I have a question regarding external filtering on the PLL supply. The datasheet for TMS320C6748 says designers should filter the PLLs' ground with a bead.
Is it right to have these grounds separated by a bead? If there is a path between PLLn_VSSA and VSS on the DSP's silicon, high-frequency voltage noise across this path could be a problem. The IC designer may keep grounds apart on the die but intend for the PCB designer to connect these together right at the part.
If this case is different, can anyone tell me why? It feels very weird to put an inductor on a ground line. I clearly understand the desire to keep digital noise off the PLL ground, BUT in my experience grounds are fully isolated within the IC, so filtering the ground pin makes the noise worse. I am open hearing how this case is different.
