CCS/TMS320C6748: McASP Starterware, additional buffer requirement for further processing.
Part Number: TMS320C6748
I have downloaded and ran the McASP Starterware program and successfully got it to input and output audio. My goal is to apply a filter to an incoming signal through the use of an FFT. As per the Starterware code, there are 3 transmit buffers and 3 receive buffers, would I be required to make another set of three buffers to process the data? To my understanding, if this was the case, the system would then be able to record, process and output in parallel.
Calum
For completeness please find the code I am working on below:
 * \file  mcaspPlayBk.c
 * \brief Sample application for McASP. This application loops back the input
 *        at LINE_IN of the EVM to the LINE_OUT of the EVM.
* Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/
*  Redistribution and use in source and binary forms, with or without
*  modification, are permitted provided that the following conditions
*  are met:
*    Redistributions of source code must retain the above copyright
*    Redistributions in binary form must reproduce the above copyright
*    documentation and/or other materials provided with the
*    distribution.
*    Neither the name of Texas Instruments Incorporated nor the names of
*  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
*  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
*  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
*  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
*  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
*  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
*  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
*  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
*  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
*  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
*  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "edma_event.h"
#include "interrupt.h"
#include "soc_C6748.h"
#include "hw_syscfg0_C6748.h"
#include "lcdkC6748.h"
#include "codecif.h"
#include "mcasp.h"
#include "aic31.h"
#include "edma.h"
#include "psc.h"
#include <string.h>
**                      INTERNAL MACRO DEFINITIONS
** Values which are configurable
/* Slot size to send/receive data */
#define SLOT_SIZE                             (16u)
/* Word size to send/receive data. Word size <= Slot size */
#define WORD_SIZE                             (16u)
/* Sampling Rate which will be used by both transmit and receive sections */
#define SAMPLING_RATE                         (48000u)
/* Number of channels, L & R */
#define NUM_I2S_CHANNELS                      (2u)
/* Number of samples to be used per audio buffer */
#define NUM_SAMPLES_PER_AUDIO_BUF             (24000u)
/* Number of buffers used per tx/rx */
#define NUM_BUF                               (3u)
/* Number of linked parameter set used per tx/rx */
#define NUM_PAR                               (2u)
/* Specify where the parameter set starting is */
#define PAR_ID_START                          (40u)
/* Number of samples in loop buffer */
#define NUM_SAMPLES_LOOP_BUF                  (10u)
/* AIC3106 codec address */
#define I2C_SLAVE_CODEC_AIC31                 (0x18u)
/* Interrupt channels to map in AINTC */
#define INT_CHANNEL_I2C                       (2u)
#define INT_CHANNEL_MCASP                     (2u)
