Other Parts Discussed in Thread: AM3517
Hello StarterWare forum:
We are looking to set up SDIO on an AM3517 that is running a custom application instead of Linux. Part of the project involves a high data rate output that necessitates the use of DMA to drive the SDIO bus we are going to be using.
We have not been able to find much in the way of example code for this on the TI sites.
The only thing we’ve been able to pull down is the U-boot driver, but that uses polling.
Is there any reference code or example projects we can reference?
I posted this initially on the Sitara forum and got this feedback:
The Starterware MMC/SD driver makes use of DMA as far as I know, but unfortunately there is no Starterware version for AM35XX so you may want to check with the StarterWare forum.
Any feedback or input is welcomed and appreciated!
Thanks again!
Paul
