Good afternoon,
I'm trying to test the logging functions of the RTOS. The manual says:
"UIA. The Unified Instrumentation Architecture (UIA) defines APIs and transports that allow
embedded software to log instrumentation data for use within CCS. In order to use UIA, you will need
to install TI-RTOS, which is available in the TI App Center within CCS. UIA is the TI-RTOS
Instrumentation component. TI-RTOS is provided with full source code and requires no up-front or
runtime license fees."
For some reason, uia is not in my TI install directory ( I installed RTOS for AM437x). Where should it be installed? Is there a patch for RTOS so I can add UIA manually?
Kind regards,
John van Maanen