#define INT_CHANNEL_EDMACC                    (2u)
/* McASP Serializer for Receive */
#define MCASP_XSER_RX                         (14u)
/* McASP Serializer for Transmit */
#define MCASP_XSER_TX                         (13u)
** Below Macros are calculated based on the above inputs
#define NUM_TX_SERIALIZERS                    ((NUM_I2S_CHANNELS >> 1) \
                                               + (NUM_I2S_CHANNELS & 0x01))
#define NUM_RX_SERIALIZERS                    ((NUM_I2S_CHANNELS >> 1) \
#define I2S_SLOTS                             ((1 << NUM_I2S_CHANNELS) - 1)
#define BYTES_PER_SAMPLE                      ((WORD_SIZE >> 3) \
                                               * NUM_I2S_CHANNELS)
#define AUDIO_BUF_SIZE                        (NUM_SAMPLES_PER_AUDIO_BUF \
                                               * BYTES_PER_SAMPLE)
#define TX_DMA_INT_ENABLE                     (EDMA3CC_OPT_TCC_SET(1) | (1 \
                                               << EDMA3CC_OPT_TCINTEN_SHIFT))
#define RX_DMA_INT_ENABLE                     (EDMA3CC_OPT_TCC_SET(0) | (1 \
#define PAR_RX_START                          (PAR_ID_START)
#define PAR_TX_START                          (PAR_RX_START + NUM_PAR)
** Definitions which are not configurable
#define SIZE_PARAMSET                         (32u)
#define OPT_FIFO_WIDTH                        (0x02 << 8u)
**                      INTERNAL FUNCTION PROTOTYPES
static void McASPErrorIsr(void);
static void McASPErrorIntSetup(void);
static void AIC31I2SConfigure(void);
static void McASPI2SConfigure(void);
static void McASPTxDMAComplHandler(void);
static void McASPRxDMAComplHandler(void);
static void EDMA3CCComplIsr(void);
static void I2SDataTxRxActivate(void);
static void I2SDMAParamInit(void);
static void ParamTxLoopJobSet(unsigned short parId);
static void BufferTxDMAActivate(unsigned int txBuf, unsigned short numSamples,
                                unsigned short parToUpdate,
                                unsigned short linkAddr);
static void BufferRxDMAActivate(unsigned int rxBuf, unsigned short parId,
                                unsigned short parLink);
**                      INTERNAL VARIABLE DEFINITIONS
static unsigned char loopBuf[NUM_SAMPLES_LOOP_BUF * BYTES_PER_SAMPLE] = {0};
** Transmit buffers. If any new buffer is to be added, define it here and
** update the NUM_BUF.
static unsigned char txBuf0[AUDIO_BUF_SIZE];
static unsigned char txBuf1[AUDIO_BUF_SIZE];
static unsigned char txBuf2[AUDIO_BUF_SIZE];
** Receive buffers. If any new buffer is to be added, define it here and
static unsigned char rxBuf0[AUDIO_BUF_SIZE];
static unsigned char rxBuf1[AUDIO_BUF_SIZE];
static unsigned char rxBuf2[AUDIO_BUF_SIZE];
** Next buffer to receive data. The data will be received in this buffer.
static volatile unsigned int nxtBufToRcv = 0;
** The RX buffer which filled latest.
static volatile unsigned int lastFullRxBuf = 0;
** The offset of the paRAM ID, from the starting of the paRAM set.
static volatile unsigned short parOffRcvd = 0;
** The offset of the paRAM ID sent, from starting of the paRAM set.
static volatile unsigned short parOffSent = 0;
** The offset of the paRAM ID to be sent next, from starting of the paRAM set.
static volatile unsigned short parOffTxToSend = 0;
** The transmit buffer which was sent last.
static volatile unsigned int lastSentTxBuf = NUM_BUF - 1;
