 r6:c0072de8 r5:c00086b0 r4:c0523750
[<c039d8dc>] (dump_stack+0x0/0x1c) from [<c039d958>] (panic+0x60/0x17c)
[<c039d8f8>] (panic+0x0/0x17c) from [<c003c5c8>] (init_post+0xa4/0xc4)
 r3:c2ea7a00 r2:00000000 r1:c05ba4e0 r0:c045bd1d
[<c003c524>] (init_post+0x0/0xc4) from [<c00087c8>] (kernel_init+0x118/0x154)
Please find below mentioned steps used to have EVM configured to boot from NAND :-
A) Loading the u-boot.noxip.bin (default available from prebuilts binary folder)
  1. mw.b 0x81000000 0xFF 0x260000
2. tftp 0x81000000 u-boot.noxip.bin
3. nand erase 0x0 0x260000
4. nandecc hw 2
5. nand write.i 0x81000000 0x0 0x260000
6. nandecc hw 0
B) Loading the Kernel image (uImage)
      1. tftp 0x81000000 uImage (Bytes transferred = 2566084 (2727c4 hex))
     2. nand erase 0x00280000 0x00440000
      3. nand write 0x81000000 0x00280000 0x272800 [ the size entered is made multiple of 0x800 to remove alignment error ]
C) Creating the JFFS file system
      I could not find any default rd-jffs2.bin file in the /home/ashish/ti-ezsdk_dm816x-evm_5_05_02_00 directory.
      Hence i tried below mentioned steps to create an JFFS file-system :-
     a/ Under /home/ashish/ti-ezsdk_dm816x-evm_5_05_02_00/filesystem directory there was two tar available :-
        arago-base-tisdk-image-dm816x-evm.tar.gz  [ rd-jffs2.bin was around 14MB ]
        ezsdk-dm816x-evm-rootfs.tar.gz                       [ rd-jffs2.bin was around approx 450MB ]
    b/  Untar the arago-base-tisdk-image-dm816x-evm.tar.gz under /home/ashish/test.
         Then created JFFS file system by :-
          sudo mkfs.jffs2 -lqn –e 128 -r /home/ashish/test -o /tftpboot/rd-jffs2.bin
D) Loading the NANAD JFFS file system
     a. mw.b 0x81000000 0xFF 0x0C820000
     b. tftp 0x81000000 rd-jffs2.bin [ Bytes transferred = 14715080 (e088c8 hex) ]
     c. nand erase clean 0x006C0000 0x0C820000
     d. nand write 0x81000000 0x006C0000 0xe09000 [ the size entered is made multiple of 0x800 to remove alignment error ]
     e. console=ttyO2,115200n8 root=/dev/mtdblock3 rw rootfstype=jffs2 mem=100M earlyprintk
         setenv bootcmd 'nand read 0x81000000 0x00280000 0x272800;bootm 0x81000000'   [ 0x272800 as mentioned in B.3]
ould you please help me to figure what mistake i am doing .
Thank You,
Ashish Kumar Mishra
