Other Parts Discussed in Thread: AM5728
Background/SW Versions:
Processor: TI AM5728
Platform: TI AM572x EVM
Processor SDK: ti-processor-sdk-linux-am57xx-evm-02.00.02.11
Linux Kernel: Using the 4.1.18 kernel included with the Processor SDK above
IPC: Using pre-built IPC binaries (both libraries and LAD) from the Processor SDK above
Related Thread: https://e2e.ti.com/support/embedded/linux/f/354/t/350493
Problem:
I'm in the process of trying to get ARM-DSP MessageQ communication working. Similar to the thread referenced above, doing a simple IPC_start() leads to some issues as observed from the LAD log file. In my case, I apparently get passed the NameServer_setup processing but run into the same "Address family not supported by protocol" errors later, during NameServer_attach.
Unlike the thread above, I didn't build IPC - I'm using the provided binaries from the Processor SDK. I did rebuild the kernel but only with minor tweaks to the configuration provided for the AM572x EVM. So, I would assume that everything is matched up (IPC/Linux Kernel-wise) as desired.
Please see the LAD log output below; any ideas?
[723.089789] Retrieving command...
[723.090073]
LAD_CONNECT:
[723.090113] client FIFO name = /tmp/LAD/1125
[723.090136] client PID = 1125
[723.090158] assigned client handle = 0
[723.090207] FIFO /tmp/LAD/1125 created
[723.090318] FIFO /tmp/LAD/1125 opened for writing
[723.090372] sent response
[723.090396] DONE
[723.090417] Retrieving command...
[723.090515] Sending response...
[723.090547] Retrieving command...
[723.090609] LAD_MULTIPROC_GETCONFIG: calling MultiProc_getConfig()...
[723.090636] MultiProc_getConfig() - 5 procs
[723.090658] # processors in cluster: 5
[723.090678] cluster baseId: 0
[723.090699] ProcId 0 - "HOST"
[723.090720] ProcId 1 - "IPU2"
[723.090740] ProcId 2 - "IPU1"
[723.090761] ProcId 3 - "DSP2"
[723.090780] ProcId 4 - "DSP1"
[723.090801] status = 0
[723.090821] DONE
[723.090840] Sending response...
[723.090866] Retrieving command...
[723.090959] LAD_NAMESERVER_SETUP: calling NameServer_setup()...
[723.090987] NameServer_setup: entered, refCount=0
[723.091021] NameServer_setup: creating listener thread
[723.091107] NameServer_setup: exiting, refCount=1
[723.091148] status = 0
[723.091177] DONE
[723.091204] Sending response...
[723.091124] listener_cb: Entered Listener thread.
[723.091288] NameServer: waiting for unblockFd: 2, and socks: maxfd: 2
[723.091237] Retrieving command...
[723.091366] LAD_MESSAGEQ_GETCONFIG: calling MessageQ_getConfig()...
[723.091390] status = 0
[723.091412] DONE
[723.091432] Sending response...
[723.091459] Retrieving command...
[723.091533] LAD_MESSAGEQ_SETUP: calling MessageQ_setup()...
[723.091593] MessageQ_setup: entered, refCount=0
[723.091615] NameServer_create(): 'MessageQ'
[723.091640] MessageQ_setup: exiting, refCount=1
[723.091660] status = 0
[723.091679] DONE
[723.091696] Sending response...
[723.091719] Retrieving command...
[723.091950] NameServer_attach: --> procId=1, refCount=0
[723.107794] NameServer_attach: socket failed: 97, Address family not supported by protocol
[723.107853] NameServer_attach: <-- refCount=0, status=-1
[723.107874] Sending response...
[723.107909] Retrieving command...
[723.108004] NameServer_attach: --> procId=2, refCount=0
[723.123463] NameServer_attach: socket failed: 97, Address family not supported by protocol
[723.123509] NameServer_attach: <-- refCount=0, status=-1
[723.123530] Sending response...
[723.123563] Retrieving command...
[723.123684] NameServer_attach: --> procId=3, refCount=0
[723.139161] NameServer_attach: socket failed: 97, Address family not supported by protocol
[723.139203] NameServer_attach: <-- refCount=0, status=-1
[723.139223] Sending response...
[723.139256] Retrieving command...
[723.139375] NameServer_attach: --> procId=4, refCount=0
[723.154745] NameServer_attach: socket failed: 97, Address family not supported by protocol
[723.154787] NameServer_attach: <-- refCount=0, status=-1
[723.154807] Sending response...
[723.154839] Retrieving command...
[723.154961] LAD_GATEMP_ISSETUP: calling GateMP_isSetup()...
[723.154987] status = 0
[723.155006] DONE
[723.155023] Sending response...
[723.155053] Retrieving command...
[724.155468] LAD_MESSAGEQ_DESTROY: calling MessageQ_destroy()...
[724.155516] MessageQ_destroy: entered, refCount=1
[724.155540] MessageQ_destroy: exiting, refCount=0
[724.155559] status = 0
[724.155577] DONE
[724.155594] Sending response...
[724.155625] Retrieving command...
[724.155761] LAD_NAMESERVER_DESTROY: calling NameServer_destroy()...
[724.155788] NameServer_destroy: entered, refCount=1
[724.155807] NameServer_destroy: shutdown listener...
[724.155836] NameServer_destroy: joining listener thread...
[724.155871] NameServer: back from select()
[724.155898] NameServer: listener thread, event: SHUTDOWN
[724.155987] NameServer_destroy: exiting, refCount=0
[724.156011] status = 0
[724.156030] DONE
[724.156048] Sending response...
[724.156077] Retrieving command...
[724.156205]
LAD_DISCONNECT: [724.156229]
client handle = 0[724.156259]
closing FIFO /tmp/LAD/1125 (filePtr=0x2f2e8)
[724.156307] done, unlinking /tmp/LAD/1125
[724.156358] DONE
[724.156378] Retrieving command...
[724.159042] EOF detected on FIFO, closing FIFO: /tmp/LAD/LADCMDS
[724.159109]
opening FIFO: /tmp/LAD/LADCMDS
