Other Parts Discussed in Thread: TM4C123GH6PM, CC3100, SYSBIOS
Hello all,
I am attempting to build a simple LED blink project using TI-RTOS of the TM4C. The build process of my project fails due to a "fatal error #1965: cannot open source file...empty_pem4f.h"
Does anyone have experience with this problem?
FYI I am using:
-Code Composer Version: 6.1.0.00104
-XDC Tools Version 3.31.1.33
-TI-RTOS for Tiva C 2.14.0.10
Here is my console window:
**** Build of configuration Debug for project blink_TM4C_BIOS ****
"C:\\ti\\ccsv6\\utils\\bin\\gmake" -k all
'Building file: ../main.c'
'Invoking: ARM Compiler'
"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.2/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 --abi=eabi -me --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.2/include" --include_path="I:/Need a home/ECE 4437/TI-RTOS Workshop/TI-RTOS Labs/TM4C/Labs/Lab_04/Project" --include_path="C:/ti/tirtos_tivac_2_14_00_10/products/TivaWare_C_Series-2.1.1.71b" --include_path="C:/ti/tirtos_tivac_2_14_00_10/packages/ti/drivers/wifi/cc3100/Simplelink" --include_path="C:/ti/tirtos_tivac_2_14_00_10/packages/ti/drivers/wifi/cc3100/Simplelink/Include" -g --gcc --define=ccs="ccs" --define=PART_TM4C123GH6PM --define=ccs --define=TIVAWARE --display_error_number --diag_warning=225 --diag_warning=255 --diag_wrap=off --gen_func_subsections=on --preproc_with_compile --preproc_dependency="main.pp" --cmd_file="./configPkg/compiler.opt" "../main.c"
"C:/ti/xdctools_3_31_01_33_core/packages/xdc/cfg/global.h", line 39: fatal error #1965: cannot open source file "I:/Need a home/ECE 4437/TI-RTOS Workshop/TI-RTOS Labs/TM4C/Labs/Lab_04/Project/Debug/configPkg/package/cfg/empty_pem4f.h"
1 catastrophic error detected in the compilation of "../main.c".
Compilation terminated.
>> Compilation failure
gmake: *** [main.obj] Error 1
'Building file: ../empty.cfg'
'Invoking: XDCtools'
"C:/ti/xdctools_3_31_01_33_core/xs" --xdcpath="C:/ti/tirtos_tivac_2_14_00_10/packages;C:/ti/tirtos_tivac_2_14_00_10/products/bios_6_42_01_20/packages;C:/ti/tirtos_tivac_2_14_00_10/products/ndk_2_24_03_35/packages;C:/ti/tirtos_tivac_2_14_00_10/products/uia_2_00_02_39/packages;C:/ti/ccsv6/ccs_base;" xdc.tools.configuro -o configPkg -t ti.targets.arm.elf.M4F -p ti.platforms.tiva:TM4C123GH6PM -r release -c "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.2" --compileOptions "-mv7M4 --code_state=16 --float_support=FPv4SPD16 --abi=eabi -me --include_path=\"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.2/include\" --include_path=\"I:/Need a home/ECE 4437/TI-RTOS Workshop/TI-RTOS Labs/TM4C/Labs/Lab_04/Project\" --include_path=\"C:/ti/tirtos_tivac_2_14_00_10/products/TivaWare_C_Series-2.1.1.71b\" --include_path=\"C:/ti/tirtos_tivac_2_14_00_10/packages/ti/drivers/wifi/cc3100/Simplelink\" --include_path=\"C:/ti/tirtos_tivac_2_14_00_10/packages/ti/drivers/wifi/cc3100/Simplelink/Include\" -g --gcc --define=ccs=\"ccs\" --define=PART_TM4C123GH6PM --define=ccs --define=TIVAWARE --display_error_number --diag_warning=225 --diag_warning=255 --diag_wrap=off --gen_func_subsections=on " "../empty.cfg"
configuring empty.xem4f from package/cfg/empty_pem4f.cfg ...
generating custom ti.sysbios library makefile ...
Starting build of library sources ...
making I:/NEEDAH~1/ECE443~1/TI-RTO~1/TI-RTO~1/TM4C/Labs/Lab_04/Project/src/sysbios/sysbios.aem4f ...
gmake[1]: Entering directory `I:/NEEDAH~1/ECE443~1/TI-RTO~1/TI-RTO~1/TM4C/Labs/Lab_04/Project/src/sysbios'
clem4f C:/ti/tirtos_tivac_2_14_00_10/products/bios_6_42_01_20/packages/ti/sysbios/BIOS.c ...
C:/Users/JUANRE~1/AppData/Local/Temp/make9184-1.sh: 1: Syntax error: Unterminated quoted string
gmake[1]: *** [BIOS.obj] Error 2
gmake[1]: Leaving directory `I:/NEEDAH~1/ECE443~1/TI-RTO~1/TI-RTO~1/TM4C/Labs/Lab_04/Project/src/sysbios'
gmake: *** [I:/NEEDAH~1/ECE443~1/TI-RTO~1/TI-RTO~1/TM4C/Labs/Lab_04/Project/src/sysbios/sysbios.aem4f] Error 2
error: xdc.cfg.SourceDir: "C:/ti/xdctools_3_31_01_33_core/packages/xdc/cfg/SourceDir.xs", line 209: xdc.cfg.SourceDir : Build of generated source libraries failed: exit status = 2:
Build of libraries failed.
js: "C:/ti/xdctools_3_31_01_33_core/packages/xdc/cfg/Main.xs", line 160: Error: Configuration failed!
xdctools_3_31_01_33_core\gmake.exe: *** [package/cfg/empty_pem4f.xdl] Error 1
xdctools_3_31_01_33_core\gmake.exe: *** Deleting file `package/cfg/empty_pem4f.xdl'
xdctools_3_31_01_33_core\gmake.exe: *** [package/cfg/empty_pem4f.xdl] Deleting file `package/cfg/empty_pem4f.h'
xdctools_3_31_01_33_core\gmake.exe: *** [package/cfg/empty_pem4f.xdl] Deleting file `package/cfg/empty_pem4f.c'
js: "C:/ti/xdctools_3_31_01_33_core/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
gmake: *** [configPkg/linker.cmd] Error 1
gmake: Target `all' not remade because of errors.
**** Build Finished ****
