Linux/DRA756: DRA742 based on PSDK 3.02 USB device mode is not working
Part Number: DRA756
Tool/software: Linux
Hello!
HW : custom VAYU board.
I am in the process of porting SDK from GLSDK 7.04 to Processor-SDK 3.02.
Target board is based on DRA7X_EVM(VAYU 703761-1031), there is no much differences.
I have no problem with GLSKD 7.04.
But after applying Processor-SDK 3.02, USB1 device mode is not working.
When "ums 0 mmc1" command is used at u-boot, gadget driver and stoage of ther target is found on the host linux PC.
After kernel loading, I can use usb1 as device mode.
But I couldn't use device USB1 port without u-boot command.
When I tested with previous version kernel config and device tree(based on GLSDK 7.04 ) with same u-boot, it was OK.
(I tested host mode by changing device tree, it worked perfectly in host mode.)
I think definitely kernel config or device tree is something wrong.
I have checked clock, regulator supply etc.
But I cann't figure out what's wrong.
Is there any other suggestions or tips?
Thank you
Kernel config
CONFIG_USB_NET_DRIVERS=m
CONFIG_USB_PEGASUS=m
CONFIG_USB_RTL8152=m
CONFIG_USB_USBNET=m
CONFIG_USB_NET_AX8817X=m
CONFIG_USB_NET_AX88179_178A=m
CONFIG_USB_NET_CDCETHER=m
CONFIG_USB_NET_CDC_NCM=m
CONFIG_USB_NET_SMSC75XX=m
CONFIG_USB_NET_SMSC95XX=m
CONFIG_USB_NET_NET1080=m
CONFIG_USB_NET_CDC_SUBSET=m
CONFIG_USB_BELKIN=y
CONFIG_USB_ARMLINUX=y
CONFIG_USB_NET_ZAURUS=m
CONFIG_RT2800USB=m
CONFIG_RT2800USB_RT33XX=y
CONFIG_RT2800USB_RT35XX=y
CONFIG_RT2X00_LIB_USB=m
CONFIG_MFD_OMAP_USB_HOST=y
CONFIG_MEDIA_USB_SUPPORT=y
CONFIG_USB_VIDEO_CLASS=m
CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
CONFIG_USB_GSPCA=m
CONFIG_SND_USB=y
CONFIG_SND_USB_AUDIO=m
CONFIG_USB_HID=m
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_SUPPORT=y
CONFIG_USB_COMMON=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB=m
CONFIG_USB_DEFAULT_PERSIST=y
CONFIG_USB_OTG=y
CONFIG_USB_XHCI_HCD=m
CONFIG_USB_XHCI_PCI=m
CONFIG_USB_XHCI_PLATFORM=m
CONFIG_USB_EHCI_HCD=m
CONFIG_USB_EHCI_TT_NEWSCHED=y
CONFIG_USB_EHCI_PCI=m
CONFIG_USB_EHCI_HCD_OMAP=m
CONFIG_USB_EHCI_HCD_PLATFORM=m
CONFIG_USB_OHCI_HCD=m
CONFIG_USB_OHCI_HCD_PCI=m
CONFIG_USB_OHCI_HCD_PLATFORM=m
CONFIG_USB_R8A66597_HCD=m
CONFIG_USB_ACM=m
CONFIG_USB_STORAGE=m
CONFIG_USB_MUSB_HDRC=m
CONFIG_USB_MUSB_DUAL_ROLE=y
CONFIG_USB_MUSB_OMAP2PLUS=m
CONFIG_USB_MUSB_AM35X=m
CONFIG_USB_MUSB_DSPS=m
CONFIG_USB_MUSB_AM335X_CHILD=m
CONFIG_USB_TI_CPPI41_DMA=y
CONFIG_USB_DWC3=m
CONFIG_USB_DWC3_DUAL_ROLE=y
CONFIG_USB_DWC3_OMAP=m
CONFIG_USB_ISP1760=m
CONFIG_USB_ISP1760_HCD=y
CONFIG_USB_ISP1761_UDC=y
CONFIG_USB_ISP1760_DUAL_ROLE=y
CONFIG_USB_SERIAL=m
CONFIG_USB_SERIAL_FTDI_SIO=m
CONFIG_USB_TEST=m
CONFIG_USB_PHY=y
CONFIG_NOP_USB_XCEIV=y
CONFIG_AM335X_CONTROL_USB=y
CONFIG_AM335X_PHY_USB=y
CONFIG_USB_GPIO_VBUS=y
CONFIG_USB_ISP1301=m
CONFIG_USB_GADGET=m
CONFIG_USB_GADGET_VBUS_DRAW=2
CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=32
CONFIG_USB_LIBCOMPOSITE=m
CONFIG_USB_F_ACM=m
CONFIG_USB_F_SS_LB=m
CONFIG_USB_U_SERIAL=m
CONFIG_USB_U_ETHER=m
CONFIG_USB_F_SERIAL=m
CONFIG_USB_F_OBEX=m
CONFIG_USB_F_NCM=m
CONFIG_USB_F_ECM=m
CONFIG_USB_F_SUBSET=m
CONFIG_USB_F_RNDIS=m
CONFIG_USB_F_MASS_STORAGE=m
CONFIG_USB_F_FS=m
CONFIG_USB_F_UAC2=m
CONFIG_USB_F_UVC=m
CONFIG_USB_F_MIDI=m
CONFIG_USB_F_HID=m
CONFIG_USB_F_PRINTER=m
CONFIG_USB_ZERO=m
CONFIG_USB_AUDIO=m
CONFIG_USB_ETH=m
CONFIG_USB_ETH_RNDIS=y
CONFIG_USB_G_NCM=m
CONFIG_USB_GADGETFS=m
CONFIG_USB_FUNCTIONFS=m
CONFIG_USB_FUNCTIONFS_ETH=y
