Linux/AM5718: SD card booting problem
Part Number: AM5718
Other Parts Discussed in Thread: DRA722, PMP, TMP102, TLC59108
Tool/software: Linux
We have developed a custom board with AM5718 Processor and while booting with SD card as boot device, sometimes it was booting properly and sometimes not. Please see my logs, and help me in this regard.
Boot Log1:
[    7.056700] omap_hsmmc 4809c000.mmc: card removed during transfer last time
[    7.063715] omap_hsmmc 4809c000.mmc: recovery done
[    7.069688] Starting init: /sbin/init exists but couldn't execute it (error -14)
[    7.078692] EXT4-fs error (device mmcblk0p2): __ext4_get_inode_loc:3946: inode #155042: block 622594: comm init: unable to read itable block
[    7.091474] Starting init: /bin/init exists but couldn't execute it (error -5)
[    7.100004] EXT4-fs error (device mmcblk0p2): __ext4_get_inode_loc:3946: inode #155042: block 622594: comm init: unable to read itable block
[    7.112711] EXT4-fs (mmcblk0p2): previous I/O error to superblock detected
[    7.119717] Starting init: /bin/sh exists but couldn't execute it (error -5)
[    7.126832] Kernel panic - not syncing: No working init found.  Try passing init= option to kernel. See Linux Documentation/init.txt for gui.
[    7.140016] drm_kms_helper: panic occurred, switching back to text console
[    7.146956] ---[ end Kernel panic - not syncing: No working init found.  Try passing init= option to kernel. See Linux Docum
Boot Log2:
[    4.192446] Freeing unused kernel memory: 340K (c08e1000 - c0936000)
[    4.346536] omap_hsmmc 4809c000.mmc: card removed during transfer last time
[    4.353552] omap_hsmmc 4809c000.mmc: recovery done
[    4.358497] mmc0: card e624 removed
/sbin/init: error while loading shared libraries: /lib/libblkid.so.1: cann[    4.364066] JBD2: Error -5 detected when updating journal superblo.
ot read file data: Input/output error
[    4.376655] Aborting journal on device mmcblk0p2-8.
[    4.385012] JBD2: Error -5 detected when updating journal superblock for mmcblk0p2-8.
[    4.394101] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
[    4.394101]
[    4.403274] drm_kms_helper: panic occurred, switching back to text console
[    4.410214] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
[    4.410214]
Boot Log3:
[  OK  ] Started matrix-gui-2.0.service.
         Starting thermal-zone-init.service...
[  OK  ] Started thermal-zone-init.service.
[  OK  ] Reached target Multi-User System.
         Starting Update UTMP about System Runlevel Changes...
[  OK  ] Started Update UTMP about System Runlevel Changes.
[   12.207627] omap_hsmmc 4809c000.mmc: card removed during transfer last time
[   12.214690] omap_hsmmc 4809c000.mmc: recovery done
[   12.296878] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:332: I/O error -5 writing to inode 162411 (offset 0 size 0 starting block 64796)
[   12.309724] Buffer I/O error on device mmcblk0p2, logical block 629784
[   12.317851] mmc0: card e624 removed
[   12.326185] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:332: I/O error -5 writing to inode 166077 (offset 0 size 0 starting block 67437)
[   12.339030] Buffer I/O error on device mmcblk0p2, logical block 656198
[   12.345616] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:332: I/O error -5 writing to inode 166081 (offset 0 size 4096 starting block 68)
[   12.358714] Buffer I/O error on device mmcblk0p2, logical block 662036
[   12.374728] Aborting journal on device mmcblk0p2-8.
[   12.380231] JBD2: Error -5 detected when updating journal superblock for mmcblk0p2-8.