**                      INTERNAL CONSTATNT DEFINITIONS
/* Array of receive buffer pointers */
static unsigned int rxBufPtr[NUM_BUF] =
           (unsigned int) rxBuf0,
           (unsigned int) rxBuf1,
           (unsigned int) rxBuf2
/* Array of transmit buffer pointers */
static unsigned int txBufPtr[NUM_BUF] =
           (unsigned int) txBuf0,
           (unsigned int) txBuf1,
           (unsigned int) txBuf2
** Default paRAM for Transmit section. This will be transmitting from
** a loop buffer.
static struct EDMA3CCPaRAMEntry const txDefaultPar =
           (unsigned int)(EDMA3CC_OPT_DAM  | (0x02 << 8u)), /* Opt field */
           (unsigned int)loopBuf, /* source address */
           (unsigned short)(BYTES_PER_SAMPLE), /* aCnt */
           (unsigned short)(NUM_SAMPLES_LOOP_BUF), /* bCnt */
           (unsigned int) SOC_MCASP_0_DATA_REGS, /* dest address */
           (short) (BYTES_PER_SAMPLE), /* source bIdx */
           (short)(0), /* dest bIdx */
           (unsigned short)(PAR_TX_START * SIZE_PARAMSET), /* link address */
           (unsigned short)(0), /* bCnt reload value */
           (short)(0), /* source cIdx */
           (short)(0), /* dest cIdx */
           (unsigned short)1 /* cCnt */
** Default paRAM for Receive section.
static struct EDMA3CCPaRAMEntry const rxDefaultPar =
           (unsigned int)(EDMA3CC_OPT_SAM  | (0x02 << 8u)), /* Opt field */
           (unsigned int)SOC_MCASP_0_DATA_REGS, /* source address */
           (unsigned short)(1), /* bCnt */
           (unsigned int)rxBuf0, /* dest address */
           (short) (0), /* source bIdx */
           (short)(BYTES_PER_SAMPLE), /* dest bIdx */
           (unsigned short)(PAR_RX_START * SIZE_PARAMSET), /* link address */
**                          FUNCTION DEFINITIONS
** Assigns loop job for a parameter set
    EDMA3CCPaRAMEntry paramSet;
    memcpy(&paramSet, &txDefaultPar, SIZE_PARAMSET - 2);
    /* link the paRAM to itself */
    paramSet.linkAddr = parId * SIZE_PARAMSET;
    EDMA3SetPaRAM(SOC_EDMA30CC_0_REGS, parId, &paramSet);
** Initializes the DMA parameters.
** The RX basic paRAM set(channel) is 0 and TX basic paRAM set (channel) is 1.
** The RX paRAM set 0 will be initialized to receive data in the rx buffer 0.
** The transfer completion interrupt will not be enabled for paRAM set 0;
** paRAM set 0 will be linked to linked paRAM set starting (PAR_RX_START) of RX.
** and further reception only happens via linked paRAM set.
** For example, if the PAR_RX_START value is 40, and the number of paRAMS is 2,
** reception paRAM set linking will be initialized as 0-->40-->41-->40
** The TX paRAM sets will be initialized to transmit from the loop buffer.
** The size of the loop buffer can be configured.
** The transfer completion interrupt will not be enabled for paRAM set 1;
** paRAM set 1 will be linked to linked paRAM set starting (PAR_TX_START) of TX.
** All other paRAM sets will be linked to itself.
** and further transmission only happens via linked paRAM set.
** For example, if the PAR_RX_START value is 42, and the number of paRAMS is 2,
** So transmission paRAM set linking will be initialized as 1-->42-->42, 43->43.
    int idx;
    /* Initialize the 0th paRAM set for receive */
    memcpy(&paramSet, &rxDefaultPar, SIZE_PARAMSET - 2);
    EDMA3SetPaRAM(SOC_EDMA30CC_0_REGS, EDMA3_CHA_MCASP0_RX, &paramSet);
    /* further paramsets, enable interrupt */
    paramSet.opt |= RX_DMA_INT_ENABLE;
    for(idx = 0 ; idx < NUM_PAR; idx++)
        paramSet.destAddr = rxBufPtr[idx];
        paramSet.linkAddr = (PAR_RX_START + ((idx + 1) % NUM_PAR))
                             * (SIZE_PARAMSET);
        paramSet.bCnt =  NUM_SAMPLES_PER_AUDIO_BUF;
        ** for the first linked paRAM set, start receiving the second
        ** sample only since the first sample is already received in
        ** rx buffer 0 itself.
        if( 0 == idx)
            paramSet.destAddr += BYTES_PER_SAMPLE;
            paramSet.bCnt -= BYTES_PER_SAMPLE;
        EDMA3SetPaRAM(SOC_EDMA30CC_0_REGS, (PAR_RX_START + idx), &paramSet);
    /* Initialize the required variables for reception */
    nxtBufToRcv = idx % NUM_BUF;
    lastFullRxBuf = NUM_BUF - 1;
    parOffRcvd = 0;
    /* Initialize the 1st paRAM set for transmit */
    memcpy(&paramSet, &txDefaultPar, SIZE_PARAMSET);
    EDMA3SetPaRAM(SOC_EDMA30CC_0_REGS, EDMA3_CHA_MCASP0_TX, &paramSet);
    /* rest of the params, enable loop job */
        ParamTxLoopJobSet(PAR_TX_START + idx);
    /* Initialize the variables for transmit */
    parOffSent = 0;
** Function to configure the codec for I2S mode
    volatile unsigned int delay = 0xFFF;
    AIC31Reset(SOC_I2C_0_REGS);
    while(delay--);
    /* Configure the data format and sampling rate */
    AIC31DataConfig(SOC_I2C_0_REGS, AIC31_DATATYPE_I2S, SLOT_SIZE, 0);
    AIC31SampleRateConfig(SOC_I2C_0_REGS, AIC31_MODE_BOTH, SAMPLING_RATE);
    /* Initialize both ADC and DAC */
    AIC31ADCInit(SOC_I2C_0_REGS);
    AIC31DACInit(SOC_I2C_0_REGS);