CONFIG_USB_FUNCTIONFS_RNDIS=y
CONFIG_USB_FUNCTIONFS_GENERIC=y
CONFIG_USB_MASS_STORAGE=m
CONFIG_USB_G_SERIAL=m
CONFIG_USB_MIDI_GADGET=m
CONFIG_USB_G_PRINTER=m
CONFIG_USB_CDC_COMPOSITE=m
CONFIG_USB_G_ACM_MS=m
CONFIG_USB_G_MULTI=m
CONFIG_USB_G_MULTI_RNDIS=y
CONFIG_USB_G_MULTI_CDC=y
CONFIG_USB_G_HID=m
CONFIG_USB_G_DBGP=m
CONFIG_USB_G_DBGP_SERIAL=y
CONFIG_USB_G_WEBCAM=m
CONFIG_EXTCON_USB_GPIO=m
CONFIG_OMAP_USB2=y
devicee tree settings
    model = "TI DRA742";
    reserved_mem: reserved-memory {
    extcon_usb1: extcon_usb1 {
        compatible = "linux,extcon-usb-gpio";
        id-gpio = <&pcf_hdmi 1 GPIO_ACTIVE_HIGH>;
    extcon_usb2: extcon_usb2 {
        id-gpio = <&pcf_hdmi 2 GPIO_ACTIVE_HIGH>;
&omap_dwc3_1 {
    extcon = <&extcon_usb1>;
&omap_dwc3_2 {
    extcon = <&extcon_usb2>;
&usb1 {
    dr_mode = "peripheral";
&usb2 {
    dr_mode = "host";
&usb2_phy1 {
    phy-supply = <&ldousb_reg>;
&usb2_phy2 {
// dra7.dtsi is same
		omap_dwc3_1: omap_dwc3_1@48880000 {
			compatible = "ti,dwc3";
			ti,hwmods = "usb_otg_ss1";
			reg = <0x48880000 0x10000>;
			interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>;
			#address-cells = <1>;
			#size-cells = <1>;
			utmi-mode = <2>;
			ranges;
			usb1: usb@48890000 {
				compatible = "snps,dwc3";
				reg = <0x48890000 0x17000>;
				interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>,
				interrupt-names = "peripheral",
						  "host",
						  "otg";
				phys = <&usb2_phy1>, <&usb3_phy1>;
				phy-names = "usb2-phy", "usb3-phy";
				tx-fifo-resize;
				maximum-speed = "super-speed";
				dr_mode = "otg";
				snps,dis_u3_susphy_quirk;
				snps,dis_u2_susphy_quirk;
# dmesg|grep usb
[    9.159108] usbcore: registered new interface driver usbfs
[    9.170471] usbcore: registered new interface driver hub
[    9.187886] usbcore: registered new device driver usb
[    9.415516] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   76.592947] udc 48890000.usb: registering UDC driver [g_multi]
[   76.612671] usb0: HOST MAC c6:c7:28:0d:0d:83
[   76.617426] usb0: MAC 86:2f:b0:c3:8d:9e
[   76.679495] usb0: eth_open
[   76.679652] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[   76.694434] g_multi 48890000.usb: usb_gadget_udc_start
debugfs 48890000.usb information
# cat /mnt/48890000.usb/regdump
GSBUSCFG0 = 0x0000000e
GSBUSCFG1 = 0x00000f00
GTXTHRCFG = 0x00000000
GRXTHRCFG = 0x00000000
GCTL = 0x25802000
GEVTEN = 0x00000000
GSTS = 0x3e800002
GSNPSID = 0x5533202a
GGPIO = 0x00000000
GUID = 0x0004042d
GUCTL = 0x00008010
GBUSERRADDR0 = 0x00000000
GBUSERRADDR1 = 0x00000000
GPRTBIMAP0 = 0x00000000
GPRTBIMAP1 = 0x00000000
GHWPARAMS0 = 0x202040ca
GHWPARAMS1 = 0x01c0c93b
GHWPARAMS2 = 0x00000000
GHWPARAMS3 = 0x1042008d
GHWPARAMS4 = 0x48822004
GHWPARAMS5 = 0x04202088
GHWPARAMS6 = 0x0b000c20
GHWPARAMS7 = 0x03080780
GDBGFIFOSPACE = 0x00420000
GDBGLTSSM = 0x01090440
GPRTBIMAP_HS0 = 0x00000000
GPRTBIMAP_HS1 = 0x00000000
GPRTBIMAP_FS0 = 0x00000000
GPRTBIMAP_FS1 = 0x00000000
GUSB2PHYCFG(0) = 0x00002500
GUSB2PHYCFG(1) = 0x00000000
GUSB2PHYCFG(2) = 0x00000000
GUSB2PHYCFG(3) = 0x00000000
GUSB2PHYCFG(4) = 0x00000000
GUSB2PHYCFG(5) = 0x00000000
GUSB2PHYCFG(6) = 0x00000000
GUSB2PHYCFG(7) = 0x00000000
GUSB2PHYCFG(8) = 0x00000000
GUSB2PHYCFG(9) = 0x00000000
GUSB2PHYCFG(10) = 0x00000000
GUSB2PHYCFG(11) = 0x00000000
GUSB2PHYCFG(12) = 0x00000000
GUSB2PHYCFG(13) = 0x00000000
GUSB2PHYCFG(14) = 0x00000000
GUSB2PHYCFG(15) = 0x00000000
GUSB2I2CCTL(0) = 0x00000000
GUSB2I2CCTL(1) = 0x00000000
GUSB2I2CCTL(2) = 0x00000000