[   12.462854] EXT4-fs error (device mmcblk0p2): ext4_find_entry:1457: inode #204873: comm systemd-udevd: reading directory lblock 0
[   12.476552] EXT4-fs error (device mmcblk0p2): ext4_find_entry:1457: inode #204001: comm systemd-journal: reading directory lblock 0
[   12.512149] EXT4-fs (mmcblk0p2): previous I/O error to superblock detected
[   12.583647] mmc0: host does not support reading read-only switch, assuming write-enable
[   12.595011] mmc0: new high speed SDHC card at address e624
[   12.604903] mmcblk0: mmc0:e624 SU04G 3.69 GiB
[   12.613764] EXT4-fs error (device mmcblk0p2): ext4_find_entry:1457: inode #146881: comm systemd-udevd: reading directory lblock 0
Boot Log 4:
U-Boot SPL 2015.07-00080-g4523775-dirty (Feb 11 2017 - 11:54:05)
DRA722 ES1.0
DRA722 ES1.0
reading args
spl_load_image_fat_os: error reading image args, err - -1
reading u-boot.img
reading u-boot.img
ti_i2c_eeprom_init failed 1
U-Boot 2015.07-00080-g4523775-dirty (Feb 11 2017 - 11:54:05 +0530)
CPU  : DRA722 ES1.0
Board: AM571x II2C:   ready
DRAM:  1 GiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
reading uboot.env
SCSI:  SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net:
 **********Auto Negotiation Available******cpsw
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading uEnv.txt
574 bytes read in 3 ms (186.5 KiB/s)
Loaded environment from uEnv.txt
Importing environment from mmc0 ...
3576616 bytes read in 244 ms (14 MiB/s)
89661 bytes read in 46 ms (1.9 MiB/s)
Booting from mmc0 ...
Kernel image @ 0x82000000 [ 0x000000 - 0x369328 ]
   Loading Device Tree to 8ffe7000, end 8ffffe3c ... OK
Starting Medha kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.1.13-g8dc6617 (medha@medha) (gcc version 4.9.3 20150413 (prerelease) (Linaro GCC 4.9-2015.05) ) #83 SMP PREEMPT 7
[    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] Machine model: TI AM571x IDK
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[    0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[    0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[    0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 24 MiB at 0x00000000be400000
[    0.000000] Forcing write-allocate cache policy for SMP
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] DRA722 ES1.0
[    0.000000] PERCPU: Embedded 11 pages/cpu @eee4d000 s16128 r8192 d20736 u45056
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 210514
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=00093288-02 rw rootfstype=ext4 rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 649612K/848896K available (6743K kernel code, 301K rwdata, 2312K rodata, 340K init, 258K bss, 19060K reserved, 180224K c)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc08e0074   (9057 kB)
[    0.000000]       .init : 0xc08e1000 - 0xc0936000   ( 340 kB)
[    0.000000]       .data : 0xc0936000 - 0xc0981428   ( 302 kB)
[    0.000000]        .bss : 0xc0984000 - 0xc09c48cc   ( 259 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Additional per-CPU info printed with stalls.
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] OMAP clockevent source: timer1 at 32768 Hz
[    0.000000] clocksource 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 65535999984741ns
[    0.000030] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000427] Architected cp15 timer(s) running at 6.14MHz (virt).
[    0.000427] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[    0.000462] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[    0.000472] Switching to timer-based delay loop, resolution 162ns
[    0.000983] Console: colour dummy device 80x30
[    0.000998] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.001004] This ensures that you still see kernel messages. Please
[    0.001009] update your kernel commandline.
[    0.001021] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[    0.001034] pid_max: default: 32768 minimum: 301
[    0.001117] Security Framework initialized
[    0.001153] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001162] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001687] Initializing cgroup subsys blkio
[    0.001701] Initializing cgroup subsys memory
[    0.001727] Initializing cgroup subsys devices
[    0.001740] Initializing cgroup subsys freezer
[    0.001751] Initializing cgroup subsys perf_event
[    0.001773] CPU: Testing write buffer coherency: ok
[    0.002031] /cpus/cpu@0 missing clock-frequency property
[    0.002044] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002080] Setting up static identity map for 0x80008380 - 0x800083d8
[    0.040742] Brought up 1 CPUs
[    0.040754] SMP: Total of 1 processors activated (12.29 BogoMIPS).
[    0.040761] CPU: All CPU(s) started in SVC mode.
[    0.041114] devtmpfs: initialized
[    0.064839] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.065651] omap_hwmod: l3_main_2 using broken dt data from ocp
[    0.078675] omap_hwmod: tptc0 using broken dt data from edma-controller
[    0.079140] omap_hwmod: tptc1 using broken dt data from edma-controller
[    0.154137] omap_hwmod: dcan2: _wait_target_disable failed
[    0.247723] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.251585] pinctrl core: initialized pinctrl subsystem
[    0.252392] NET: Registered protocol family 16
[    0.253327] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.261394] OMAP GPIO hardware version 0.1
[    0.263488] omap_gpio 48059000.gpio: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/gpio4_pins_default, deferring proe
[    0.285685] No ATAGs?
