When using the assembly-optimized dsplib library on the OMAP-L138 LCDK, I encounter a quirk with subsequent calls to DSPF_sp_cfftr2_dit and DSPF_sp_icfftr2_dif. The API states that the twiddle factors should be bit-reversed; however upon performing this action to both the transform and inverse twiddle factors, there is distortion present in an N=32 sized transform. If the twiddle factors are passed non-bit-reversed in back-to-back transform/inverse calls, this distortion is not present. Why might this be the case? Code snippet is as follows, for context:
FFT operations within ISR:
// Extract data (complex) from input framebuffer
for (i=0; i < BUFFER_COUNT; i++) {
// Populate input sample arrays
inpLcpx[2*i] = Left[i];
inpLcpx[2*i+1] = 0.0;
inpRcpx[2*i] = Right[i];
inpRcpx[2*i+1] = 0.0;
// Calculate FFT using call to optimized-assembly DSPF_sp_cffrt2_dit
DSPF_sp_cfftr2_dit(inpLcpx, twiddle, BUFFER_COUNT);
DSPF_sp_cfftr2_dit(inpRcpx, twiddle, BUFFER_COUNT);
// Calculate IFFT using call to optimized-assembly DSPF_sp_icfftr2_dif
DSPF_sp_icfftr2_dif(inpLcpx, twiddleInv, BUFFER_COUNT);
DSPF_sp_icfftr2_dif(inpRcpx, twiddleInv, BUFFER_COUNT);
// Then pack real data into output framebuffer
Twiddle factors are generated as follows. Call is to method defined within ISR, from main:
void twidInit()
int i=0;
float a = 2.0f*PI/BUFFER_COUNT;
for (i=0; i < BUFFER_COUNT; i+=2) {
// Populate twiddle factors
twiddle[i] = cosf(-(i/2)*a);
twiddle[i+1] = -sinf(-(i/2)*a);
twiddleInv[i] = cosf((i/2)*a);
twiddleInv[i+1] = -sinf(-(i/2)*a);