GUSB2I2CCTL(3) = 0x00000000
GUSB2I2CCTL(4) = 0x00000000
GUSB2I2CCTL(5) = 0x00000000
GUSB2I2CCTL(6) = 0x00000000
GUSB2I2CCTL(7) = 0x00000000
GUSB2I2CCTL(8) = 0x00000000
GUSB2I2CCTL(9) = 0x00000000
GUSB2I2CCTL(10) = 0x00000000
GUSB2I2CCTL(11) = 0x00000000
GUSB2I2CCTL(12) = 0x00000000
GUSB2I2CCTL(13) = 0x00000000
GUSB2I2CCTL(14) = 0x00000000
GUSB2I2CCTL(15) = 0x00000000
GUSB2PHYACC(0) = 0x00000000
GUSB2PHYACC(1) = 0x00000000
GUSB2PHYACC(2) = 0x00000000
GUSB2PHYACC(3) = 0x00000000
GUSB2PHYACC(4) = 0x00000000
GUSB2PHYACC(5) = 0x00000000
GUSB2PHYACC(6) = 0x00000000
GUSB2PHYACC(7) = 0x00000000
GUSB2PHYACC(8) = 0x00000000
GUSB2PHYACC(9) = 0x00000000
GUSB2PHYACC(10) = 0x00000000
GUSB2PHYACC(11) = 0x00000000
GUSB2PHYACC(12) = 0x00000000
GUSB2PHYACC(13) = 0x00000000
GUSB2PHYACC(14) = 0x00000000
GUSB2PHYACC(15) = 0x00000000
GUSB3PIPECTL(0) = 0x00040002
GUSB3PIPECTL(1) = 0x00000000
GUSB3PIPECTL(2) = 0x00000000
GUSB3PIPECTL(3) = 0x00000000
GUSB3PIPECTL(4) = 0x00000000
GUSB3PIPECTL(5) = 0x00000000
GUSB3PIPECTL(6) = 0x00000000
GUSB3PIPECTL(7) = 0x00000000
GUSB3PIPECTL(8) = 0x00000000
GUSB3PIPECTL(9) = 0x00000000
GUSB3PIPECTL(10) = 0x00000000
GUSB3PIPECTL(11) = 0x00000000
GUSB3PIPECTL(12) = 0x00000000
GUSB3PIPECTL(13) = 0x00000000
GUSB3PIPECTL(14) = 0x00000000
GUSB3PIPECTL(15) = 0x00000000
GTXFIFOSIZ(0) = 0x00000042
GTXFIFOSIZ(1) = 0x00420184
GTXFIFOSIZ(2) = 0x01c60184
GTXFIFOSIZ(3) = 0x034a0184
GTXFIFOSIZ(4) = 0x04ce0184
GTXFIFOSIZ(5) = 0x06520013
GTXFIFOSIZ(6) = 0x06650013
GTXFIFOSIZ(7) = 0x06780013
GTXFIFOSIZ(8) = 0x068b0013
GTXFIFOSIZ(9) = 0x069e0013
GTXFIFOSIZ(10) = 0x06b10013
GTXFIFOSIZ(11) = 0x06c40013
GTXFIFOSIZ(12) = 0x06d70013
GTXFIFOSIZ(13) = 0x06ea0013
GTXFIFOSIZ(14) = 0x06fd0013
GTXFIFOSIZ(15) = 0x07100013
GTXFIFOSIZ(16) = 0x00000000
GTXFIFOSIZ(17) = 0x00000000
GTXFIFOSIZ(18) = 0x00000000
GTXFIFOSIZ(19) = 0x00000000
GTXFIFOSIZ(20) = 0x00000000
GTXFIFOSIZ(21) = 0x00000000
GTXFIFOSIZ(22) = 0x00000000
GTXFIFOSIZ(23) = 0x00000000
GTXFIFOSIZ(24) = 0x00000000
GTXFIFOSIZ(25) = 0x00000000
GTXFIFOSIZ(26) = 0x00000000
GTXFIFOSIZ(27) = 0x00000000
GTXFIFOSIZ(28) = 0x00000000
GTXFIFOSIZ(29) = 0x00000000
GTXFIFOSIZ(30) = 0x00000000
GTXFIFOSIZ(31) = 0x00000000
GRXFIFOSIZ(0) = 0x071e0185
GRXFIFOSIZ(1) = 0x08a30000
GRXFIFOSIZ(2) = 0x08a30000
GRXFIFOSIZ(3) = 0x00000000
GRXFIFOSIZ(4) = 0x00000000
GRXFIFOSIZ(5) = 0x00000000
GRXFIFOSIZ(6) = 0x00000000
GRXFIFOSIZ(7) = 0x00000000
GRXFIFOSIZ(8) = 0x00000000
GRXFIFOSIZ(9) = 0x00000000
GRXFIFOSIZ(10) = 0x00000000
GRXFIFOSIZ(11) = 0x00000000
GRXFIFOSIZ(12) = 0x00000000
GRXFIFOSIZ(13) = 0x00000000
GRXFIFOSIZ(14) = 0x00000000
GRXFIFOSIZ(15) = 0x00000000
GRXFIFOSIZ(16) = 0x00000000
GRXFIFOSIZ(17) = 0x00000000
GRXFIFOSIZ(18) = 0x00000000
GRXFIFOSIZ(19) = 0x00000000
GRXFIFOSIZ(20) = 0x00000000
GRXFIFOSIZ(21) = 0x00000000
GRXFIFOSIZ(22) = 0x00000000
GRXFIFOSIZ(23) = 0x00000000
GRXFIFOSIZ(24) = 0x00000000
GRXFIFOSIZ(25) = 0x00000000
GRXFIFOSIZ(26) = 0x00000000
GRXFIFOSIZ(27) = 0x00000000
GRXFIFOSIZ(28) = 0x00000000
GRXFIFOSIZ(29) = 0x00000000
GRXFIFOSIZ(30) = 0x00000000
GRXFIFOSIZ(31) = 0x00000000
GEVNTADRLO(0) = 0xfbc44000
GEVNTADRHI(0) = 0x00000000
GEVNTSIZ(0) = 0x00001000
GEVNTCOUNT(0) = 0x00000000
GHWPARAMS8 = 0x0000071e
DCFG = 0x00080800
DCTL = 0x00000000
DEVTEN = 0x00000000
DSTS = 0x00d20001
DGCMDPAR = 0x00000000
DGCMD = 0x00000000
DALEPENA = 0x00000000
DEPCMDPAR2(0) = 0x00000000
DEPCMDPAR2(1) = 0x00000000
DEPCMDPAR2(2) = 0x00000000
DEPCMDPAR2(3) = 0x00000000
DEPCMDPAR2(4) = 0x00000000
