Tool/software: Linux
For LPAE support, I am switching from am57xx-evm-02.00.02.11 to linux-am57xx-evm-03.01.00.06, but system is boot properly but with multiple warnings like:
Please note I have created file system using below steps:
HW clock is also not initialized
root@am57xx-evm:~# hwclock
hwclock: can't open '/dev/misc/rtc': No such file or directory
4863.Log_working_for_ref_SDK2_00.txt
Please let me know what can be the possible issue.
Shweta
Hello shweta,
By separately running ./setup-targetfs-nfs.sh you have changed the rootfs but the kernel and device tree files still remain the old ones, that is why you are facing all these errors. The setup-targetfs-nfs.sh should be invoked by setup.sh script. Please, set-up the Processor SDK as explained at this wiki page.
Kemal
also my project init script in not running from rc5.d which is workinf with old SDK and file system
Failed to start Load Kernel Modules.
disagrees about version of symbol module_layout etc
Thanks Yordan and Kemal,
Your inputs are very helpful, system is booting properly RTC is also working, reason was because module authentication check.
Can you please let me know what is logs for, it says,
below are the logs:
[ 4.212500] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start [ 4.220386] systemd[1]: sysinit.target: Found dependency on alignment.service/start [ 4.228085] systemd[1]: sysinit.target: Found dependency on basic.target/start [ 4.235389] systemd[1]: sysinit.target: Found dependency on sockets.target/start [ 4.242880] systemd[1]: sysinit.target: Found dependency on rpcbind.socket/start [ 4.250331] systemd[1]: sysinit.target: Found dependency on sysinit.target/start [ 4.257763] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start [ 4.267219] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start [ SKIP ] Ordering cycle found, skipping alignment.service [ 4.301832] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 4.329381] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 4.359247] systemd[1]: Listening on Syslog Socket. [ OK ] Listening on Syslog Socket. [ 4.380388] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 4.409326] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ 4.439254] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 4.469225] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ OK ] Listening on /dev/initctl Compatibility Named Pipe. [ 4.499254] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 4.519220] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 4.549131] systemd[1]: Reached target Swap. [ OK ] Reached target Swap. [ 4.569352] systemd[1]: Listening on Journal Audit Socket. [ OK ] Listening on Journal Audit Socket. [ 4.599290] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password Requests to Wall Directory Watch. [ 4.629123] systemd[1]: Reached target Paths. [ OK ] Reached target Paths. [ 4.649176] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 4.679616] systemd[1]: Created slice System Slice. [ OK ] Created slice System Slice. [ 4.709656] systemd[1]: Created slice system-serial\x2dgetty.slice. [ OK ] Created slice system-serial\x2dgetty.slice. [ 4.739601] systemd[1]: Created slice system-getty.slice. [ OK ] Created slice system-getty.slice. [ 4.809338] systemd[1]: Starting Setup Virtual Console... Starting Setup Virtual Console... [ 4.851430] systemd[1]: Starting Create list of required static device nodes for the current kernel... Starting Create list of required st... nodes for the current kernel... [ 4.919178] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 4.936690] systemd[1]: Starting Journal Service... Starting Journal Service... [ 4.971643] systemd[1]: Mounting Temporary Directory... Mounting Temporary Directory... [ 5.011899] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 5.034102] cmemk: disagrees about version of symbol module_layout [ 5.042757] systemd[1]: Starting Remount Root and Kernel File Systems... Starting Remount Root and Kernel File Systems... [ 5.058186] cryptodev: disagrees about version of symbol module_layout [ 5.069277] systemd[1]: Reached target Slices. [ OK ] Reached target Slices.[ 5.076741] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 5.081051] gdbserverproxy: disagrees about version of symbol module_layout [ 5.101415] uio_module_drv: disagrees about version of symbol module_layout [ 5.119440] systemd[1]: Mounting Debug File System... Mounting Debug File System... [ 5.145302] systemd[1]: Mounted POSIX Message Queue File System. [ OK ] Mounted POSIX Message Queue File System. [ 5.179217] systemd[1]: Mounted Debug File System. [ OK ] Mounted Debug File System. [ 5.199236] systemd[1]: Mounted Temporary Directory. [ OK ] Mounted Temporary Directory. [ 5.219391] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Started Setup Virtual Console. [ OK ] Started Create list of required sta...ce nodes for the current kernel. [FAILED] Failed to start Load Kernel Modules. See 'systemctl status systemd-modules-load.service' for details. [ OK ] Started Remount Root and Kernel File Systems. Starting Rebuild Hardware Database... Starting Rebuild Dynamic Linker Cache... Mounting Configuration File System... Starting Apply Kernel Variables... Starting Create Static Device Nodes in /dev... Starting Flush Journal to Persistent Storage... [ OK ] Mounted Configuration File System. [ 5.809977] systemd-journald[138]: Received request to flush runtime journal from PID 1 [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Started Apply Kernel Variables. [ OK ] Started Create Static Device Nodes in /dev. Starting udev Kernel Device Manager... [ OK ] Reached target Local File Systems (Pre). Mounting /media/ram... Mounting /var/volatile... [ OK ] Mounted /var/volatile. [ OK ] Mounted /media/ram. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... Starting Rebuild Journal Catalog... [ OK ] Started Load/Save Random Seed. [ OK ] Started udev Kernel Device Manager. [ OK ] Started Create Volatile Files and Directories. [ OK ] Started Rebuild Journal Catalog. Starting Opkg first boot configure... Starting Update UTMP about System Boot/Shutdown... Starting Network Time Synchronization... [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Time Synchronized. Starting Synchronize System and HW clocks... [ OK ] Started Rebuild Hardware Database. [FAILED] Failed to start Synchronize System and HW clocks. See 'systemctl status sync-clocks.service' for details. Starting udev Coldplug all Devices... [ OK ] Started udev Coldplug all Devices. [ 7.699313] vpe 489d0000.vpe: Device registered as /dev/video0 [ 7.976890] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
Shweta
Also I didn’t see any print from intrc, I have added simple hello script in runlevel 5 but not showing my msg in boot time.
attaching logs for your reference, please let me know what may be responsible for now running script from runlevel.
Note i follow the simple steps:
In previous version SDK logs are like:
INIT: Entering runlevel: 5 Configuring network interfaces... [ 12.599622] net eth0: initializing cpsw version 1.15 (0) [ 12.681390] net eth0: phy found : id is : 0x221622 done. Starting system message bus: dbus. UIM SYSFS Node Found at /sys/./devices/platform/kim/install Starting uim-sysfs daemon. uim:@ main uim:install = /sys/./devices/platform/kim/install uim:dev_name = /sys/./devices/platform/kim/dev_name uim:baud_rate = /sys/./devices/platform/kim/baud_rate uim:flow_cntrl = /sys/./devices/platform/kim/flow_cntrl uim:begin polling... [ 13.441799] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ] Loaded PowerVR consumer services. Starting Dropbear SSH server: [ 13.597126] NET: Registered protocol family 10 [ 13.606188] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready dropbear. Starting telnet daemon. Starting tiipclad daemon GateMP support enabled on host Opened log file: lad.txt numProcessors = 5 id = 0 baseId = 0 Spawned daemon: /usr/bin/lad_dra7xx
Shweta
What is the content of systemctl status systemd-modules-load.service and systemctl status sync-clocks.service commands? Can you share?
Thanks Kemal,
Its working now I have recompiled the modules that resolved all the issues. and added systed service.
Shweta
