Tool/software: Linux
Hello, I want to use the touch screen in beaglebone black.
So, i change my am335x-boneblack.dts file but the touch screen did not work.
How do I configure my dts file?
I use the beagleboneblack and my linux version is 4.4.32-gadde2ca9f8. Plus, My LCD is 4DCAPE-43t
my device tree file is attached below.
boo
/* * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/ * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. */ /dts-v1/; #include "am33xx.dtsi" #include "am335x-bone-common.dtsi" #include <dt-bindings/display/tda998x.h> / { model = "TI AM335x BeagleBone Black"; compatible = "ti,am335x-bone-black", "ti,am335x-bone", "ti,am33xx"; backlight { compatible = "pwm-backlight"; pinctrl-names = "default"; pinctrl-0 = <&pwm_bl_pins>; status = "okay"; pwms = <&ehrpwm1 0 500000 0>; pwm-names = "LCD7"; brightness-levels = <0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100>; default-brightness-level = <101>; /* index to the array above */ }; }; &ldo3_reg { regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-always-on; }; &mmc1 { vmmc-supply = <&vmmcsd_fixed>; }; &mmc2 { vmmc-supply = <&vmmcsd_fixed>; pinctrl-names = "default"; pinctrl-0 = <&emmc_pins>; bus-width = <8>; status = "okay"; }; &cpu0_opp_table { /* * All PG 2.0 silicon may not support 1GHz but some of the early * BeagleBone Blacks have PG 2.0 silicon which is guaranteed * to support 1GHz OPP so enable it for PG 2.0 on this board. */ oppnitro@1000000000 { opp-supported-hw = <0x06 0x0100>; }; }; &am33xx_pinmux { uart1_pins: pinmux_uart1_pins { pinctrl-single,pins = < 0x180 (PIN_INPUT_PULLUP | MUX_MODE0) /* uart1_rxd.uart1_rxd */ 0x184 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart1_txd.uart1_txd */ >; }; lcd_pins_default: lcd_pins_default { pinctrl-single,pins = < 0xa0 0x00 /* lcd_data0.lcd_data0, OUTPUT | MODE0 */ 0xa4 0x00 /* lcd_data1.lcd_data1, OUTPUT | MODE0 */ 0xa8 0x00 /* lcd_data2.lcd_data2, OUTPUT | MODE0 */ 0xac 0x00 /* lcd_data3.lcd_data3, OUTPUT | MODE0 */ 0xb0 0x00 /* lcd_data4.lcd_data4, OUTPUT | MODE0 */ 0xb4 0x00 /* lcd_data5.lcd_data5, OUTPUT | MODE0 */ 0xb8 0x00 /* lcd_data6.lcd_data6, OUTPUT | MODE0 */ 0xbc 0x00 /* lcd_data7.lcd_data7, OUTPUT | MODE0 */ 0xc0 0x00 /* lcd_data8.lcd_data8, OUTPUT | MODE0 */ 0xc4 0x00 /* lcd_data9.lcd_data9, OUTPUT | MODE0 */ 0xc8 0x00 /* lcd_data10.lcd_data10, OUTPUT | MODE0 */ 0xcc 0x00 /* lcd_data11.lcd_data11, OUTPUT | MODE0 */ 0xd0 0x00 /* lcd_data12.lcd_data12, OUTPUT | MODE0 */ 0xd4 0x00 /* lcd_data13.lcd_data13, OUTPUT | MODE0 */ 0xd8 0x00 /* lcd_data14.lcd_data14, OUTPUT | MODE0 */ 0xdc 0x00 /* lcd_data15.lcd_data15, OUTPUT | MODE0 */ 0xe0 0x00 /* lcd_vsync.lcd_vsync, OUTPUT | MODE0 */ 0xe4 0x00 /* lcd_hsync.lcd_hsync, OUTPUT | MODE0 */ 0xe8 0x00 /* lcd_pclk.lcd_pclk, OUTPUT | MODE0 */ 0xec 0x00 /* lcd_ac_bias_en.lcd_ac_bias_en, OUTPUT | MODE0 */ >; }; nxp_hdmi_bonelt_pins: nxp_hdmi_bonelt_pins { pinctrl-single,pins = < 0x1b0 0x03 /* xdma_event_intr0, OMAP_MUX_MODE3 | AM33XX_PIN_OUTPUT */ 0xa0 0x08 /* lcd_data0.lcd_data0, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xa4 0x08 /* lcd_data1.lcd_data1, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xa8 0x08 /* lcd_data2.lcd_data2, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xac 0x08 /* lcd_data3.lcd_data3, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xb0 0x08 /* lcd_data4.lcd_data4, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xb4 0x08 /* lcd_data5.lcd_data5, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xb8 0x08 /* lcd_data6.lcd_data6, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xbc 0x08 /* lcd_data7.lcd_data7, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xc0 0x08 /* lcd_data8.lcd_data8, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xc4 0x08 /* lcd_data9.lcd_data9, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xc8 0x08 /* lcd_data10.lcd_data10, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xcc 0x08 /* lcd_data11.lcd_data11, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xd0 0x08 /* lcd_data12.lcd_data12, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xd4 0x08 /* lcd_data13.lcd_data13, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xd8 0x08 /* lcd_data14.lcd_data14, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xdc 0x08 /* lcd_data15.lcd_data15, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xe0 