** Configures the McASP Transmit Section in I2S mode.
    McASPRxReset(SOC_MCASP_0_CTRL_REGS);
    McASPTxReset(SOC_MCASP_0_CTRL_REGS);
    /* Enable the FIFOs for DMA transfer */
    McASPReadFifoEnable(SOC_MCASP_0_FIFO_REGS, 1, 1);
    McASPWriteFifoEnable(SOC_MCASP_0_FIFO_REGS, 1, 1);
    /* Set I2S format in the transmitter/receiver format units */
    McASPRxFmtI2SSet(SOC_MCASP_0_CTRL_REGS, WORD_SIZE, SLOT_SIZE,
                     MCASP_RX_MODE_DMA);
    McASPTxFmtI2SSet(SOC_MCASP_0_CTRL_REGS, WORD_SIZE, SLOT_SIZE,
                     MCASP_TX_MODE_DMA);
    /* Configure the frame sync. I2S shall work in TDM format with 2 slots */
    McASPRxFrameSyncCfg(SOC_MCASP_0_CTRL_REGS, 2, MCASP_RX_FS_WIDTH_WORD,
                        MCASP_RX_FS_EXT_BEGIN_ON_FALL_EDGE);
    McASPTxFrameSyncCfg(SOC_MCASP_0_CTRL_REGS, 2, MCASP_TX_FS_WIDTH_WORD,
                        MCASP_TX_FS_EXT_BEGIN_ON_RIS_EDGE);
    /* configure the clock for receiver */
    McASPRxClkCfg(SOC_MCASP_0_CTRL_REGS, MCASP_RX_CLK_EXTERNAL, 0, 0);
    McASPRxClkPolaritySet(SOC_MCASP_0_CTRL_REGS, MCASP_RX_CLK_POL_RIS_EDGE);
    McASPRxClkCheckConfig(SOC_MCASP_0_CTRL_REGS, MCASP_RX_CLKCHCK_DIV32,
                          0x00, 0xFF);
    /* configure the clock for transmitter */
    McASPTxClkCfg(SOC_MCASP_0_CTRL_REGS, MCASP_TX_CLK_EXTERNAL, 0, 0);
    McASPTxClkPolaritySet(SOC_MCASP_0_CTRL_REGS, MCASP_TX_CLK_POL_FALL_EDGE);
    McASPTxClkCheckConfig(SOC_MCASP_0_CTRL_REGS, MCASP_TX_CLKCHCK_DIV32,
                          0x00, 0xFF);
    /* Enable synchronization of RX and TX sections  */
    McASPTxRxClkSyncEnable(SOC_MCASP_0_CTRL_REGS);
    /* Enable the transmitter/receiver slots. I2S uses 2 slots */
    McASPRxTimeSlotSet(SOC_MCASP_0_CTRL_REGS, I2S_SLOTS);
    McASPTxTimeSlotSet(SOC_MCASP_0_CTRL_REGS, I2S_SLOTS);
