SQLite Plugin for Qt5.4.1 AM335x Processor SDK
I'm currently moving our device from ti-sdk-am335x-evm-08.00.00.00 to ti-processor-sdk-linux-am335x-evm-01.00.00.03 as part of this I need to port my application from Qt4.8 to Qt5.4. My issue is that in the previous SDK SQLite support was built directly into the file-system however this is not the case for the new processor SDK. Do you have a guide or example I can follow to build the SQLite plugin for Qt5.4?
  • Hello Micheal,
    Check the attached qtbase_5.4.1-r0-arago6-tisdk0_cortexa8t2hf-vfp-neon.ipk.
    opkg install qtbase_5.4.1-r0-arago6-tisdk0_cortexa8t2hf-vfp-neon.ipk
    #install these too since the qtbase depends on them
    opkg install libcrypto1.0.0_1.0.1p-r0_cortexa8t2hf-vfp-neon.ipk
    opkg install libssl1.0.0_1.0.1p-r0_cortexa8t2hf-vfp-neon.ipk
    I have built it by appending PACKAGECONFIG_append = " sql-sqlite" in build/conf/local.conf file and it should contain the qt sqlite driver.
    $ git clone git://arago-project.org/git/projects/oe-layersetup.git tisdk
    $ cd tisdk
    $ ./oe-layertool-setup.sh -f configs/processor-sdk/processor-sdk-01.00.00.03-config.txt
    $ cd build
    $ echo 'PACKAGECONFIG_append = " sql-sqlite"' >> conf/local.conf
    $ . conf/setenv
    $ export PATH=$HOME/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/bin:$PATH
    $ MACHINE=am335x-evm bitbake qtbase
    Check this guide to setup your OE build environment.
    http://processors.wiki.ti.com/index.php/Processor_SDK_Building_The_SDK
    Check this page for transition from Qt4 to Qt5.
    https://wiki.qt.io/Transition_from_Qt_4.x_to_Qt5
    Check this section for .ipk package installation.
    http://processors.wiki.ti.com/index.php/Processor_SDK_Building_The_SDK#Installing_Package
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/354/4137.qtbase_5F00_5.4.1_2D00_r0_2D00_arago6_2D00_tisdk0_5F00_cortexa8t2hf_2D00_vfp_2D00_neon.ipk, https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/354/5287.libcrypto1.0.0_5F00_1.0.1p_2D00_r0_5F00_cortexa8t2hf_2D00_vfp_2D00_neon.ipk,
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/354/2072.libssl1.0.0_5F00_1.0.1p_2D00_r0_5F00_cortexa8t2hf_2D00_vfp_2D00_neon.ipk
    Kemal
  • Hi Kemal,
    Thanks for this, it worked great
    Micheal