[    0.285710] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.285719] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.288156] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[    0.288166] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[    0.288729] OMAP DMA hardware revision 0.0
[    0.327946] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[    0.330593] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver
[    0.335409] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[    0.335590] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[    0.335743] omap-iommu 58882000.mmu: 58882000.mmu registered
[    0.335893] omap-iommu 55082000.mmu: 55082000.mmu registered
[    0.336163] vgaarb: loaded
[    0.336527] SCSI subsystem initialized
[    0.338434] palmas 0-0058: IRQ missing: skipping irq request
[    0.351072] palmas 0-0058: Muxing GPIO 51, PWM 0, LED 2
[    0.391527] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[    0.391704] media: Linux media interface: v0.10
[    0.391759] Linux video capture interface: v2.00
[    0.391800] pps_core: LinuxPPS API ver. 1 registered
[    0.391807] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.391832] PTP clock support registered
[    0.392470] omap-mailbox 4883c000.mailbox: omap mailbox rev 0x400
[    0.392759] omap-mailbox 4883e000.mailbox: omap mailbox rev 0x400
[    0.393042] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    0.393111] omap-mailbox: probe of 48842000.mailbox failed with error -22
[    0.393337] Advanced Linux Sound Architecture Driver Initialized.
[    0.393999] Switched to clocksource arch_sys_counter
[    0.403398] missing cooling_device property
[    0.403408] failed to build thermal zone board_thermal: -2
[    0.403516] NET: Registered protocol family 2
[    0.404095] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.404159] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.404284] TCP: Hash tables configured (established 8192 bind 8192)
[    0.404336] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.404368] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.404563] NET: Registered protocol family 1
[    0.404809] RPC: Registered named UNIX socket transport module.
[    0.404817] RPC: Registered udp transport module.
[    0.404824] RPC: Registered tcp transport module.
[    0.404830] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.405800] CPU PMU: Failed to parse /pmu/interrupt-affinity[0]
[    0.405830] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.407724] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.407804] audit: initializing netlink subsys (disabled)
[    0.407836] audit: type=2000 audit(0.390:1): initialized
[    0.414815] VFS: Disk quotas dquot_6.6.0
[    0.414985] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.417021] NFS: Registering the id_resolver key type
[    0.417050] Key type id_resolver registered
[    0.417057] Key type id_legacy registered
[    0.417116] jffs2: version 2.2. (NAND) (SUMMARY)  �© 2001-2006 Red Hat, Inc.
[    0.419463] NET: Registered protocol family 38
[    0.419540] bounce: pool size: 64 pages
[    0.419552] io scheduler noop registered
[    0.419563] io scheduler deadline registered
[    0.419598] io scheduler cfq registered (default)
[    0.423044] pinctrl-single 4a003400.pinmux: 281 pins at pa fc003400 size 1124
[    0.423159] pinctrl-single 4a002e8c.pinmux: 1 pins at pa fc002e8c size 4
[    0.438833] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[    0.438847] pci_bus 0000:00: root bus resource [io  0x1000-0xffff]
[    0.438857] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[    0.438867] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.438988] pci 0000:00:00.0: IOMMU is currently not supported for PCI
[    0.439248] PCI: bus0: Fast back to back transfers disabled
[    0.439641] pci 0000:01:00.0: IOMMU is currently not supported for PCI
[    0.440001] PCI: bus1: Fast back to back transfers disabled
[    0.440132] pci 0000:00:00.0: BAR 8: assigned [mem 0x20400000-0x20ffffff]
[    0.440144] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[    0.440157] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[    0.440170] pci 0000:00:00.0: BAR 7: assigned [io  0x1000-0x1fff]
[    0.440183] pci 0000:01:00.0: BAR 0: assigned [mem 0x20800000-0x20ffffff]
[    0.440202] pci 0000:01:00.0: BAR 3: assigned [mem 0x20400000-0x20403fff]
[    0.440220] pci 0000:01:00.0: BAR 2: assigned [io  0x1000-0x101f]
[    0.440237] pci 0000:00:00.0: PCI bridge to [bus 01]
[    0.440247] pci 0000:00:00.0:   bridge window [io  0x1000-0x1fff]
[    0.440258] pci 0000:00:00.0:   bridge window [mem 0x20400000-0x20ffffff]
[    0.442049] ldo5: supplied by evm_3v3_sd
[    0.442588] OMAP DSS rev 6.1
[    0.442855] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[    0.447449] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.450382] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 267, base_baud = 3000000) is a 8250
[    1.447473] console [ttyS0] enabled
[    1.451639] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 268, base_baud = 3000000) is a 8250
[    1.461148] 48420000.serial: ttyS6 at MMIO 0x48420000 (irq = 269, base_baud = 3000000) is a 8250
[    1.470634] 48422000.serial: ttyS7 at MMIO 0x48422000 (irq = 270, base_baud = 3000000) is a 8250
[    1.480528] [drm] Initialized drm 1.1.0 20060810
[    1.493410] brd: module loaded
[    1.500506] loop: module loaded
[    1.505109] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[    1.511861] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    1.520496] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[    1.530701] scsi host0: ahci
[    1.533864] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 307
[    1.542300] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.550280] libphy: Fixed MDIO Bus: probed
[    1.554903] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[    1.561981] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    1.567856] e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
[    1.573712] e1000e: Copyright(c) 1999 - 2014 Intel Corporation.