DEPCMDPAR2(5) = 0x00000000
DEPCMDPAR2(6) = 0x00000000
DEPCMDPAR2(7) = 0x00000000
DEPCMDPAR2(8) = 0x00000000
DEPCMDPAR2(9) = 0x00000000
DEPCMDPAR2(10) = 0x00000000
DEPCMDPAR2(11) = 0x00000000
DEPCMDPAR2(12) = 0x00000000
DEPCMDPAR2(13) = 0x00000000
DEPCMDPAR2(14) = 0x00000000
DEPCMDPAR2(15) = 0x00000000
DEPCMDPAR2(16) = 0x00000000
DEPCMDPAR2(17) = 0x00000000
DEPCMDPAR2(18) = 0x00000000
DEPCMDPAR2(19) = 0x00000000
DEPCMDPAR2(20) = 0x00000000
DEPCMDPAR2(21) = 0x00000000
DEPCMDPAR2(22) = 0x00000000
DEPCMDPAR2(23) = 0x00000000
DEPCMDPAR2(24) = 0x00000000
DEPCMDPAR2(25) = 0x00000000
DEPCMDPAR2(26) = 0x00000000
DEPCMDPAR2(27) = 0x00000000
DEPCMDPAR2(28) = 0x00000000
DEPCMDPAR2(29) = 0x00000000
DEPCMDPAR2(30) = 0x00000000
DEPCMDPAR2(31) = 0x00000000
DEPCMDPAR1(0) = 0x00000000
DEPCMDPAR1(1) = 0x00000000
DEPCMDPAR1(2) = 0x00000000
DEPCMDPAR1(3) = 0x00000000
DEPCMDPAR1(4) = 0x00000000
DEPCMDPAR1(5) = 0x00000000
DEPCMDPAR1(6) = 0x00000000
DEPCMDPAR1(7) = 0x00000000
DEPCMDPAR1(8) = 0x00000000
DEPCMDPAR1(9) = 0x00000000
DEPCMDPAR1(10) = 0x00000000
DEPCMDPAR1(11) = 0x00000000
DEPCMDPAR1(12) = 0x00000000
DEPCMDPAR1(13) = 0x00000000
DEPCMDPAR1(14) = 0x00000000
DEPCMDPAR1(15) = 0x00000000
DEPCMDPAR1(16) = 0x00000000
DEPCMDPAR1(17) = 0x00000000
DEPCMDPAR1(18) = 0x00000000
DEPCMDPAR1(19) = 0x00000000
DEPCMDPAR1(20) = 0x00000000
DEPCMDPAR1(21) = 0x00000000
DEPCMDPAR1(22) = 0x00000000
DEPCMDPAR1(23) = 0x00000000
DEPCMDPAR1(24) = 0x00000000
DEPCMDPAR1(25) = 0x00000000
DEPCMDPAR1(26) = 0x00000000
DEPCMDPAR1(27) = 0x00000000
DEPCMDPAR1(28) = 0x00000000
DEPCMDPAR1(29) = 0x00000000
DEPCMDPAR1(30) = 0x00000000
DEPCMDPAR1(31) = 0x00000000
DEPCMDPAR0(0) = 0x00000000
DEPCMDPAR0(1) = 0x00000000
DEPCMDPAR0(2) = 0x00000000
DEPCMDPAR0(3) = 0x00000000
DEPCMDPAR0(4) = 0x00000000
DEPCMDPAR0(5) = 0x00000000
DEPCMDPAR0(6) = 0x00000000
DEPCMDPAR0(7) = 0x00000000
DEPCMDPAR0(8) = 0x00000000
DEPCMDPAR0(9) = 0x00000000
DEPCMDPAR0(10) = 0x00000000
DEPCMDPAR0(11) = 0x00000000
DEPCMDPAR0(12) = 0x00000000
DEPCMDPAR0(13) = 0x00000000
DEPCMDPAR0(14) = 0x00000000
DEPCMDPAR0(15) = 0x00000000
DEPCMDPAR0(16) = 0x00000000
DEPCMDPAR0(17) = 0x00000000
DEPCMDPAR0(18) = 0x00000000
DEPCMDPAR0(19) = 0x00000000
DEPCMDPAR0(20) = 0x00000000
DEPCMDPAR0(21) = 0x00000000
DEPCMDPAR0(22) = 0x00000000
DEPCMDPAR0(23) = 0x00000000
DEPCMDPAR0(24) = 0x00000000
DEPCMDPAR0(25) = 0x00000000
DEPCMDPAR0(26) = 0x00000000
DEPCMDPAR0(27) = 0x00000000
DEPCMDPAR0(28) = 0x00000000
DEPCMDPAR0(29) = 0x00000000
DEPCMDPAR0(30) = 0x00000000
DEPCMDPAR0(31) = 0x00000000
DEPCMD(0) = 0x00000000
DEPCMD(1) = 0x00000000
DEPCMD(2) = 0x00000000
DEPCMD(3) = 0x00000000
DEPCMD(4) = 0x00000000
DEPCMD(5) = 0x00000000
DEPCMD(6) = 0x00000000
DEPCMD(7) = 0x00000000
DEPCMD(8) = 0x00000000
DEPCMD(9) = 0x00000000
DEPCMD(10) = 0x00000000
DEPCMD(11) = 0x00000000
DEPCMD(12) = 0x00000000
DEPCMD(13) = 0x00000000
DEPCMD(14) = 0x00000000
DEPCMD(15) = 0x00000000
DEPCMD(16) = 0x00000000
DEPCMD(17) = 0x00000000
DEPCMD(18) = 0x00000000
DEPCMD(19) = 0x00000000
DEPCMD(20) = 0x00000000
DEPCMD(21) = 0x00000000
DEPCMD(22) = 0x00000000
DEPCMD(23) = 0x00000000
DEPCMD(24) = 0x00000000
DEPCMD(25) = 0x00000000
DEPCMD(26) = 0x00000000
DEPCMD(27) = 0x00000000
DEPCMD(28) = 0x00000000
DEPCMD(29) = 0x00000000
DEPCMD(30) = 0x00000000
DEPCMD(31) = 0x00000000
OCFG = 0x00000000
OCTL = 0x00000040
OEVT = 0x80000000
OEVTEN = 0x00000000
OSTS = 0x00000019
# cat /mnt/48890000.usb/mode
device
log of modprobe g_multi
log of g_multi modprobe
/dev/mmcblk0 is eMMC.