    ** Set the serializers, Currently only one serializer is set as
    ** transmitter and one serializer as receiver.
    McASPSerializerRxSet(SOC_MCASP_0_CTRL_REGS, MCASP_XSER_RX);
    McASPSerializerTxSet(SOC_MCASP_0_CTRL_REGS, MCASP_XSER_TX);
    ** Configure the McASP pins
    ** Input - Frame Sync, Clock and Serializer Rx
    ** Output - Serializer Tx is connected to the input of the codec
    McASPPinMcASPSet(SOC_MCASP_0_CTRL_REGS, 0xFFFFFFFF);
    McASPPinDirOutputSet(SOC_MCASP_0_CTRL_REGS, MCASP_PIN_AXR(MCASP_XSER_TX));
    McASPPinDirInputSet(SOC_MCASP_0_CTRL_REGS, MCASP_PIN_AFSX
                                               | MCASP_PIN_ACLKX
                                               | MCASP_PIN_AFSR
                                               | MCASP_PIN_ACLKR
                                               | MCASP_PIN_AXR(MCASP_XSER_RX));
    /* Enable error interrupts for McASP */
    McASPTxIntEnable(SOC_MCASP_0_CTRL_REGS, MCASP_TX_DMAERROR
                                            | MCASP_TX_CLKFAIL
                                            | MCASP_TX_SYNCERROR
                                            | MCASP_TX_UNDERRUN);
    McASPRxIntEnable(SOC_MCASP_0_CTRL_REGS, MCASP_RX_DMAERROR
                                            | MCASP_RX_CLKFAIL
                                            | MCASP_RX_SYNCERROR
                                            | MCASP_RX_OVERRUN);
** Sets up the interrupts for EDMA in AINTC
static void EDMA3IntSetup(void)
#ifdef _TMS320C6X
	IntRegister(C674X_MASK_INT5, EDMA3CCComplIsr);
	IntEventMap(C674X_MASK_INT5, SYS_INT_EDMA3_0_CC0_INT1);
	IntEnable(C674X_MASK_INT5);
#else
    IntRegister(SYS_INT_CCINT0, EDMA3CCComplIsr);
    IntChannelSet(SYS_INT_CCINT0, INT_CHANNEL_EDMACC);
    IntSystemEnable(SYS_INT_CCINT0);
#endif
** Sets up the error interrupts for McASP in AINTC
#ifdef _TMS320C6X
	IntRegister(C674X_MASK_INT6, McASPErrorIsr);
	IntEventMap(C674X_MASK_INT6, SYS_INT_MCASP0_INT);
	IntEnable(C674X_MASK_INT6);
#else
    /* Register the error ISR for McASP */
    IntRegister(SYS_INT_MCASPINT, McASPErrorIsr);
    IntChannelSet(SYS_INT_MCASPINT, INT_CHANNEL_MCASP);
    IntSystemEnable(SYS_INT_MCASPINT);
#endif
** Activates the data transmission/reception
** The DMA parameters shall be ready before calling this function.
    /* Start the clocks */
    McASPRxClkStart(SOC_MCASP_0_CTRL_REGS, MCASP_RX_CLK_EXTERNAL);
    McASPTxClkStart(SOC_MCASP_0_CTRL_REGS, MCASP_TX_CLK_EXTERNAL);
    /* Enable EDMA for the transfer */
    EDMA3EnableTransfer(SOC_EDMA30CC_0_REGS, EDMA3_CHA_MCASP0_RX,
                        EDMA3_TRIG_MODE_EVENT);
                        EDMA3_CHA_MCASP0_TX, EDMA3_TRIG_MODE_EVENT);
    /* Activate the  serializers */
    McASPRxSerActivate(SOC_MCASP_0_CTRL_REGS);
    McASPTxSerActivate(SOC_MCASP_0_CTRL_REGS);
    /* make sure that the XDATA bit is cleared to zero */
    while(McASPTxStatusGet(SOC_MCASP_0_CTRL_REGS) & MCASP_TX_STAT_DATAREADY);
    /* Activate the state machines */
    McASPRxEnable(SOC_MCASP_0_CTRL_REGS);
    McASPTxEnable(SOC_MCASP_0_CTRL_REGS);