[    1.579736] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.2.15-k
[    1.586829] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.592488] igb 0000:01:00.0: enabling device (0140 -> 0142)
[    1.609809] CTRL_CORE_MAC_ID_SW_3  5cf821
[    1.613836] CTRL_CORE_MAC_ID_SW_2  40fb99
[    1.637539] pps pps0: new PPS source ptp0
[    1.641572] igb 0000:01:00.0: added PHC on eth0
[    1.646146] igb 0000:01:00.0: Intel(R) Gigabit Ethernet Network Connection
[    1.653051] igb 0000:01:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 5c:f8:21:40:fb:99
[    1.660233] igb 0000:01:00.0: eth0: PBA No: FFFFFF-0FF
[    1.665409] igb 0000:01:00.0: Using legacy interrupts. 1 rx queue(s), 1 tx queue(s)
[    1.724026] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[    1.730150] davinci_mdio 48485000.mdio: detected phy mask fffffdff
[    1.738556] libphy: 48485000.mdio: probed
[    1.742588] davinci_mdio 48485000.mdio: phy[9]: device 48485000.mdio:09, driver unknown
[    1.751169] CTRL_CORE_MAC_ID_SW_1  5cf821
[    1.755243] CTRL_CORE_MAC_ID_SW_0  40fb98
[    1.759267] mac addr[i] 5c
[    1.761983] mac addr[i] f8
[    1.764751] mac addr[i] 21
[    1.767467] mac addr[i] 40
[    1.770181] mac addr[i] fb
[    1.772896] mac addr[i] 98
[    1.775667] cpsw 48484000.ethernet: Missing slave[1] phy_id property
[    1.782048] CTRL_CORE_MAC_ID_SW_1  5cf821
[    1.786109] CTRL_CORE_MAC_ID_SW_0  40fb98
[    1.790133] mac addr[i] 5c
[    1.792847] mac addr[i] f8
[    1.795592] mac addr[i] 21
[    1.798307] mac addr[i] 40
[    1.801021] mac addr[i] fb
[    1.803734] mac addr[i] 98
[    1.806467] cpsw 48484000.ethernet: Detected MACID = 5c:f8:21:40:fb:98
[    1.814553] mousedev: PS/2 mouse device common for all mice
[    1.820641] RTC date time get
[    1.823934] rtc-ds1307 0-0068: rtc core: registered ds1307 as rtc0
[    1.830379] rtc-ds1307 0-0068: 56 bytes nvram
[    1.834839] i2c /dev entries driver
[    1.839963] tmp102 0-0049: initialized
[    1.845152] omap_hsmmc 4809c000.mmc: Got CD GPIO
[    1.884651] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[    1.892093] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[    1.900541] ata1: SATA link down (SStatus 0 SControl 300)
[    1.906002] omap_hsmmc 480b4000.mmc: no pinctrl state for ddr_1_8v mode
[    1.912731] omap_hsmmc 480b4000.mmc: no pinctrl state for hs mode
[    1.918915] omap_hsmmc 480b4000.mmc: no pinctrl state for hs200_1_8v mode
[    1.964327] ledtrig-cpu: registered to indicate activity on CPUs
[    1.970679] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[    1.977258] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[    1.983545] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[    1.990429] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[    1.999779] oprofile: using timer interrupt.
[    2.004466] Initializing XFRM netlink socket
[    2.008780] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.016897] NET: Registered protocol family 17
[    2.021385] NET: Registered protocol family 15
[    2.026053] Key type dns_resolver registered
[    2.030440] mmc0: new high speed SDHC card at address e624
[    2.036106] omap_voltage_late_init: Voltage driver support not added
[    2.042726] Power Management for TI OMAP4+ devices.
