Other Parts Discussed in Thread: OMAP-L138, OMAPL138
When writing data to a Micron NAND (specifically the MT29F4G08ABADAWP - which is a 4 Gigabit 8 bit interface) we're seeing the following OOB:
We now have over several thousand units in the field and am starting to see NAND issues. The issue is that after a power cycle, they are getting “Bad CRC: Kernel Image not found”. When U-Boot reads in the Linux partition, the CRC calculation fails and so the unit doesn’t come up. When we get this error, we read the OMAP NAND Flash Status Register in EMIFA module NAND Flash Status Register (NANDFSR) we consistently see 0x30103 and 0x30303. Both are bad, consistently 4+ errors, most of the time not correctable.
We do have a work-around, dual kernel images, however, we need to get to the bottom of WHY this is happening.
We’ve looked in it and think the problem is with the ECC calculations in U-Boot NAND driver. Looking at the Micron device MT29F4G08ABADAWP (8 bit wide 4 Gigabit flash) the ECC byte location didn’t seem to be written correctly. They didn’t match with Micron’s spec with the device.
The change we made in the code to “fix” this (e.g. make the data match the data sheet) are:
./drivers/mtd/nand/davinci_nand.c:
static struct nand_ecclayout nand_davinci_4bit_layout_oobfirst = {
#if defined(CONFIG_SYS_NAND_PAGE_2K)
.eccbytes = 32,
.eccpos = {
8, 9, 10, 11, 12, 13, 14, 15,
24, 25, 26, 27, 28, 29, 30, 31,
40, 41, 42, 43, 44, 45, 46, 47,
56, 57, 58, 59, 60, 61, 62, 63,
.oobfree = {
{.offset = 0, .length = 0, },
#if 0
// bgg - orig
.eccbytes = 40,
.eccpos = {
24, 25, 26, 27, 28,
29, 30, 31, 32, 33, 34, 35, 36, 37, 38,
39, 40, 41, 42, 43, 44, 45, 46, 47, 48,
49, 50, 51, 52, 53, 54, 55, 56, 57, 58,
59, 60, 61, 62, 63,
.oobfree = {
{.offset = 2, .length = 22, },
#endif
Using the following commands from U-Boot to write a page of data containing only the byte 0x34:
mw c0700000 0x34343434 512
nand erase 0 20000
nand write.e c0700000 0 800
Then examining the data using:
nand dump 0
The results are make the ECC data look like the following:
U-Boot > nand dump 0
bgg - made it to nand_print_info...
nand_read_page_raw_syndrome: page:0 Page 00000000 dump:
34 34 34 34 34 34 34 34 34 34 34 34 34 34 34 34
OOB:
ff ff ff ff ff ff ff ff
ad a8 f7 f5 ab c1 0e 19
U-Boot >
Performing this test WITHOUT the change yields the following OOB block:
Page 00000000 dump:
OOB:
e3 de ad a8 f7 f5 ab c1
0e 19 e3 de ad a8 f7 f5
ab c1 0e 19 e3 de ad a8
f7 f5 ab c1 0e 19 e3 de
U-Boot >
The question is: What is the layout of the OOB supposed to look like?
This is a critical problem, please help..!
Bill