[ 1320.513821] using random self ethernet address
[ 1320.519152] using random host ethernet address
[ 1320.524106] using random self ethernet address
[ 1320.529274] using random host ethernet address
[ 1320.537189] usb0: HOST MAC 0e:14:c0:11:dc:f2
[ 1320.541880] usb0: MAC c2:21:f7:06:34:84
[ 1320.552720] Mass Storage Function, version: 2009/09/11
[ 1320.559307] LUN: removable file: (no medium)
[ 1320.565966] LUN: file: /dev/mmcblk0
[ 1320.569491] Number of LUNs=1
[ 1320.580228] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 1320.590029] g_multi gadget: Multifunction Composite Gadget
[ 1320.600862] g_multi gadget: userspace failed to provide iSerialNumber
[ 1320.607916] g_multi gadget: g_multi ready
and then 48890000.usb regdump
and then
GCTL = 0x25802000
GEVTEN = 0x00000000
GSTS = 0x3e800002
GGPIO = 0x00000000
GUID = 0x0004042d
GUCTL = 0x00008010
DCFG = 0x00080804
DCTL = 0x80000000
DEVTEN = 0x00001e1f
DSTS = 0x009240b4
DGCMD = 0x00000000
DALEPENA = 0x00000003
DEPCMDPAR1(0) = 0xfbc46000
DEPCMDPAR1(1) = 0x02000500
DEPCMDPAR0(1) = 0x00001000
DEPCMDPAR0(2) = 0x00000001
DEPCMDPAR0(3) = 0x00000001
DEPCMDPAR0(4) = 0x00000001
DEPCMDPAR0(5) = 0x00000001
DEPCMDPAR0(6) = 0x00000001
DEPCMDPAR0(7) = 0x00000001
DEPCMDPAR0(8) = 0x00000001
DEPCMDPAR0(9) = 0x00000001
DEPCMDPAR0(10) = 0x00000001
DEPCMDPAR0(11) = 0x00000001
DEPCMDPAR0(12) = 0x00000001
DEPCMDPAR0(13) = 0x00000001
DEPCMDPAR0(14) = 0x00000001
DEPCMDPAR0(15) = 0x00000001
DEPCMDPAR0(16) = 0x00000001
DEPCMDPAR0(17) = 0x00000001
DEPCMDPAR0(18) = 0x00000001
DEPCMDPAR0(19) = 0x00000001
DEPCMDPAR0(20) = 0x00000001
DEPCMDPAR0(21) = 0x00000001
DEPCMDPAR0(22) = 0x00000001
DEPCMDPAR0(23) = 0x00000001
DEPCMDPAR0(24) = 0x00000001
DEPCMDPAR0(25) = 0x00000001
DEPCMDPAR0(26) = 0x00000001
DEPCMDPAR0(27) = 0x00000001
DEPCMDPAR0(28) = 0x00000001
DEPCMDPAR0(29) = 0x00000001
DEPCMDPAR0(30) = 0x00000001
DEPCMDPAR0(31) = 0x00000001
DEPCMD(0) = 0x00000006
DEPCMD(1) = 0x00000001
DEPCMD(2) = 0x00030002
DEPCMD(3) = 0x00040002
DEPCMD(4) = 0x00050002
DEPCMD(5) = 0x00060002
DEPCMD(6) = 0x00070002
DEPCMD(7) = 0x00080002
DEPCMD(8) = 0x00090002
DEPCMD(9) = 0x000a0002
DEPCMD(10) = 0x000b0002
DEPCMD(11) = 0x000c0002
DEPCMD(12) = 0x000d0002
DEPCMD(13) = 0x000e0002
DEPCMD(14) = 0x000f0002
DEPCMD(15) = 0x00100002
DEPCMD(16) = 0x00110002
DEPCMD(17) = 0x00120002
DEPCMD(18) = 0x00130002
DEPCMD(19) = 0x00140002
DEPCMD(20) = 0x00150002
DEPCMD(21) = 0x00160002
DEPCMD(22) = 0x00170002
DEPCMD(23) = 0x00180002
DEPCMD(24) = 0x00190002
DEPCMD(25) = 0x001a0002
DEPCMD(26) = 0x001b0002
DEPCMD(27) = 0x001c0002
DEPCMD(28) = 0x001d0002
DEPCMD(29) = 0x001e0002
DEPCMD(30) = 0x001f0002
DEPCMD(31) = 0x00200002
OCFG = 0x00000000
OCTL = 0x00000040
OEVT = 0x80000000
OEVTEN = 0x00000000
OSTS = 0x00002019
ifconfig result
ifconfig
eth0      Link encap:Ethernet  HWaddr A4:D5:78:7E:5E:EC
          inet addr:192.168.1.1  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::a6d5:78ff:fe7e:5eec%132112/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:5 errors:0 dropped:0 overruns:0 frame:0
          TX packets:90 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1145 (1.1 KiB)  TX bytes:20649 (20.1 KiB)
          Interrupt:99
eth1      Link encap:Ethernet  HWaddr A4:D5:78:7E:5E:ED
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1%132112/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:166 errors:0 dropped:0 overruns:0 frame:0
          TX packets:166 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:12736 (12.4 KiB)  TX bytes:12736 (12.4 KiB)
usb0      Link encap:Ethernet  HWaddr C2:21:F7:06:34:84
          inet addr:192.168.0.1  Bcast:192.168.0.255  Mask:255.255.255.0
but, linux host pc can't detect linux gadget usb driver.
  • Hi Kim,
    What is the output of lsmod ? Have you made sure MASS STORAGE related gadget drivers are running ?