[    2.047989] mmcblk0: mmc0:e624 SU04G 3.69 GiB
[    2.053123] ThumbEE CPU extension supported.
[    2.057534]  mmcblk0: p1 p2
[    2.060649] Registering SWP/SWPB emulation handler
[    2.070504] dmm 4e000000.dmm: workaround for errata i878 in use
[    2.078125] dmm 4e000000.dmm: initialized all PAT entries
[    2.100151] tlc59108 0-0040: Successfully initialized tlc59108
[    2.126402] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.133046] [drm] No driver support for vblank timestamp query.
[    2.142226] [drm] Enabling DMM ywrap scrolling
[    2.187714] Console: switching to colour frame buffer device 100x37
[    2.197467] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[    2.203412] omapdrm omapdrm.0: registered panic notifier
[    2.234192] omapwb-m2m: Device registered as video10
[    2.239181] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[    2.245377] RTC date time get
[    2.248560] rtc-ds1307 0-0068: setting system clock to 2017-06-28 20:31:32 UTC (1498681892)
[    2.257422] fdt: not creating '/sys/firmware/fdt': CRC check failed
[    2.275251] ldo4: disabling
[    2.278512] ldo2: disabling
[    2.281602] aic_dvdd_fixed: disabling
[    2.285323] vdd_3v3: disabling
[    2.288614] ALSA device list:
[    2.291592]   No soundcards found.
[    2.309640] EXT4-fs (mmcblk0p2): recovery complete
[    2.314529] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.322680] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.332194] devtmpfs: mounted
[    2.335430] Freeing unused kernel memory: 340K (c08e1000 - c0936000)
[    2.397991] mmc1: MAN_BKOPS_EN bit is not set
[    2.403147] mmc1: new MMC card at address 0001
[    2.408049] mmcblk1: mmc1:0001 MMC04G 3.60 GiB
[    2.412851] mmcblk1boot0: mmc1:0001 MMC04G partition 1 16.0 MiB
[    2.419130] mmcblk1boot1: mmc1:0001 MMC04G partition 2 16.0 MiB
[    2.428452]  mmcblk1: p1 p2
[    2.709477] systemd[1]: Failed to insert module 'autofs4': No such file or directory
[    2.726967] random: nonblocking pool is initialized
[    2.739908] systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRY)
[    2.758432] systemd[1]: Detected architecture arm.
Welcome to Arago 2017.05!
[    2.784847] systemd[1]: Set hostname to <am57xx-evm>.
[    3.125510] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
[    3.133301] systemd[1]: sysinit.target: Found dependency on alignment.service/start
[    3.141047] systemd[1]: sysinit.target: Found dependency on basic.target/start
[    3.148368] systemd[1]: sysinit.target: Found dependency on sockets.target/start
[    3.155851] systemd[1]: sysinit.target: Found dependency on avahi-daemon.socket/start
[    3.163718] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
[    3.171168] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
[    3.180624] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
[ SKIP ] Ordering cycle found, skipping alignment.service
[    3.219210] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    3.244281] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    3.264253] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    3.284245] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    3.304260] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[    3.334304] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[    3.364126] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    3.384119] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    3.404601] systemd[1]: Created slice System Slice.
[  OK  ] Created slice System Slice.
[    3.428291] systemd[1]: Starting Load Kernel Modules...
[    3.456097] systemd[1]: Starting Remount Root and Kernel File Systems...
[    3.486344] systemd[1]: Starting Setup Virtual Console...
[    3.501474] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    3.508150] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    3.544870] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    3.566062] systemd[1]: Mounting Debug File System...
[    3.594392] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[    3.624241] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    3.644222] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    3.666641] systemd[1]: Mounting Temporary Directory...
[    3.694427] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[    3.716082] systemd[1]: Starting Journal Service...
[    3.744332] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    3.764217] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    3.776320] systemd[1]: Starting Create Static Device Nodes in /dev...
[    3.816251] systemd[1]: Mounting POSIX Message Queue File System...
[    3.840624] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    3.883743] systemd[1]: Mounted Debug File System.
[  OK  ] Mounted Debug File System.
[    3.914229] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    3.934229] systemd[1]: Mounted Temporary Directory.
[  OK  ] Mounted Temporary Directory.
[    3.954527] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Setup Virtual Console.
[  OK  ] Started Create Static Device Nodes in /dev.
         Starting udev Kernel Device Manager...