** Activates the DMA transfer for a parameterset from the given buffer.
                         unsigned short parId, unsigned short linkPar)
    /* Copy the default paramset */
    /* Enable completion interrupt */
    paramSet.opt |= TX_DMA_INT_ENABLE;
    paramSet.srcAddr =  txBufPtr[txBuf];
    paramSet.linkAddr = linkPar * SIZE_PARAMSET;
    paramSet.bCnt = numSamples;
** The main function. Application starts here.
int main(void)
    unsigned short parToSend;
    unsigned short parToLink;
    /* Set up pin mux for I2C module 0 */
    I2CPinMuxSetup(0);
    McASPPinMuxSetup();
    /* Power up the McASP module */
    PSCModuleControl(SOC_PSC_1_REGS, HW_PSC_MCASP0, PSC_POWERDOMAIN_ALWAYS_ON,
		     PSC_MDCTL_NEXT_ENABLE);
    /* Power up EDMA3CC_0 and EDMA3TC_0 */
    PSCModuleControl(SOC_PSC_0_REGS, HW_PSC_CC0, PSC_POWERDOMAIN_ALWAYS_ON,
    PSCModuleControl(SOC_PSC_0_REGS, HW_PSC_TC0, PSC_POWERDOMAIN_ALWAYS_ON,
#ifdef _TMS320C6X
    // Initialize the DSP interrupt controller
    IntDSPINTCInit();
#else
    /* Initialize the ARM Interrupt Controller.*/
    IntAINTCInit();
#endif
    /* Initialize the I2C 0 interface for the codec AIC31 */
    I2CCodecIfInit(SOC_I2C_0_REGS, INT_CHANNEL_I2C, I2C_SLAVE_CODEC_AIC31);
    EDMA3Init(SOC_EDMA30CC_0_REGS, 0);
    EDMA3IntSetup();
    McASPErrorIntSetup();
#ifdef _TMS320C6X
    IntGlobalEnable();
#else
    /* Enable the interrupts generation at global level */
    IntMasterIRQEnable();
    IntGlobalEnable();
    IntIRQEnable();
#endif
    ** Request EDMA channels. Channel 0 is used for reception and
    ** Channel 1 is used for transmission
    EDMA3RequestChannel(SOC_EDMA30CC_0_REGS, EDMA3_CHANNEL_TYPE_DMA,
                        EDMA3_CHA_MCASP0_TX, EDMA3_CHA_MCASP0_TX, 0);
                        EDMA3_CHA_MCASP0_RX, EDMA3_CHA_MCASP0_RX, 0);
    /* Initialize the DMA parameters */
    I2SDMAParamInit();
    /* Configure the Codec for I2S mode */
    AIC31I2SConfigure();
    /* Configure the McASP for I2S */
    McASPI2SConfigure();
    /* Activate the audio transmission and reception */
    I2SDataTxRxActivate();
    ** Loop forever. if a new buffer is received, the lastFullRxBuf will be
    ** updated in the rx completion ISR. if it is not the lastSentTxBuf,
    ** buffer is to be sent. This has to be mapped to proper paRAM set.
    while(1)
        if(lastFullRxBuf != lastSentTxBuf)
            ** Start the transmission from the link paramset. The param set
            ** 1 will be linked to param set at PAR_TX_START. So do not
            ** update paRAM set1.
            parToSend =  PAR_TX_START + (parOffTxToSend % NUM_PAR);
            parOffTxToSend = (parOffTxToSend + 1) % NUM_PAR;
            parToLink  = PAR_TX_START + parOffTxToSend;
            lastSentTxBuf = (lastSentTxBuf + 1) % NUM_BUF;
            /* Copy the buffer */
            memcpy((void *)txBufPtr[lastSentTxBuf],
                   (void *)pxBufPtr[lastFullRxBuf],
                   AUDIO_BUF_SIZE);
