Arago project fail to build at ti-llvm3.6_3.6.bb (MACHINE=am57xx-evm, arago-core-tisdk-image, config=arago-krogoth-config.txt )
Hi, everyone,
I'm looking at
arago-project.org/.../Setting_Up_Build_Environment
and trying to build processor SDK from source code.
I'm having an error building ti-llvm3.6.
Here are the error messages:
| make[4]: Entering directory '/home/rivanna/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-ti-llvm3.6/3.6-r5/llvm-3.6.build/tools/clang/lib/FrontendTool'
| make[4]: *** No rule to make target 'all'.  Stop.
| make[4]: Leaving directory '/home/rivanna/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-ti-llvm3.6/3.6-r5/llvm-3.6.build/tools/clang/lib/FrontendTool'
| /home/rivanna/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-ti-llvm3.6/3.6-r5/git/Makefile.rules:932: recipe for target 'FrontendTool/.makeall' failed
| make[3]: *** [FrontendTool/.makeall] Error 2
| make[3]: *** Waiting for unfinished jobs....
| make[4]: Entering directory '/home/rivanna/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-ti-llvm3.6/3.6-r5/llvm-3.6.build/tools/clang/lib/Frontend'
| for dir in Rewrite; do \
|   if ([ ! -f $dir/Makefile ] || \
|       command test $dir/Makefile -ot /home/rivanna/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-ti-llvm3.6/3.6-r5/git/tools/clang/lib/Frontend/$dir/Makefile ); then \
|     /home/rivanna/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-ti-llvm3.6/3.6-r5/git/autoconf/mkinstalldirs $dir; \
|     /bin/cp /home/rivanna/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-ti-llvm3.6/3.6-r5/git/tools/clang/lib/Frontend/$dir/Makefile $dir/Makefile; \
|   fi; \
|   (make -C $dir all ) || exit 1; \
| done
| make[5]: Entering directory '/home/rivanna/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-ti-llvm3.6/3.6-r5/llvm-3.6.build/tools/clang/lib/Frontend/Rewrite'
| make[5]: Nothing to be done for 'all'.
| make[5]: Leaving directory '/home/rivanna/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-ti-llvm3.6/3.6-r5/llvm-3.6.build/tools/clang/lib/Frontend/Rewrite'
| make[4]: Leaving directory '/home/rivanna/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-ti-llvm3.6/3.6-r5/llvm-3.6.build/tools/clang/lib/Frontend'
| make[3]: Leaving directory '/home/rivanna/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-ti-llvm3.6/3.6-r5/llvm-3.6.build/tools/clang/lib'
| /home/rivanna/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-ti-llvm3.6/3.6-r5/git/Makefile.rules:873: recipe for target 'all' failed
| make[2]: *** [all] Error 1
| make[2]: Leaving directory '/home/rivanna/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-ti-llvm3.6/3.6-r5/llvm-3.6.build/tools/clang'
| /home/rivanna/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-ti-llvm3.6/3.6-r5/git/Makefile.rules:932: recipe for target 'clang/.makeall' failed
| make[1]: *** [clang/.makeall] Error 2
| make[1]: Leaving directory '/home/rivanna/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-ti-llvm3.6/3.6-r5/llvm-3.6.build/tools'
| make: *** [all] Error 1
| WARNING: /home/rivanna/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-ti-llvm3.6/3.6-r5/temp/run.do_compile.21325:1 exit 1 from 'exit 1'
| ERROR: oe_runmake failed
| ERROR: Function failed: do_compile (log file is located at /home/rivanna/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-ti-llvm3.6/3.6-r5/temp/log.do_compile.21325)
ERROR: Task 8030 (virtual:nativesdk:/home/rivanna/tisdk/sources/meta-arago/meta-arago-extras/recipes-core/llvm/ti-llvm3.6_3.6.bb, do_compile) failed with exit code '1'
I tried to run do_clean then restart, but the error persists.
How can I fix this?