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting udev Coldplug all Devices...
         Mounting Configuration File System...
         Starting Apply Kernel Variables...
         Starting Flush Journal to Persistent Storage...
[  OK  ] Mounted Configuration File System.
[  OK  ] Mounted /var/volatile.
[  OK  ] Mounted /media/ram.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Apply Kernel Variables.
[    4.436186] systemd-journald[104]: Received request to flush runtime journal from PID 1
[  OK  ] Reached target Local File Systems.
         Starting Load/Save Random Seed...
[  OK  ] Started Flush Journal to Persistent Storage.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Synchronized.
         Starting Synchronize System and HW clocks...
[    4.871781] RTC date time set
[    4.884726] RTC date time get[  OK  ] Started Synchronize System and HW clocks.
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Reached target System Initialization.
[  OK  ] Listening on RPCbind Server Activation Socket.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Listening on dropbear.socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
         Starting Print notice about GPLv3 packages...
[  OK  ] Started System Logging Service.
         Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Started D-Bus System Message Bus.
[    5.445361] igb 0000:01:00.0 enp1s0: renamed from eth0
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
         Starting Network Service...
[  OK  ] Started Kernel Logging Service.
         Starting uim-sysfs.service...
         Starting Telephony service...
         Starting TI MultiCore Tools Daemon...
         Starting Login Service...
[  OK  ] Found device /dev/ttyS0.
[    6.303471] net eth1: initializing cpsw version 1.15 (0)
[  OK  ] Started Network Service.
[FAILED] Failed to start TI MultiCore Tools Daemon.
See 'systemctl status ti-mct-daemon.service' for details.
[    6.547135] net eth1: phy found : id is : 0x20005c90
[    6.552240] libphy: PHY  not found
[  OK  ] Started Telephony service.
[  OK  ] Started Login Service.
[  OK  ] Reached target Network.
         Starting Lightning Fast Webserver With Light System Requirements...
[    6.712856] net eth1: phy  not found on slave 1
         Starting Enable and configure wl18xx bluetooth stack...
[  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
         Starting Permit User Sessions...
         Starting Network Name Resolution...
         Starting Simple Network Management Protocol (SNMP) Daemon....
[  OK  ] Started Lightning Fast Webserver With Light System Requirements.
[  OK  ] Started Permit User Sessions.
[  OK  ] Found device /dev/ttyS2.
[  OK  ] Started Network Name Resolution.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS0.
[  OK  ] Reached target Login Prompts.
[  OK  ] Started Enable and configure wl18xx bluetooth stack.
[    8.599284] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    8.650654] kjournald starting.  Commit interval 5 seconds
[    8.914584] EXT3-fs (mmcblk1p2): using internal journal
[    8.919855] EXT3-fs (mmcblk1p2): recovery complete
[    9.036767] EXT3-fs (mmcblk1p2): mounted filesystem with ordered data mode
[    9.205427] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
[  OK  ] Started uim-sysfs.service.
         Starting rc.pvr.service...
[  OK  ] Started rc.pvr.service.
         Starting weston.service...
[  OK  ] Started weston.service.
         Starting telnetd.service...
         Starting tiipclad-daemon.service...
[  OK  ] Started telnetd.service.
[  OK  ] Started tiipclad-daemon.service.
         Starting thttpd.service...
[  OK  ] Started thttpd.service.
         Starting rng-tools.service...
NOTICE: This file system contains the following GPLv3 packages:
        autoconf
        binutils-dev
        binutils
        bison-dev
        bison
        cpp-symlinks
        cpp
        dosfstools
        g++-symlinks
        g++
        gawk-dev
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbc6x
        gdbserver
        gstreamer1.0-libav
        hidapi
        libcairo-perf-utils
        libgmp10
        libidn11
        libmpc3
        libmpfr4
        libreadline-dev
        libreadline6
        m4-dev
        m4
        make
        nettle
        parted
        swig-dev
        swig
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Started rng-tools.service.
[  OK  ] Started Print notice about GPLv3 packages.
         Starting SYSV: The kdump script provides the support:...
[FAILED] Failed to start SYSV: The kdump script provides the support:.
See 'systemctl status kdump.service' for details.
         Starting gdbserverproxy.service...
[  OK  ] Started gdbserverproxy.service.
         Starting matrix-gui-2.0.service...
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org am57xx-evm ttyS0
Arago 2017.05 am57xx-evm ttyS0
am57xx-evm login: root
root@am57xx-evm:~#
Ganesh