  • Hello!
    from target
    # lsusb
    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation
    # lsusb -v
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               3.00
      bDeviceClass            9 Hub
      bDeviceSubClass         0
      bDeviceProtocol         3
      bMaxPacketSize0         9
      idVendor           0x1d6b Linux Foundation
      idProduct          0x0003
      bcdDevice            4.04
      iManufacturer           3 Linux 4.4.45 xhci-hcd
      iProduct                2 xHCI Host Controller
      iSerial                 1 xhci-hcd.1.auto
      bNumConfigurations      1
      Configuration Descriptor:
        bLength                 9
        bDescriptorType         2
        wTotalLength           31
        bNumInterfaces          1
        bConfigurationValue     1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
        Interface Descriptor:
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          bInterfaceClass         9 Hub
          bInterfaceSubClass      0
          bInterfaceProtocol      0 Full speed (or root) hub
          iInterface              0
          Endpoint Descriptor:
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x81  EP 1 IN
            bmAttributes            3
              Transfer Type            Interrupt
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0004  1x 4 bytes
            bInterval              12
            bMaxBurst               0
    Hub Descriptor:
      bLength              12
      bDescriptorType      42
      nNbrPorts             1
      wHubCharacteristic 0x0009
        Per-port power switching
        Per-port overcurrent protection
      bPwrOn2PwrGood       10 * 2 milli seconds
      bHubContrCurrent      0 milli Ampere
      bHubDecLat          0.0 micro seconds
      wHubDelay             0 nano seconds
      DeviceRemovable    0x00
     Hub Port Status:
       Port 1: 0000.02a0 5Gbps power Rx.Detect
    Binary Object Store Descriptor:
      bLength                 5
      bDescriptorType        15
      wTotalLength           15
      bNumDeviceCaps          1
      SuperSpeed USB Device Capability:
        bLength                10
        bDescriptorType        16
        bDevCapabilityType      3
        bmAttributes         0x02
          Latency Tolerance Messages (LTM) Supported
        wSpeedsSupported   0x0008
          Device can operate at SuperSpeed (5Gbps)
        bFunctionalitySupport   3
          Lowest fully-functional device speed is SuperSpeed (5Gbps)
        bU1DevExitLat           0 micro seconds
        bU2DevExitLat           0 micro seconds
    can't get debug descriptor: Resource temporarily unavailable
    Device Status:     0x0001
      Self Powered
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bDeviceSubClass         0
      bDeviceProtocol         1 Single TT
      bMaxPacketSize0        64
      idProduct          0x0002
      bcdDevice            4.04
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              12
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             1
        TT think time 8 FS bits
      PortPwrCtrlMask    0xff
     Hub Port Status:
       Port 1: 0000.0100 power
    can't get device qualifier: Resource temporarily unavailable
      Self Powered
    I meant lsmod and corrected it. What is the USB device you are trying to configure ? When you give the uboot command, do you connect the USB cable to PC ? What happens, when you connect the USB cable after linux kernel boots up(with uboot command given)
    next lsmod (device mode is not working)
    # lsmod
    Module Size Used by
    rpmsg_rpc 19412 0
    xhci_plat_hcd 5119 0
    xhci_hcd 108888 1 xhci_plat_hcd
    usbcore 193663 2 xhci_plat_hcd,xhci_hcd
    dwc3 64014 0
    virtio_rpmsg_bus 12760 1 rpmsg_rpc
    xfrm_user 22972 2
    bluetooth 324846 2
    xfrm4_tunnel 2040 0
    ipcomp 2473 0
    xfrm_ipcomp 4567 1 ipcomp
    esp4 6465 0
    ah4 5665 0
    af_key 27307 0
    xfrm_algo 6970 5 ah4,esp4,af_key,xfrm_user,xfrm_ipcomp
    ecb 1909 0
    sha512_generic 9903 0
    sha512_arm 12079 0
    sha256_generic 9503 0
    hmac 2735 0
    md5 1897 0
    sha1_generic 2621 0
    ahci_platform 3218 0
    libahci_platform 8821 1 ahci_platform
    sha1_arm_neon 6261 0
    libahci 27699 2 libahci_platform,ahci_platform
    c_can_platform 6604 0
    c_can 9590 1 c_can_platform
    sha1_arm 3862 1 sha1_arm_neon
    libata 195684 3 libahci,libahci_platform,ahci_platform
    can_dev 12225 1 c_can
    scsi_mod 129013 1 libata
    omap_aes_driver 19230 0
    omap_sham 21089 0
    omap_wdt 4570 0
    dwc3_omap 4926 0
    rtc_omap 8272 0
    omap_des 11446 0
    omap_rng 4835 0
    rng_core 7691 1 omap_rng
    omap_remoteproc 12637 4
    remoteproc 27185 3 omap_remoteproc,virtio_rpmsg_bus,rpmsg_rpc
    virtio 7452 2 remoteproc,virtio_rpmsg_bus
    virtio_ring 12291 2 remoteproc,virtio_rpmsg_bus
    sch_fq_codel 8059 3
    > I want to use USB port as ethernet and mass storage(to access the target eMMC device through usb from host linux pc).
    > USB cable is already connected. I didn't pug and unplug.
    > After uboot command, I unplugged the cable. And then booting the kernel, I pluged cable.
    > There's no message from /proc/kmsg and dmesg.
    > But I run modprobe g_multi <option>, next message is displayed from dmesg.
    > And device mode is working.