            ** Send the buffer by setting the DMA params accordingly.
            ** Here the buffer to send and number of samples are passed as
            ** parameters. This is important, if only transmit section
            ** is to be used.
            BufferTxDMAActivate(lastSentTxBuf, NUM_SAMPLES_PER_AUDIO_BUF,
                                (unsigned short)parToSend,
                                (unsigned short)parToLink);
** Activates the DMA transfer for a parameter set from the given buffer.
    paramSet.destAddr =  rxBufPtr[rxBuf];
    paramSet.linkAddr = parLink * SIZE_PARAMSET ;
** This function will be called once receive DMA is completed
    unsigned short nxtParToUpdate;
    ** Update lastFullRxBuf to indicate a new buffer reception
    ** is completed.
    lastFullRxBuf = (lastFullRxBuf + 1) % NUM_BUF;
    nxtParToUpdate =  PAR_RX_START + parOffRcvd;
    parOffRcvd = (parOffRcvd + 1) % NUM_PAR;
    ** Update the DMA parameters for the received buffer to receive
    ** further data in proper buffer
    BufferRxDMAActivate(nxtBufToRcv, nxtParToUpdate,
                        PAR_RX_START + parOffRcvd);
    /* update the next buffer to receive data */
    nxtBufToRcv = (nxtBufToRcv + 1) % NUM_BUF;
** This function will be called once transmit DMA is completed
    ParamTxLoopJobSet((unsigned short)(PAR_TX_START + parOffSent));
    parOffSent = (parOffSent + 1) % NUM_PAR;
** EDMA transfer completion ISR
#ifdef _TMS320C6X
	IntEventClear(SYS_INT_EDMA3_0_CC0_INT1);
#else
    IntSystemStatusClear(SYS_INT_CCINT0);
#endif
    /* Check if receive DMA completed */
    if(EDMA3GetIntrStatus(SOC_EDMA30CC_0_REGS) & (1 << EDMA3_CHA_MCASP0_RX))
        /* Clear the interrupt status for the 0th channel */
        EDMA3ClrIntr(SOC_EDMA30CC_0_REGS, EDMA3_CHA_MCASP0_RX);
        McASPRxDMAComplHandler();
    /* Check if transmit DMA completed */
    if(EDMA3GetIntrStatus(SOC_EDMA30CC_0_REGS) & (1 << EDMA3_CHA_MCASP0_TX))
        /* Clear the interrupt status for the first channel */
        EDMA3ClrIntr(SOC_EDMA30CC_0_REGS, EDMA3_CHA_MCASP0_TX);
        McASPTxDMAComplHandler();
** Error ISR for McASP
#ifdef _TMS320C6X
	IntEventClear(SYS_INT_MCASP0_INT);
#else
    IntSystemStatusClear(SYS_INT_MCASPINT);
#endif
    ; /* Perform any error handling here.*/
/***************************** End Of File ***********************************/
    I've notified the RTOS team. They will post their feedback directly here.
    Please share which SDK version are you using.
    Best Regards.
    Yordan
  • Hi Yordan,
    I am using Code Composer Studio 6.2.0.00050
    Calum
  • Calum,
    Starterrware is legacy software for this device that we are supporting for bare-metal and no-OS developers with existing projects using this software only. For any new development, we recommend using PRocessor SDK RTOS that provide software with an MCASP LLD driver with full RTOS integration.
    Having said that, your need to allocate additional scratch buffers to store intermediate values will depend on the algortihm that you are trying to insert in the audio path. If the algorithm simply takes in inputs processes it and then gives an output then you can use existing setup without any additonal buffer, but if you are computing FFT and then filtering the data and then computing inverse FFT to out put data or if you have to pass the input through a series of buffers then you may need to allocate additional buffers.
    I would recommend that you look at the fillowing TI Design for audio Equalization example on K2G to see how we have implemented the code. This design is integrated in the Processor SDK RTOS with MCASP examples here:
    processors.wiki.ti.com/.../Processor_SDK_RTOS_MCASP
    Rahul
  • Hi Rahul,
    Thank you for your reply. Do you have any advice on how I should go about learning to use the Processor SDK ROTS and if there are any guides/examples for me to use? I am an undergraduate and don't consider myself to be a strong programmer, so am finding the development to be quite difficult. I have browsed the Software Developer Guide as well as the Getting Started Guide for the Processor SDK RTOS but am struggling to fully understand the information that is being presented. Are you able to give me any information directly relating to the TMS320C6748 LCDK, audio processing, or anything similar.
    Calum
