Build errors while using codec engine examples with custom DSP library
               We are trying to work with videodec_copy in codec engine examples. When we are building the codecs for videodec_copy it is generating " viddec_copy.a64P, viddec_copy.a64P.mak, viddec_copy.av5T, viddec_copy.av5T.mak ". Then we are building the servers and then the application, it is working fine.
               We took the same source files present in viddec_copy to CCS and generated the viddec_copy.a64P and by placing that in codecs/lib folder it is working fine.
The probem is........
               We are not able to generate " viddec_copy.a64P.mak, viddec_copy.av5T, viddec_copy.av5T.mak " in CCS. When we give the CCS generated library in codecs lib replacing the original one it is working fine but when we remove viddec_copy.av5T we are geting error while bulding the applicaion.  We are getting the following error generated while building apps folder..
Info: Configuring engine named 'video_copy' from the info file for DSP server './video_copy.x64P',
          located in package 'ti.sdo.ce.examples.servers.video_copy.evm3530':
      Target app will look for the DSP server image 'video_copy.x64P' in its current directory.
      Adding codec 'viddec_copy' (ti.sdo.ce.examples.codecs.viddec_copy.VIDDEC_COPY), scratch groupId=0
      Adding codec 'videnc_copy' (ti.sdo.ce.examples.codecs.videnc_copy.VIDENC_COPY), scratch groupId=0
Info: Reading DSP memory map from the info file for DSP server './video_copy.x64P',
ti.sdo.ce.examples.codecs.videnc_copy.close() ...
    will link with ti.sdo.ce.examples.codecs.videnc_copy:lib/videnc_copy.av5T
    will link with ti.sdo.ce.examples.codecs.viddec_copy:lib/viddec_copy.av5T
js: "/home/omap/dvsdk_3_00_00_29/xdctools_3_10_03/packages/xdc/cfg/Main.xs", line 28: XDC runtime error: can't find the library 'lib/viddec_copy.av5T' specified by package ti.sdo.ce.examples.codecs.viddec_copy. It wasn't found along the path '/home/omap/dvsdk_3_00_00_29/codec_engine_2_20_01/examples;/home/omap/dvsdk_3_00_00_29/codec_engine_2_20_01/packages;/home/omap/dvsdk_3_00_00_29/xdais_6_20/packages;/home/omap/dvsdk_3_00_00_29/local_power_manager_1_20_01/packages;/home/omap/dvsdk_3_00_00_29/dsplink_1.51/packages;/home/omap/dvsdk_3_00_00_29/linuxutils_2_20/packages;/home/omap/dvsdk_3_00_00_29/framework_components_2_20_01/packages;/home/omap/dvsdk_3_00_00_29/biosutils_1_01_00/packages;/home/omap/dvsdk_3_00_00_29/bios_5_32_04/packages;/home/omap/dvsdk_3_00_00_29/xdctools_3_10_03/packages;/home/omap/dvsdk_3_00_00_29/xdctools_3_10_03/packages;..;'.
gmake: *** [package/cfg/ceapp_xv5T.c] Error 1
gmake: *** Deleting file `package/cfg/ceapp_xv5T.c'
gmake: *** [package/cfg/ceapp_xv5T.c] Deleting file `package/cfg/ceapp_xv5T.xdl'
gmake: *** [package/cfg/ceapp_xv5T.c] Deleting file `package/cfg/ceapp_xv5T.h'
js: "/home/omap/dvsdk_3_00_00_29/xdctools_3_10_03/packages/xdc/tools/Cmdr.xs", line 40: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
Why we need this viddec_copy.av5T ?
Thanks and Regards,
Bharath.M
  • I updated this article to add details about what you're seeing:
    http://tiexpressdsp.com/index.php?title=Codec_Engine_FAQ#Why_does_my_GPP-side_application_try_.28and_fail.21.29_to_link_in_a_DSP-side_library
    If you're modifying the viddec_copy example package to only provide a C64P lib (i.e. viddec_copy.a64P), it shouldn't return a library for any other target, so it's getLibs() fxn will need to be modified - an example is provided at the article above.
    Chris
    Thanks a lot for you help.
    After modifying package.xs only for .a64P , I could build servers and codecs sucessfully.
    But when i try to run application.. (..apps/video_copy/dualcpu/evm3530) , it is throwing the following error :
    XDCPATH="/home/omap/dvsdk_3_00_00_29/codec_engine_2_20_01/examples/ti/sdo/ce/examples/apps/video_copy/dualcpu/evm35         30/../../../../../../../..;/home/omap/dvsdk_3_00_00_29/codec_engine_2_20_01/packages;/home/omap/dvsdk_3_00_00_29/xd         ais_6_20/packages;/home/omap/dvsdk_3_00_00_29/local_power_manager_1_20_01/packages;/home/omap/dvsdk_3_00_00_29/dspl         ink_1.51/packages;/home/omap/dvsdk_3_00_00_29/linuxutils_2_20/packages;/home/omap/dvsdk_3_00_00_29/framework_compon         ents_2_20_01/packages;/home/omap/dvsdk_3_00_00_29/biosutils_1_01_00/packages;/home/omap/dvsdk_3_00_00_29/bios_5_32_         04/packages" /home/omap/dvsdk_3_00_00_29/xdctools_3_10_03/xs xdc.tools.configuro -c /home/omap/toolchain/arm-2007q3          -o ceapp \
                    -t gnu.targets.arm.GCArmv5T -p ti.platforms.evm3530 \
                    -b /home/omap/dvsdk_3_00_00_29/codec_engine_2_20_01/examples/ti/sdo/ce/examples/apps/video_copy/dua         lcpu/evm3530/../../../../../../../../config.bld ceapp.cfg
    making package.mak (because of package.bld) ...
    config.bld: Running the version from Codec Engine Examples.
    config.bld: loading user build configuration file /home/omap/dvsdk_3_00_00_29/codec_engine_2_20_01/examples/user.bl         d
    js: "/home/omap/dvsdk_3_00_00_29/xdctools_3_10_03/packages/gnu/targets/ITarget.xs", line 227: xdc.services.global.X         DCException: gnu.targets.UNDEFINED_EXECUTABLE: 'LONGNAME' must be defined for the target gnu.targets.arm.GCArmv5T
        "./package.bld", line 62
    gmake: *** [package.mak] Error 1
    gmake: *** Deleting file `package.mak'
    gmake: *** [ceapp/compiler.opt] Error 1
    I would like to build my application on ARM and library completely on DSP.
    Can you please suggest me where can i modify to run my library on DSP and application on ARM.
  • Check your XDCtools version, and also examples/user.bld.  In Codec Engine 2.23.01 (and also 2.22), the published examples/user.bld set the target's LONGNAME when its name is "GCArmv5T"; this works for me with XDCtools 3.10.03.
