Other Parts Discussed in Thread: SYSBIOS, TMS320C6657
I am running sysBios 6.33.6.50, MCSDK 2.1.1.4 and PDK TMS320C6657 version 1.1.1.4. XDCtool is 3.32.4.60. CCS version is 5.2.1.00018.
Following spruex3k-7.pdf section 6.6.2, I added the following lines to the cfg file
var Cache = xdc.useModule('ti.sysbios.hal.Cache');
var ti_sysbios_family_c66_Cache = xdc.useModule('ti.sysbios.family.c66.Cache');
ti_sysbios_family_c66_Cache.MAR_128_159 = 0;
and got the following error message:
Description Resource Path Location Type
ti.sysbios.family.c66.Cache: no element named 'MAR_128_159' GaussEVMc6657.cfg /GaussEVMc6657 25 C/C++ Problem
I have the following questions:
1. In stead of ti.sysbios.family.c64p I used c66. Would this make a difference? If I change it to 64p, would it cause trouble for C66 processor?
2. I understand the number MAR_128 as MAR register 128, where does the number 159 come from? If I try to access other registers, which number should I use for instance MAR_130_???
3. how do I solve this cfg file problem?
thanks
Weichun
