CPU and Task Load Analysis using CCS (RTOS/SYSBIOS instrumentation)
I have extracted the CPU and Task load %.
Here is the procedure to extract and interpret the data:
 Step1:
  • Build the code by enabling UIA instrumentation, as shown below:
  • TI-RTOS->Products->UIA->LoggingSetup - UIA Logging Configuration: Enable CPU Load and Task Load
Step 2:
  • Flash the code built with the above mentioned options onto the microcontroller.
Step 3:
  • Enable execution Analysis (CPU and Load) by going into Tools menu.
  • Tools->Execution Analysis->Start/Run
Step4
  • Initiate the free run for a while and then suspend the execution/debugger
  • We can see the following graph depicting CPU and Task Load % (no need to insert the breakpoints, suspending the execution is enough to capture the details)
Every time we resume and suspend the execution the graph gets updated with recent/new data
Please let me know the procedure followed is right and the data aligns with my interpretation.
Occasionally i observe the warning called, x gap in records missed loading the data, please let me know if there is any action required for this.
-Nikhilesh