    [ 109.650567] udc 48890000.usb: registering UDC driver [g_multi]
    [ 109.650651] using random self ethernet address
    [ 109.655148] using random host ethernet address
    [ 109.659929] using random self ethernet address
    [ 109.664509] using random host ethernet address
    [ 109.670128] usb0: HOST MAC 9e:a7:cb:d4:af:4c
    [ 109.674756] usb0: MAC 72:dc:f5:89:be:6b
    [ 109.682166] userial_init: registered 4 ttyGS* devices
    [ 109.683954] Mass Storage Function, version: 2009/09/11
    [ 109.692420] LUN: removable file: (no medium)
    [ 109.698850] lun0: open backing file: /dev/mmcblk0
    [ 109.698866] LUN: file: /dev/mmcblk0
    [ 109.702391] Number of LUNs=1
    [ 109.705303] g_multi gadget: adding config #1 'Multifunction with RNDIS'/bf3309d4
    [ 109.705346] rndis_register: configNr = 0
    [ 109.705357] g_multi gadget: adding 'rndis'/ed447540 to config 'Multifunction with RNDIS'/bf3309d4
    [ 109.705381] rndis_set_param_medium: 0 0
    [ 109.705391] g_multi gadget: RNDIS: super speed IN/ep1in OUT/ep1out NOTIFY/ep2in
    [ 109.705406] g_multi gadget: adding 'acm'/ed9f13c0 to config 'Multifunction with RNDIS'/bf3309d4
    [ 109.705434] g_multi gadget: acm ttyGS0: super speed IN/ep3in OUT/ep2out NOTIFY/ep4in
    [ 109.705451] g_multi gadget: adding 'Mass Storage Function'/ed9e8b80 to config 'Multifunction with RNDIS'/bf3309d4
    [ 109.706283] g_multi gadget: I/O thread pid: 1157
    [ 109.706306] g_multi gadget: cfg 1/bf3309d4 speeds: super high full
    [ 109.706315] g_multi gadget: interface 0 = rndis/ed447540
    [ 109.706326] g_multi gadget: interface 1 = rndis/ed447540
    [ 109.706334] g_multi gadget: interface 2 = acm/ed9f13c0
    [ 109.706341] g_multi gadget: interface 3 = acm/ed9f13c0
    [ 109.706349] g_multi gadget: interface 4 = Mass Storage Function/ed9e8b80
    [ 109.706360] g_multi gadget: adding config #2 'Multifunction with CDC ECM'/bf330a78
    [ 109.706374] g_multi gadget: adding 'cdc_ethernet'/edbe5f00 to config 'Multifunction with CDC ECM'/bf330a78
    [ 109.706390] g_multi gadget: CDC Ethernet: super speed IN/ep1in OUT/ep1out NOTIFY/ep2in
    [ 109.706400] g_multi gadget: adding 'acm'/edbe5a80 to config 'Multifunction with CDC ECM'/bf330a78
    [ 109.706416] g_multi gadget: acm ttyGS0: super speed IN/ep3in OUT/ep2out NOTIFY/ep4in
    [ 109.706429] g_multi gadget: adding 'Mass Storage Function'/ed594980 to config 'Multifunction with CDC ECM'/bf330a78
    [ 109.706440] g_multi gadget: cfg 2/bf330a78 speeds: super high full
    [ 109.706448] g_multi gadget: interface 0 = cdc_ethernet/edbe5f00
    [ 109.706455] g_multi gadget: interface 1 = cdc_ethernet/edbe5f00
    [ 109.706462] g_multi gadget: interface 2 = acm/edbe5a80
    [ 109.706469] g_multi gadget: interface 3 = acm/edbe5a80
    [ 109.706476] g_multi gadget: interface 4 = Mass Storage Function/ed594980
    [ 109.706486] g_multi gadget: Multifunction Composite Gadget
    [ 109.712142] g_multi gadget: userspace failed to provide iSerialNumber
    [ 109.720286] g_multi gadget: g_multi ready
    [ 109.724323] g_multi 48890000.usb: usb_gadget_udc_start
    [ 109.730048] usb0: eth_open
    [ 109.730911] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
    [ 109.829025] g_multi gadget: suspend
    [ 110.191157] g_multi gadget: high-speed config #2: Multifunction with CDC ECM
    [ 110.198252] g_multi gadget: init ecm
    [ 110.198261] g_multi gadget: notify connect false
    [ 110.198276] g_multi gadget: reset acm ttyGS0
    [ 110.198283] g_multi gadget: activate acm ttyGS0
    [ 110.198302] g_multi gadget: acm ttyGS0 serial state 0000
    [ 110.198319] g_multi gadget: set_config: interface 4 (Mass Storage Function) requested delayed status
    [ 110.198325] g_multi gadget: delayed_status count 1
    [ 110.198414] g_multi gadget: usb_composite_setup_continue
    [ 110.198423] g_multi gadget: usb_composite_setup_continue: Completing delayed status
    [ 110.199122] g_multi gadget: activate ecm
    [ 110.199149] usb0: qlen 10
    [ 110.199159] g_multi gadget: ecm_open
    [ 110.199173] usb0: eth_start
    [ 110.199247] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
    [ 110.205551] g_multi gadget: packet filter 0c
    [ 110.205559] g_multi gadget: ecm req21.43 v000c i0000 l0
    [ 110.206285] g_multi gadget: acm ttyGS0 req21.20 v0000 i0002 l7
    [ 110.211075] g_multi gadget: acm ttyGS0 req21.20 v0000 i0002 l7
    [ 110.211426] g_multi gadget: acm ttyGS0 req21.22 v0003 i0002 l0
    [ 110.211968] g_multi gadget: acm ttyGS0 req21.20 v0000 i0002 l7
    [ 110.212113] g_multi gadget: acm ttyGS0 req21.22 v0002 i0002 l0
    [ 110.212186] g_multi gadget: packet filter 0e
    [ 110.212194] g_multi gadget: ecm req21.43 v000e i0000 l0
    [ 110.231835] g_multi gadget: packet filter 0c
    [ 110.231844] g_multi gadget: ecm req21.43 v000c i0000 l0
    [ 110.232019] g_multi gadget: packet filter 0e
    [ 110.232027] g_multi gadget: ecm req21.43 v000e i0000 l0
    [ 110.281371] g_multi gadget: notify connect true
    [ 110.312452] g_multi gadget: acm ttyGS0 req21.22 v0003 i0002 l0
    [ 110.313361] g_multi gadget: notify speed 425984000
    [ 110.332604] NOHZ: local_softirq_pending 08
    [ 110.413610] NOHZ: local_softirq_pending 08
    [ 110.451957] NOHZ: local_softirq_pending 08
    [ 110.490104] NOHZ: local_softirq_pending 08
    [ 110.702732] NOHZ: local_softirq_pending 08
    [ 110.809636] NOHZ: local_softirq_pending 08
    [ 110.861636] NOHZ: local_softirq_pending 08
    [ 110.953401] NOHZ: local_softirq_pending 08
    [ 111.154037] NOHZ: local_softirq_pending 08
    [ 111.210577] g_multi gadget: sending command-failure status
    [ 111.211085] g_multi gadget: bulk-in set halt
    [ 111.211308] g_multi gadget: bulk-in set halt
    [ 111.316334] g_multi gadget: bulk-in set halt
    [ 111.332400] NOHZ: local_softirq_pending 08
    [ 111.425936] g_multi gadget: bulk-in set halt
    [ 111.537130] g_multi gadget: bulk-in set halt
    [ 111.537530] g_multi gadget: bulk-in set halt
    [ 111.809771] g_multi gadget: packet filter 0e
    [ 111.809785] g_multi gadget: ecm req21.43 v000e i0000 l0
    [ 119.452724] g_multi gadget: acm ttyGS0 req21.22 v0000 i0002 l0
    [ 119.454061] g_multi gadget: acm ttyGS0 req21.22 v0003 i0002 l0
    [ 119.454144] g_multi gadget: acm ttyGS0 req21.20 v0000 i0002 l7
    [ 125.452425] g_multi gadget: acm ttyGS0 req21.22 v0000 i0002 l0
  • sorry.