0x00 /* lcd_vsync.lcd_vsync, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT */ 0xe4 0x00 /* lcd_hsync.lcd_hsync, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT */ 0xe8 0x00 /* lcd_pclk.lcd_pclk, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT */ 0xec 0x00 /* lcd_ac_bias_en.lcd_ac_bias_en, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT */ >; }; nxp_hdmi_bonelt_off_pins: nxp_hdmi_bonelt_off_pins { pinctrl-single,pins = < 0x1b0 0x03 /* xdma_event_intr0, OMAP_MUX_MODE3 | AM33XX_PIN_OUTPUT */ >; }; mcasp0_pins: mcasp0_pins { pinctrl-single,pins = < AM33XX_IOPAD(0x9ac, PIN_INPUT_PULLUP | MUX_MODE0) /* mcasp0_ahcklx.mcasp0_ahclkx */ AM33XX_IOPAD(0x99c, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mcasp0_ahclkr.mcasp0_axr2*/ AM33XX_IOPAD(0x994, PIN_OUTPUT_PULLUP | MUX_MODE0) /* mcasp0_fsx.mcasp0_fsx */ AM33XX_IOPAD(0x990, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* mcasp0_aclkx.mcasp0_aclkx */ AM33XX_IOPAD(0x86c, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gpmc_a11.GPIO1_27 */ >; }; panel { compatible = "ti,tilcdc,panel"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&lcd_pins_default>; panel-info { ac-bias = <255>; ac-bias-intrpt = <0>; dma-burst-sz = <16>; bpp = <16>; fdd = <0x80>; sync-edge = <0>; sync-ctrl = <1>; raster-order = <0>; fifo-th = <0>; tft-alt-mode = <0>; stn-565-mode = <0>; mono-8bit-mode = <0>; }; display-timings { 800x480p62 { clock-frequency = <30000000>; hactive = <800>; vactive = <480>; hfront-porch = <40>; hback-porch = <40>; hsync-len = <48>; vback-porch = <30>; vfront-porch = <13>; vsync-len = <3>; hsync-active = <0>; vsync-active = <0>; }; }; }; }; &uart1 { pinctrl-names = "default"; pinctrl-0 = <&uart1_pins>; status = "okay"; }; &epwmss1 { status = "okay"; }; &lcdc { status = "okay"; /* If you want to get 24 bit RGB and 16 BGR mode instead of * current 16 bit RGB and 24 BGR modes, set the propety * below to "crossed" and uncomment the video-ports -property * in tda19988 node. */ blue-and-red-wiring = "straight"; port { lcdc_0: endpoint@0 { remote-endpoint = <&hdmi_0>; }; }; }; &i2c0 { tda19988: tda19988 { compatible = "nxp,tda998x"; reg = <0x70>; pinctrl-names = "default", "off"; pinctrl-0 = <&nxp_hdmi_bonelt_pins>; pinctrl-1 = <&nxp_hdmi_bonelt_off_pins>; /* Convert 24bit BGR to RGB, e.g. cross red and blue wiring */ /* video-ports = <0x234501>; */ #sound-dai-cells = <0>; audio-ports = < AFMT_I2S 0x03>; ports { port@0 { hdmi_0: endpoint@0 { remote-endpoint = <&lcdc_0>; }; }; }; }; }; &rtc { system-power-controller; }; &mcasp0 { #sound-dai-cells = <0>; pinctrl-names = "default"; pinctrl-0 = <&mcasp0_pins>; status = "okay"; op-mode = <0>; /* MCASP_IIS_MODE */ tdm-slots = <2>; serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ 0 0 1 0 >; tx-num-evt = <32>; rx-num-evt = <32>; }; &sgx { status = "okay"; }; / { clk_mcasp0_fixed: clk_mcasp0_fixed { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <24576000>; }; clk_mcasp0: clk_mcasp0 { #clock-cells = <0>; compatible = "gpio-gate-clock"; clocks = <&clk_mcasp0_fixed>; enable-gpios = <&gpio1 27 0>; /* BeagleBone Black Clk enable on GPIO1_27 */ }; sound { compatible = "simple-audio-card"; simple-audio-card,name = "TI BeagleBone Black"; simple-audio-card,format = "i2s"; simple-audio-card,bitclock-master = <&dailink0_master>; simple-audio-card,frame-master = <&dailink0_master>; dailink0_master: simple-audio-card,cpu { sound-dai = <&mcasp0>; clocks = <&clk_mcasp0>; }; simple-audio-card,codec { sound-dai = <&tda19988>; }; }; ecap0_pins_default: backlight_pins { pinctrl-single,pins = < 0x164 0x0 /* eCAP0_in_PWM0_out.eCAP0_in_PWM0_out MODE0 */ >; }; pwm_bl_pins: pinmux_pwm_bl_pins { pinctrl-single,pins = < 0x48 0x06 /* gpmc_a2.ehrpwm1a, OMAP_MUX_MODE6 | AM33XX_PIN_OUTPUT */ >; }; }; &lcdc { pinctrl-names = "default"; pinctrl-0 = <&lcd_pins_default>; status = "okay"; display-timings { 800x480p62 { clock-frequency = <30000000>; hactive = <800>; vactive = <480>; hfront-porch = <39>; hback-porch = <39>; hsync-len = <47>; vback-porch = <29>; vfront-porch = <13>; vsync-len = <2>; hsync-active = <0>; vsync-active = <0>; bpp = <16>; }; }; }; &tscadc { status = "okay"; tsc { ti,wires = <4>; ti,x-plate-resistance = <200>; ti,coordinate-readouts = <5>; ti,wire-config = <0x00 0x11 0x22 0x33>; }; adc { ti,adc-channels = <4 5 6 7>; }; };