    modprobe g_multi is not executed.
    next is lsmod after modprobe
    # lsmod
    Module Size Used by
    usb_f_acm 6304 1
    u_serial 10956 1 usb_f_acm
    g_multi 6438 0
    usb_f_mass_storage 41736 2 g_multi
    usb_f_rndis 21378 2 g_multi
    usb_f_ncm 13267 0
    usb_f_ecm 8418 1
    u_ether 13854 4 usb_f_ecm,usb_f_ncm,usb_f_rndis,g_multi
    libcomposite 46256 6 usb_f_acm,usb_f_ecm,usb_f_ncm,usb_f_rndis,g_multi,usb_f_mass_storage
    configfs 25246 7 usb_f_acm,usb_f_ecm,usb_f_ncm,usb_f_rndis,libcomposite,usb_f_mass_storage
    rpmsg_rpc 19412 0
    dwc3 64014 0
    xfrm_user 22972 2
    bluetooth 324846 2
    xfrm4_tunnel 2040 0
    ipcomp 2473 0
    esp4 6465 0
    ah4 5665 0
    af_key 27307 0
    ecb 1909 0
    sha512_arm 12079 0
    hmac 2735 0
    md5 1897 0
    sha1_generic 2621 0
    omap_sham 21089 0
    omap_wdt 4570 0
    dwc3_omap 4926 0
    rtc_omap 8272 0
    omap_des 11446 0
    omap_rng 4835 0
    sch_fq_codel 8059 4
  • I believe, if you can automate the modprobe of g_multi from scripting, I think you will be able to get it detected.
  • Hi Dwarakesh R
    Hmm. I think you misunderstand.
    The problem was not modprobe of gadget driver.
    Even though I executed the script of modprobe, device mode of USB1 was not working.
    My meaning is that only the log of lsmod is executed without modprobe of gadget driver.
    So I just added the log of lsmod command, after gadget driver execution.
    Device mode is not working after modprobe command without the uboot command. That is problem.
  • Oh ok got it. Were you able to observe any change in USB registers, between the working case and non working case(when uboot comand is given and not given). I suspect the FCLK of USB being not set the difference.
  • Hi~
    Dwarakesh R
    regdump : not working
    GCTL = 0x25802000
    GEVTEN = 0x00000000
    GSTS = 0x3e800002
    GGPIO = 0x00000000
    GUID = 0x0004042d
    GUCTL = 0x00008010
    DCFG = 0x00080804
    DCTL = 0x80000000
    DEVTEN = 0x00001e1f
    DSTS = 0x0093ca9c
    DGCMD = 0x00000000
    OCFG = 0x00000000
    OCTL = 0x00000040
    OEVT = 0x80000000
    OEVTEN = 0x00000000
    OSTS = 0x00002019
    regdump : working
    GCTL = 0x25802000
    GEVTEN = 0x00000000
    GSTS = 0x3e800002
    GGPIO = 0x00000000
    GUID = 0x0004042d
    GUCTL = 0x00008010
    GTXFIFOSIZ(2) = 0x00420004
    GTXFIFOSIZ(3) = 0x004600c4
    GTXFIFOSIZ(4) = 0x010a0004
    GTXFIFOSIZ(5) = 0x010e00c4
    DCFG = 0x0048088c
    DCTL = 0x8c000a00
    DEVTEN = 0x00001e1f
    DSTS = 0x0082f128
    DGCMD = 0x00000000
    DALEPENA = 0x00000aff
    DEPCMDPAR1(1) = 0xfbc46000
    DEPCMDPAR1(2) = 0xfbc48090
    DEPCMDPAR1(4) = 0x08000700
    DEPCMDPAR1(5) = 0xfbc58000
    DEPCMDPAR1(6) = 0xfbc4a000
    DEPCMDPAR1(7) = 0x0e000700
    DEPCMDPAR1(9) = 0xfbc5a000
    DEPCMDPAR1(11) = 0xfbc5b000
    DEPCMDPAR0(4) = 0x00001004
    DEPCMDPAR0(7) = 0x00061004
    DEPCMD(1) = 0x00010006
    DEPCMD(2) = 0x00020006
    DEPCMD(3) = 0x00000007
    DEPCMD(4) = 0x00000001
    DEPCMD(5) = 0x00050006
    DEPCMD(6) = 0x00060006
    DEPCMD(7) = 0x00000001
    DEPCMD(9) = 0x00090006
    DEPCMD(11) = 0x000b0006
    OCFG = 0x00000000
    OCTL = 0x00000040
    OEVT = 0x80000000
    OEVTEN = 0x00000000
    OSTS = 0x0000201f
    diff not working(left) : working(right)
